Hi all,
In a major bind trying to finish an edit and ever since I installed Digital Anarchy's Deflicker, Premiere won't open and throws the error in the screen capture posted below. I uninstalled Digital Anarchy to no avail. I also uninstalled the entire creative suite and reinstalled and still getting the same error. I'm assuming there is a cache or some setting syncing with my old settings when I reinstall.
Anybody know how I can resolve this or know how I can completely remove all Adobe settings, presets, etc off my computer for a brand new fresh install?
Edit: Also when I follow the path below to see the files in question, there is no plug-ins folder in Common.
Any and all help appreciated, Thank you.
Not exactly, but I appreciate the response.
Sorry i Forgot to come back and update, but after trying nearly everything I finally found buried in a cached folder an old version of flicker free installed for an older version of premiere (2016). inside that folder was a broken uninstall file and a broken 32bit file and once deleted premiere started back up with no issue.
Hope this helps anyone with the same troubles.
Need to uninstall the plugin and make sure it's removed from Premiere 2018 preferences, then reinstall Premiere 2019.
Hey RunGun!
Were you able to get back to work with BikeVeloce's suggestion?
-Caroline
Was curious where you found this folder? I'm in a similar bind right now!
hope this helps!
So incredibly helpful thank you!!!! I was almost in tears I was so frustrated today and this was the ticket!
Thank you so much and appreciate this is helpful.
Thanks SO MUCH for this very helpful information. Honestly made my day and saved me a mini breakdown : )
Cheers sir.
Thank you so much for finding this hack. Worked perfectly!
Thanks for posting your solution... Vestiges of old installs can create problems and it's not always easy to find them...
Thanks @rungun88! This same thing worked for BeautyBox. NOT a cheap plugin and after a traumatic recovery from Time Machine finding it not working was killing my spirit. Your fix worked a trick! Sending love from Indonesia.
