Premiere CC2019 No video playback, weird crashes since 13.0.1 update
Nov 12, 2018 Nov 12, 2018
Hello,
I've been working with the CC2019 13.0.0 version of premiere succesfully since its release. I'm on an iMac with HighSierra 10.13.6 installed.
Last week I updated to the 13.0.1 version and encountered severe problems:
Problem description:
I immediatly noticed that I couldn't get any video playback in any of my existing projects, nor in newly created ones.
The Project preview window stays either black, or grey, I get no audio playback either. In converted projects the source window also isn't showing anything,
in newly created projects it's working as usual.
When placing an object in a newly created project's timeline, I get the following error:
A low-level exception occurred in: Adobe-Bereiche (Transmit::CreateInstance)
Also Premiere is crashing everytime when I try to quit and I have to hardquit it.
Attempted fixes:
I've tried resetting preferences, changing software acceleration and also reinstalled Premiere CC2019. Rightnow I downgraded back to version 13.0.0 but that doesn't change anything. My older version of CC2018 is still working (luckily). I can't reinstall the whole CC rightnow due to time issues and projects that need to be finished.
I'm using a clean Premiere Install without any plugins or third party software.
I tried googling the above symptoms and it looks like the Transmit tool is connected to third party software, which I don't have any installed though.
It also seems like nobody else has this exact problem according to my research.
Maybe someone here can help me out. If you need any additional information, I'll provide it.
Best Wishes
Lennard
3.2K
New Here , Jan 02, 2019 Jan 02, 2019
Delete the file :Mac - Document - Adobe - Premiere Pro - 13.0
And then, restart Pr 2019, and good luck.
Adobe Employee ,
Hi Lennard,
Sorry about your issue. I appreciate that you have already tried to fix it. I understand you are not getting any playback in Adobe Premiere Pro. Please follow the steps mentioned below:
  1. Try cleaning media cache. FAQ: How to clean (delete or trash) media cache files?
  2. Please check if the Composite Video view is selected for the Program monitor.
  3. Please check if the correct audio hardware is selected under Preferences > Audio Hardware > Default Output
Let us know if it helps.
Shivangi
Nov 13, 2018 Nov 13, 2018
Hi Shivangi,
thank you for the answer. I looked into all of your suggestions but they don't seem to work.
I noticed two additional things:
- The video and audio playback in the source monitor only works before I create a sequence with the imported footage.
As soon as I do that, the frame freezes and scrubbing isn't working anymore.
- Premiere also crashes when I close all projects over the file tab.
Maybe that helps.
Best wishes
Lennard
Nov 19, 2018 Nov 19, 2018
We have all the same symptoms and an International documentary is at not deliverable right now.  This version is terrible.
We can't trash our preferences and media cache every second crash, 6 times a day..... this is really bad now.
Nov 21, 2018 Nov 21, 2018
Ok, so there are no more suggestions on what I should try out?
Nov 26, 2018 Nov 26, 2018
So there is still no update at all?
Dec 03, 2018 Dec 03, 2018
So I'll just keep asking weekly if there are any new updates on this...
Jan 07, 2019 Jan 07, 2019
This actually worked out! Thanks alot. It seems like the documents folder didn't get deleted during the uninstall. That's why I never bothered to actually delete it manually.
Feb 01, 2019 Feb 01, 2019
I don't see a file of that name. Any further information? because we are still resetting user settings 3-4 times a day just to open after crashes, which are a plenty...
I just deleted the whole folder full of files as opposed to a file. See how we travel.
May 28, 2019 May 28, 2019
Thanks so much!! This worked well!
Jan 05, 2019 Jan 05, 2019
Have you tried: Files> Project Settings> General > Change the renderer and also mess about with the audio section as well.
Had a similar issue where I had no video output and switching from Mercury Playback Engine GPU Accelerated (CUDA) to Mercury Playback Engine Software Only worked for me.
Jun 09, 2019 Jun 09, 2019
Just discovered this same problem after trying to clear out my cache. Deleted the 13.0 folder and it's all working again now, thank you!!
