Bonjour,
Je ne peux plus ouvrir mes fichiers pdf. Voici le message d'erreur :
Crashed Thread: | 0 |
Exception Type: | EXC_CRASH (SIGABRT) |
Exception Codes: | 0x0000000000000000, 0x0000000000000000 |
Exception Note: | EXC_CORPSE_NOTIFY |
Termination Reason: | DYLD, [0x5] Code Signature |
J'ai désinstallé et réinstallé le logiciel sans succès.
Pouvez-vous m'apporter votre aide s'il vous plaît ? Merci.
Cécile
Moderator: Moved from Adobe Creative Cloud to Acrobat General Troubleshooting
Hi Cecile,
Sorry for the trouble caused.
As the application crashing when you try to open the PDF, try the troubleshooting steps mentioned here Resolve Acrobat DC intermittent crashes on Windows.
If that does not help, try the cleaner tool to remove the Acrobat from your machine.
Take help of the steps mentioned here Use the Creative Cloud Cleaner Tool to solve installation problems
It will remove the application from your system.
Then reboot the device once and re-install the application from your CC application.
If the issue still occurs, please share the crash logs of the application using Acrobat and Reader process monitor tool Download Acrobat and Reader Process Monitor Tool - Adobe Labs
Also, share the details as asked below:
- Application version
- OS version on the machine
- Do you experience this behavior with every PDF you try to open in Acrobat?
- Are you able to open the Acrobat application directly by clicking on the Acrobat Acrobat DC icon on the desktop?
Let us know if you have any questions or need any help.
Meenakshi
