The really useful script here is
Sephiroth's
Actionscript 3 PHP Unserializer. I have used the old AS2
version many times and it's totally rad. With it you can create
really complex data objects in php,
serialize() them, and then
unserialize them with this code in Flash. It dramatically reduces
the amount of code you have to write to share complex data between
PHP and Flash.
The problem I'm having is that the new Actionscript 3 version
was apparently written for Flex. When I try to use it in flash, I
get an error:
1004: Namespace was not found or is not a compile-time
constant.. This error refers to this line of code:
use namespace mx_internal;
I know next to nothing about namespaces in Flash, but best I
can tell, that namespace constant is apparently to be found in
mx.core.
At any rate, if I remove all references to mx_internal
namespace and mx.core, I can get the script working. This brings me
to my first questions:
QUESTION 1: What does the use of that namespace stuff
accomplish?
QUESTION 2: Am I likely to suffer any unpredictable consequences
by removing that namespace stuff?
Also, I get an error (1061: Call to a possibly undefined
method serialize through a reference with static type
org.sepy.io:Serializer.) when I try to call the static methods of
the Serialize class by instantiating it and calling the methods via
the instance like this:
var oSerializer:Serializer = new Serializer();
var str = oSerializer.serialize(obj);
That's my third question:
QUESTION 3: Is it impossible to call a static method of a class
from an instance of the class? Do we have to reference the class
name instead?
Any help would be much appreciated
