Hi All
I use the below applescript to export a PDF from Indesign CC 2019 to a folder on my desktop that begins with "Q", it works
well and as expected, what I am wanting to do is try the same set up in extend script, my problem is I don't no how to write
it, can some one please help translate this to extend script, using the same variables etc, and with out user interaction?
thank you in advance.
tell application "Finder"
set myFolder to POSIX path of ((folders of desktop whose name begins with "Q") as string)
end tell
tell application id "com.adobe.InDesign"
set myDoc to active document
set docName to name of myDoc as string
set _dest to myFolder as Unicode text
delete unused swatches of document 1
set screenSettings to PDF export preset "USE THIS TO DISTILL-1"
set page range of PDF export preferences to all pages
set PathToDesktop to file path of document 1 as string
set this_folder to (PathToDesktop) as alias
export document 1 format PDF type to (_dest & docName & ".pdf") using screenSettings without options
close document 1 saving yes
tell PDF export preferences
set view PDF to true
end tell
end tell
Hi Kevin,
Try the following, i have removed some unused variables like PathToDesktop and this_folder. i have not added anything extra like error handling conditions, i have tried to keep the code as similar to the one you have. Give it a try and let me know if something is missing, i am not proficient in Applescript so i may have skipped something
...function isOurFolder(arg)
if(arg.name.match(/^Q.*?/))
return true
else
return false
var myFolder = Folder.desktop.getFiles(is
I have run the script and its exported pdf in the desktop folder which name starts with "Q". When desktop contains more than one folder, name starts with "Q"? Its throwing an error. In this case, how to will you decide the destination folder?
Better choose or define the path.
Hi SUdha
thanks for replying, my work flow dictates I only have 1 folder on desktop beginning with Q, no need for error check
Regards
Kevin Parrott
Hi Kevin,
return true
else
return false
var myFolder = Folder.desktop.getFiles(isOurFolder)
var myDoc = app.activeDocument
var docName = myDoc.name
var _dest = myFolder[0].fsName
try
var unusedSwatches = myDoc.unusedSwatches
for(var i = 0; i < unusedSwatches.length; i++)
unusedSwatches.remove()
catch(e){}
var screenSettings = app.pdfExportPresets.itemByName("USE THIS TO DISTILL-1")
app.pdfExportPreferences.pageRange = PageRange.ALL_PAGES
app.pdfExportPreferences.viewPDF = true
app.activeDocument.exportFile(ExportFormat.PDF_TYPE, _dest + "/" + docName + ".pdf", false, screenSettings)
myDoc.close(SaveOptions.YES)
-Manan
Hi Manan,
Really nice... It is works same as apple script which he post.
arg for the function isOurFolder is Folder.desktop.getFiles?
isOurFolder is a callback function that will be called with each File or Folder as arg within the desktop folder.
-Manan
Hi Manan
thank you for the code,appreciate the time taken to translate, it slips perfectly into my work flow, and it's faster than the apple script I was using, which was the main reason for doing this.
One thing id like to change is when the PDF is exported it looks like this Q12345-ABCD-.indd.pdf , id like to eliminate the .indd suffix, is this doable within the code you provided?
cheers
Kevin
Hi Manan,
Thanks for your explanation...
Hi Kevin,
return true
else
return false
var docName = myDoc.name.replace(".indd",".pdf") // replaced .indd to .pdf
alert("docName " + docName)
try
catch(e){}
var screenSettings = app.pdfExportPresets.itemByName("OUP_US")
app.activeDocument.exportFile(ExportFormat.PDF_TYPE, _dest + "/" + docName, false, screenSettings)
Pls check.
Hi Sudha
thanks for your input
I am now getting an error, I have an ope ID file, I then run the script
Adobe Indesign CC 2019 got an error: Cannot save to the file "Q12345",because it is already open
Change this line to your preset file.
Also check whether pdf file is already open.
Hi
I already changed over the preset to my one, and no pdf's are open, only the Indesign file
it appears that the Indesign file did not have the .indd suffix on it, I tried a file with the .indd suffix and it worked
is there a possibility to add a little error check to see if the .indd suffix is there or not ?
Try the following line
var docName = myDoc.name.replace(/.indd$/i, "")
and let me know how it goes
P.S. :- Just change this line in the original script and not any other
-Manan
Hi Sudha,
In your code we could have the following issues.
-Manan
Hi Manan,
Thanks for pointing out the issues and for explanation. It useful to avoid such issues.
Thank you...
Hi Manan
Thank you very much for your time and knowledge, very much appreciated, the final change worked perfectly, it seems
a lot faster than the apple script.
Sudha, thank you for your time and input
