What platform does the cloud run on?
if you're asking what hardware adobe uses, i don't think that's public info.
otherwise, Adobe Cloud Platform | Adobe
We can easily assume that the cloud platform runs on state of the art hardware and software. Otherwise you may guess some of it when looking at the host names. But most important of all: as John T Smith ​correctly assumes, the Adobe side of the cloud platform is simply irrelevant to the user...
Or do you mean this?
System requirements for Cloud Programs... scroll down and check each program
-http://helpx.adobe.com/creative-cloud/system-requirements.html
We're all grasping at straws to understand your question. Can you be more specific?
After more digging, I found my answer which is Flash or Macromedia Flash. Thanks all.
How does that relate to your original question?
Just curious.
My IT department is evaluating every technology our company uses and asked me what 'platform' the Creative Could runs on and the answer I found was 'Flash.'
What Creative Cloud are you referring to? Where did you get your answer from?
The answer is not Flash.
Flash is an old technology which Adobe has retired and parts of which have been rolled into Adobe Animate. Nothing to do with the platform that the Creative Cloud runs on.
creative cloud programs run locally (on your computer).
if you share documents using adobe's creative cloud, then your question make some (but not very much) sense.
and it doesn't make sense for your it dept to delegate their job to their clients (you). they might reasonable ask you what programs you're using but otherwise they're misleading you or you're misleading them or both.
and, as has been pointed out, no matter who wants to know what, 'flash' is the wrong answer.
Before receiving a good and sensible answer, one must know how to formulate the right question.
[Tongue in cheek answer follows]
Your answer is water vapour which condenses with aerosols into tiny water droplets or ice crystals at very high altitudes below -30 degrees.
