4 Replies Latest reply on Apr 1, 2009 6:55 PM by (Marco_Ugolini)
    Color Settings CS3 Mac for CMYK Commercial Print
    CS3 Charlene Level 1
      Can somebody advise me as too what I should be setting my color settings to so they will be the same across the suite and when I send my files to commercial print that prints CMYK sheet fed coated.
      I've read so much I'm confused. I'm new to CS3 and the Mac ... In the past my work has come back perfect in color and matched to my monitor. Now on CS3 on the Mac I'm not sure what to do.
      If anyone can help it would be most appreciated.
        • 1. Re: Color Settings CS3 Mac for CMYK Commercial Print
          (Marco_Ugolini) Level 1
          What tools did you use then? Why can't you go back to using those?
          >Now on CS3 on the Mac I'm not sure what to do..
          What exactly is getting you stumped?
          • 2. Re: Color Settings CS3 Mac for CMYK Commercial Print
            Brace yourself ... I have been working in Corel on a PC. I purchased CS3 and the Mac as there were problems in sending files to print from Corel.
            I haven't sent out any files from the Mac as of yet as I want to know what color settings need to be set at to minimize problems.
            Can you advise?
            • 3. Re: Color Settings CS3 Mac for CMYK Commercial Print
              Marco ... I read your post on rGB / CMYK conversion and I'm looking for the answer you are ... I work through a print broker that prints CMYK and the only thing he can tell me is that they print CMYK and on sheet fed coated. So my question is di turn everything to CMYK on my monitor and change to sheet fed coated in the settings?
              • 4. Re: Color Settings CS3 Mac for CMYK Commercial Print
                Which one was that, if you could remind me?
                Well, yes, print is always CMYK. As for "sheetfed coated", I would assume that they intend a color space like the one described by the U.S. Sheetfed Coated v2 profile (though it could possibly be the GRACoL2006_Coated1v2 profile). You may want to ask them to confirm one or the other, to be safer.
                To make sure I understand your question, I think you are asking me whether you should turn your image file(s) to a chosen CMYK output profile. Yes and no. You should do your color and tonal correction work
                b in RGB
                , and convert to the intended CMYK output profile
                b only as a last step
                , just before you deliver the files to the print provider or the prepress specialists.
                Do
                b not
                convert your files to the intended CMYK output profile in the beginning and correct them in CMYK. Do not do that. That is not the most desirable way to work.
                The default working spaces in Photoshop's Color Settings are important, but not essential. Yes, you should set the default RGB profile to AdobeRGB (if not ProPhoto RGB, though you may wish to hold off on that one until you have more experience with the application), and the CMYK default profile to U.S. Sheetfed Coated v2.
                But, as long as your chosen color management policies are to "Preserve Embedded Profiles", and as long as the image files you work on are tagged with the appropriate profile, then the default profile in Color Settings is no longer relevant.
