Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
SOLVED
After migrating From AEM 6.2 to AEM 6.4 Clientlib is not working in Publish
Avatar
Level 4
Dear All,
I have migrated my AEM application from AEM 6.2 AEM 6.4.
In AEM 6.2 , my clientlibs was under the path /etc/designs , as shown below.
After migrating to AEM 6.4 , I have moved to the clientlibs under the apps/Sunita , as shown below.
After doing the necessary changes , my home page images are coming fine in AEM-6.4 author instance.
But it is not coming fine in AEM-6.4 publish instance. It is still calling etc.clientlibs , as shown below.
I am feeling I have missed something. But I am not able to figure out .
It will be really appreciated if Anybody can help me on this.
1 Accepted Solution
Avatar
Correct answer by
Community Advisor
Yes, you need to change references in CSS as well
e.g.
You can reference the image in CSS via /etc.clientlibs/myprojects/clientlibs/foo/resources/icon.png
.insight-splash-v2 .arr-right {
    background-image: url("/etc.clientlibs/SUNITA/clientlibs/global/resources/images/arrow-background.png");
    display: block;
    height: 30px;
    width: 30px;
    color: #fff;
Arun Patidar
Avatar
Community Advisor
Try this, it worked for me. Images under /apps are worked only when there are under resources folder
Ex:
Image/Fonts: /apps/site/clientlibs/resources
CSS: /apps/site/clientlibs/css
Avatar
Level 3
What category you are adding for clientlibs ?? How you are including your clientlibs ???
Please post more details
Avatar
Community Advisor
In order for the client libraries under /apps to be accessible, a proxy servelt is used. The ACLs are still enforced on the client library folder, but the servlet allows for the content to be read via /etc.clientlibs/ if the allowProxy property is set to true.
A static resource can only be accessed via the proxy, if it resides below a resource below the client library folder.
As an example:
  • You have a clientlib in /apps/myproject/clientlibs/foo
  • You have a static image in /apps/myprojects/clientlibs/foo/resources/icon.png
Then you set the allowProxy property on foo to true.
  • You can then request /etc.clientlibs/myprojects/clientlibs/foo.js
  • You can then reference the image via /etc.clientlibs/myprojects/clientlibs/foo/resources/icon.png
Arun Patidar
Avatar
Level 4
Dear All,
Thanks a lot for your response. I have put the images in resources and still it is not coming fine.
and in my clientlibs /apps/SUNITA/clientlibs/global , I have created the below categories.
In my head.jsp , I have included below categories
<cq:includeClientLib categories="etc.sunita.global"/>
But still it is not calling to the images to the path SUNITA/clientlibs/global/css/images/arrow-background.png
Avatar
Community Advisor
Your image should be inside resources folder
Arun Patidar
Avatar
Level 4
So I have one doubt here. After putting the images under resources , do I need to change anything in my css file "or" there is no need to change anywhere ?
I have added below one in my css file.
    background-image: url("images/arrow-background.png");
    display: block;
    height: 30px;
    width: 30px;
    color: #fff;
I believe to call the  resources/images/arrow-background.png is the later part but all the [pages still calling to the path  http://localhost:4503/etc.clientlibs/SUNITA/clientlibs/global/css/images/arrow-background.png
Avatar
Level 3
Sunita,
As arun mentioned your images should be in resources folder.
Please try using ui include instead of cq. Ex:
<ui:includeClientLib categories="etc.sunita.global"/>
Avatar
Correct answer by
Community Advisor
e.g.
    display: block;
    height: 30px;
    width: 30px;
    color: #fff;
Arun Patidar
Avatar
Level 4
Thanks Arun ,
Now it is working fine after , I changes all my images/ path to the below path.
