15 Replies Latest reply on Dec 6, 2018 10:56 AM by Kevin Parrott
    how to translate export pdf from applescript to extend scriipt
    Kevin Parrott Level 2
      Hi All
      I use the below applescript to export a PDF from Indesign CC 2019 to a folder on my desktop that begins with "Q", it works
      well and as expected, what I am wanting to do is try the same set up in extend script, my problem is I don't no how to write
      it, can some one please help translate this to extend script, using the same variables etc, and with out user interaction?
      thank you in advance.
      tell application "Finder"
          set myFolder to POSIX path of ((folders of desktop whose name begins with "Q") as string)
      end tell
      tell application id "com.adobe.InDesign"
          set myDoc to active document
          set docName to name of myDoc as string
          set _dest to myFolder as Unicode text
          delete unused swatches of document 1
          set screenSettings to PDF export preset "USE THIS TO DISTILL-1"
          set page range of PDF export preferences to all pages
          set PathToDesktop to file path of document 1 as string
          set this_folder to (PathToDesktop) as alias
          export document 1 format PDF type to (_dest & docName & ".pdf") using screenSettings without options
          close document 1 saving yes
          tell PDF export preferences
              set view PDF to true
          end tell
      end tell
