hello, i used the transform - > deform on a background
now i want that the text that i add to this layer gets n the same way deformed, so that its clung on the background
is there a possibility without having to work extra with Text - deform tool?
because would take much more time and background is not so clear to see
First off: There is no »Deform Tool« in Photoshop», neither a »Transform Tool«, Photoshop Tools are to be found in the Toolbar.
Please post a meaningful screenshot including the Layers Panel.
If I understand correctly you should ideally select both Layers and transform them in one go.
Alternatively you could also convert the two Layers together to a Smart Object and transform that.
ok smart object works, but hte other option not.
but now ic ant make changes to the text layer anymore in after effects.
is there a way around that?
Hi, Can you please post a screenshot so that we can understand your issue ?
Thanks.
