So I made a gif which I wanted to use for my follower widget for streamlabs:
And its working fine but the only problem is when I put it in, its creating some wierd white flimer thing and I dont know why. Its making the white stuff around the box and around the text when it is disappearing. Can someone please help
-Petervpg
I don't see a "white flimer thing"!
What program do you use?
I made it in a program called OvrStream and I made it a gif in Photoshop.
Heres a link for Imgur where you can se the white thing:
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
[Moved from generic Cloud/Setup forum to the specific Program forum... Mod]
What was it before?
You can see that its making these white things, and before its simply the same just without the white stuffm
Is it because of the transparent background in the gif?
The P has a white border or stroke which you do not see on the lef and top when displayed on a white background on this web site. You do see it on it own dark background. Your see none of it while the P is panned into view on the white background. White on White.
Not sure why it's doing it exactly, but you can see that it is actually your text appearing for a frame or 2. Looks like your animation timing is a little off with the masks appearing and so forth.
When you have it open in Photoshop are you able to find those specific frames? You can put a black background to find them easier. It looks like you have some white elements that should be removed from specific frames.
I tried to put a blue background in and then chroma key it and it actually works. Im pretty New to Photoshop so Im sry. Thanks everybody Who tried to help me.
