20 Replies Latest reply on Dec 6, 2018 12:55 PM by shaylag45954664
    Script to Export Multiple PDFs at Once
    rahulb1976 Level 1
      Hi All
      I’m trying to find out how to export two PDF's at once from Indesign CC. I'm aiming to get 1 PDFx-1a PDF (High res with crop and bleed) and 1 smallest File Size (Cropped, no marks)? Could you point me in the right direction or if anyone has a working script I could use that would be amazing. My brain is going to fall out my ears.
      Many thanks
      Rahul
        • 2. Re: Script to Export Multiple PDFs at Once
          rahulb1976 Level 1
          Thank you however I've tried this but the coding is incorrect. Could you resupply it on here? I keep getting an error with it.
          Want to test this today 20th April if possible. Many thanks.
          • 3. Re: Script to Export Multiple PDFs at Once
            [Jongware] Most Valuable Participant
            Why not share the error? It may help us help you.
            • 4. Re: Script to Export Multiple PDFs at Once
              rahulb1976 Level 1
              Got an error with it - I don't know anything about scripts, so any help or reconfiguration would be amazing!
              // BS"D
              // All rights reserved (c) 2015 by Id-Extras.com
              // Free to use and modify but do not delete this copyright attribution.
              // This script will export 2 pdfs of the current document
              // Choose the PDF presets by altering their names below
              // The second PDF gets a suffix added to its name.
              // Modify the line below beginning name2 = to change the suffix.
              // For more InDesign scripts: www.Id-Extras.com
              d = app.activeDocument;
              // Here you can choose the PDF preset
              preset1 = app.pdfExportPresets.itemByName("200dpi");
              preset2 = app.pdfExportPresets.itemByName("300dpi");
              if (!(preset1.isValid && preset2.isValid)){
              alert("One of the presets does not exist. Please check spelling carefully.");
              exit();
              if (d.saved){
              thePath = String(d.fullName).replace(/\..+$/, "") + ".pdf";
              thePath = String(new File(thePath).saveDlg());
              else{
              thePath = String((new File).saveDlg());
              thePath = thePath.replace(/\.pdf$/, "");
              name1 = thePath.replace(/AW$/, "LR")+".pdf";
              name2 = thePath.replace(/AW$/, "HR") +".pdf";
              d.exportFile(ExportFormat.PDF_TYPE, new File(name1), false, preset1);
              d.exportFile(ExportFormat.PDF_TYPE, new File(name2), false, preset2);
              • 5. Re: Script to Export Multiple PDFs at Once
                Peter Kahrel Adobe Community Professional & MVP
                Looks as if you're treating this as an AppleScript. But it's JavaScript.
                2 people found this helpful
                • 6. Re: Script to Export Multiple PDFs at Once
                  rahulb1976 Level 1
                  Hi Peter thanks for this. If it does work - I know its a silly question but how do I make this work with indesign? I know nothing about scripts - apple or java. Does this script work?
                  • 7. Re: Script to Export Multiple PDFs at Once
                    Copy the script to InDesign's script folder, then run it from InDesign's Scripts panel. See here for details:
                    https://indesignsecrets.com/how-to-install-scripts-in-indesign.php
                    P.
                    1 person found this helpful
                    • 8. Re: Script to Export Multiple PDFs at Once
                      rahulb1976 Level 1
                      Peter - great work - however can you tell me what im doing wrong. I'm almost there but not sure about the characters for the indesign pdf presets.
                      preset1 = app.pdfExportPresets.[HighQualityPrint]("300dpi");
                      preset2 = app.pdfExportPresets.[Smallest File Size]("100dpi");
                      exit();
                      if (d.saved){
                      else{
                      d.exportFile(ExportFormat.PDF_TYPE, new File(name2), false, preset2);Screen Shot 2018-04-20 at 15.32.17.png
                      Cheers for your help so far, greatly appreciated.
                      • 9. Re: Script to Export Multiple PDFs at Once
                        You'll have to specify PDF presets that exist on your disk. This one:
                        should be this:
                        preset1 = app.pdfExportPresets.item ('[High Quality Print]');
                        and for preset2 you should use a similar format.
                        (mind the spaces). The ones in Ariel's script are specific for his system (sorry, Ariel, I seem to have hijacked this thread. . .)
                        P.
                        • 10. Re: Script to Export Multiple PDFs at Once
                          rahulb1976 Level 1
                          Okay - so the script worked! Yay! however its only creating one pdf - not two and its not renaming _LR _HR. I dont have a clue why it's working completley. Ive created two presets myself Print 1 and Lowres as test presets. Only one is working. See Code. I'm happy to wait on this, but just really need it by the end of next week. So close I can feel it!
                          preset1 = app.pdfExportPresets.item ('Print1');
                          preset2 = app.pdfExportPresets.item ('Lowres');
                          exit();
                          if (d.saved){
                          else{
                          • 11. Re: Script to Export Multiple PDFs at Once
                            rahulb1976 Level 1
                            Okay - so the script worked! Yay! however its only creating one pdf - not two and its not renaming _LR _HR. I dont have a clue why it's working completly. Ive created two presets myself Print 1 and Lowres as test presets. Only one is working. See Code. I'm happy to wait on this, but just really need it by the end of this week. So close I can feel it!
                            exit();
                            if (d.saved){
                            else{
                            • 12. Re: Script to Export Multiple PDFs at Once
                              Looks as if the script expects the names of the InDesign files to end in AW. Try this:
                              name1 = thePath + "LR.pdf";
                              name2 = thePath + "HR.pdf";
                              • 13. Re: Script to Export Multiple PDFs at Once
                                rahulb1976 Level 1
                                Fantastic - Thanks very much for your help! Greatly appreciated!
                                Rahul
                                • 14. Re: Script to Export Multiple PDFs at Once
                                  TᴀW Adobe Community Professional & MVP
                                  Thanks for the help, Peter!
                                  The script that rahul1976 is posting here has been modified (possibly by me for someone else). The original version on the website that I linked to initially should work fine as is (see my initial post above).
                                  Ariel
                                  • 15. Re: Script to Export Multiple PDFs at Once
                                    rahulb1976 Level 1
                                    Thanks guys - Ariel your right I couldn't figure out the bit where I wanted to customise it.
                                    Many thanks
                                    • 16. Re: Script to Export Multiple PDFs at Once
                                      charur94718007 Level 2
                                      I hope this change in script will help you
                                      d = app.activeDocument; preset1 = app.pdfExportPresets.itemByName("[PDF/X-1a:2001]"); preset2 = app.pdfExportPresets.itemByName("[Smallest File Size]"); if (!(preset1.isValid && preset2.isValid)) { alert("One of the presets does not exist. Please check spelling carefully."); exit(); } if (d.saved) { thePath = String(d.fullName).replace(/\..+$/, "") + ".pdf"; thePath = String(new File(thePath).saveDlg()); } else { thePath = String((new File).saveDlg()); } thePath = thePath.replace(/\.pdf$/, ""); name1 = thePath + "_LR.pdf"; name2 = thePath + "_HR.pdf" d.exportFile(ExportFormat.PDF_TYPE, new File(name1), false, preset1); d.exportFile(ExportFormat.PDF_TYPE, new File(name2), false, preset2);
                                      • 17. Re: Script to Export Multiple PDFs at Once
                                        schuba Level 1
                                        Hello
                                        Im looking for a way to iprove this script a little - that it will
                                        - save pdfs in current indd document location
                                        - add active layer name to output name - filename_layername_LR
                                        anyone could help me with it ?
                                        • 18. Re: Script to Export Multiple PDFs at Once
                                          fragmichnicht Level 1
                                          Hello
                                               exit();
                                          thePath = d.filePath + "/" + d.name.replace(".indd", "") + "_" + d.activeLayer.name;
                                          name1 = thePath + "_HR.pdf";
                                          name2 = thePath + "_LR.pdf";
                                          //export PDFs as Background Tasks
                                          d.asynchronousExportFile(ExportFormat.PDF_TYPE, new File(name1), false, preset1); //Hi-Res PDF
                                          d.asynchronousExportFile(ExportFormat.PDF_TYPE, new File(name2), false, preset2); //Lo-Res PDF
                                          • 19. Re: Script to Export Multiple PDFs at Once
                                            schuba Level 1
                                            Thank you very much. it is working, you've made my day
                                            • 20. Re: Script to Export Multiple PDFs at Once
                                              shaylag45954664 Level 1
                                              This is freaking fantastic!! I adjusted the code (below) to save out 3 PDFs at once and it works. YAY! What a time saver.
                                              // BS"D
                                              // This script will export 3 pdfs of the current document
                                              preset1 = app.pdfExportPresets.itemByName("PRINT");
                                              preset2 = app.pdfExportPresets.itemByName("PRESS");
                                              preset3 = app.pdfExportPresets.itemByName("[Smallest File Size]");
                                              exit();
                                              if (d.saved){
                                              else{
                                              name1 = thePath+"_PRINT.pdf";
                                              // Here you can set the suffix at the end of the name
                                              name2 = thePath+"_PRESS.pdf";
                                              name3 = thePath+"_DIGITAL.pdf";
                                              d.exportFile(ExportFormat.PDF_TYPE, new File(name3), false, preset3);
