1120: Access of undefined properties button2
Dec 05, 2018 Dec 05, 2018
Hello,
I'm hoping for some insight into an issue I am having. I am trying to create a series of buttons, one that sends you to another frame, that has a new button, which then sends you to a third frame. When I say buttons, in reality I am just using AS3 event handlers on movie clip symbols, so they act like buttons.
When I just have a handler for the first button with the code, and run the file, it works without fail.
button1.addEventListener(MouseEvent.CLICK, fl_ClickToGoToAndPlayFromFrame_2);
function fl_ClickToGoToAndPlayFromFrame_2(event:MouseEvent):void
gotoAndPlay(62);
But if I add a second movie Clip with a different instance name, and add the action
button2.addEventListener(MouseEvent.CLICK, fl_ClickToGoToAndPlayFromFrame_3);
function fl_ClickToGoToAndPlayFromFrame_3(event:MouseEvent):void
gotoAndPlay(82);
I get the error on runtime "1120: Access of undefined properties button2".
I'm not sure when when I effectively duplicate the frames, change the instance name and function name, this does not run. Any insight would be wonderful.
Thank you!
21.0K
Community Expert , Dec 06, 2018 Dec 06, 2018
disable advanced layers (or learn how their use changes the code you need to use), modify>document>untick 'advanced layers'
Thank you! As someone who is very new to Animate and just learning using lynda videos I would have never known to have done that. It seems to have been the fix I am looking for. Now, to read up on it
you're welcome.  and here's info about advanced layer, Create timeline layers with Animate CC
Oct 06, 2020 Oct 06, 2020
Turning off advanced layers works to solve this problem for me, but then animations involving the camera are removed, does anyone know a way to fix the "1120: Access of undefined properties" problem, whilst still being able to use a camera layer?
Aug 26, 2021 Aug 26, 2021
i think this has been fixed and there's now no longer a need to reference the layer in either html5/canvas or as3 documents.  ie, your 1120 error is a user error, and not because of any special needs caused by using smart layers/virtual camera
Participant ,
Apr 10, 2023 Apr 10, 2023
Are you saying that now, after a fix, smart layers are not the cause of the 1120 error, (though disabling it removes the error). Is there an explanation of what causes a 1120 error when smart layers are enabled?
maybe your animate version
Participant ,
Apr 11, 2023 Apr 11, 2023
I am on the most current CC version of Animate, (23.0.1). We you pointing out that there is a way to keep smart layers enabled, and have more than one AS3 button? While subsequent buttons work when smart layers are disabled, there are frequent warnings about it being disabled. Is there a better way to define multiple AS3 buttons than with the function call examples that christophern6788262 listed, which are also provided in the Code snippets interface?
Participant ,
The link you provided at the top, advanced layers, does give an example of how to implement buttons with advanced layers. It shows an example for a movie clip, rather than a button though, Would Button would replace each instance of MovieClip:
Var Layer:MovieClip =MovieClip(getchildbyname("L1"));
Layer.getchildbyname("symbol1");
buttons, movieclips, graphics - it doesn't matter as long as it's a symbol that can be assigned an instance name.
and using advanced layers in animate v23.0.1 doesn't require a special reference when i test.
tick permit debugging in your publish settings and test with advanced layers enabled. what's the full error message?
Nov 28, 2021 Nov 28, 2021
heaven sent. been tinkering and wondering what's wrong for hours. who knows it was just as simple as this!
Jun 06, 2022 Jun 06, 2022
Thank you so much for this 🤩🤩🤩 now im able to make my game project at school. This was the only problem that's stopping me from doing it soo.... thank u very much 😁😁😁
you're welcome.
Check out this tutorial on buttons.
see if this helps.
Actions on buttons in Adobe Animate - YouTube
Thanks! I definitely will check that video out
Every time I see a thread like this, I can't help but think that Adobe profoundly screwed up their implementation of advanced layers if simply turning them on breaks even the simplest code. Just moving a symbol from one layer to another can break a functioning script as well. There had to have been a better way to implement this.
The fact that the 2019 update now enables advanced layers by default is the cherry on top of the disaster sundae. It's like Adobe is trying to stop people from using the last decade or so of example AS3 code.
I concur! I was thinking the same thing.
Engaged ,
I concur with resdesign concurring with Clay. A bit of a mess. Have it turned off by default at the very least.
lol.  i can't even get a movieclip to play when it's added to the main timeline when 'advanced layers' is enabled unless main timeline frames are added (like graphics require).
and the code to reference an object (mc_child) in a movieclip (mc) is a bit over-the-top:
MovieClip(MovieClip(getChildByName('layer containing mc)).mc.getChildByName('layer containing mc_child')).mc_child
and to think this used to be, mc.mc_child
Feb 09, 2019 Feb 09, 2019
This 2019 update has caused me BOAT LOADS of stress and confusion.  The way I've created presentations at work for the past 5 years suddenly stopped working.  I wasted so much time at work this week trying to figure out why my simple goto and stop actions were creating errors.
TURN OFF ADVANCED LAYERS BY DEFAULT ADOBE!
adobe allows you to do just that.
