So I checked all of my footage on the timeline and it shows that everything is 1920 X 1080. I get to the export screen and I see this (See picture). Why is that? Someone help.
That is reporting the Sequence settings, not your footage settings. Select your Sequence tab in the Timeline panel, then go to Sequence menu > Sequence Settings. This will show you what your Sequence is set to and can be modified.
The 1920x1080 might be due to a preset your selected. If you want to export to 1440x1080, 1.333 PAR, then change those settings in the Export Settings (or you can click the Match Source button)
