I am returning to old projects and of course, the file path is disrupted.
The problem is, even when i locate the proper files, PPro will not
"grab" onto them. The old project will not move the file path in
that search window.
top shows old path and new, correct.
Bottom shows NO files to pin "locate file" to
but the files ARE there.
Thanks anyone
PPRO 13.0.1 B13
You need to open the KnifeParty and look for the R0010340.avi
If you mean open the project and then link media one by one,
I get the same windows, and no files appear.
What happens if you drag and drop R0010340.avi from a Finder window to the Project tab in Premiere Pro?
While this isn't relinking, it at least tests that the file can be imported into the project "as is" at its current location on your storage media.
file not supported
well obviously it used to be.
now what?
I’d look in to converting it to a more current format.
Your screenshot only shows the left side of the Locate dialog box.
What, if anything, is displayed in the right side?
Also, what is "File types displayed" in the upper right of the Locate dialog box set to?
Please try importing the avi in to Premiere And see if it works. It may not be compatible with the newer Adobe apps.
Ah, good one: avi on mac needs QT....
