SOLVED
Is there any OOTB show/hide functionality on AEM 6.4 for Coral-3 .?
Avatar
Level 5
Level 5
Hi Team,
I there any OOTB functionality for the dialog show/hide(toggle) behavior for Coral 3 dialog,
After usage of dialog converter for AEM 6.4 the below blog related component show/hide (toggle) behavior for the Touch UI dialog got broken.
Adobe Experience Manager Help | Dynamically modifying an Adobe Experience Manager Touch UI Dialog
1 Accepted Solution
Avatar
Correct answer by
Community Advisor
This is broken because you might be using coral3 instead coral2 resources. In Coarl3 class and data attribute values are created differently as shown in vipins5188​ reply. You need to update node with granite:class and granite:data nodes to make it work with Coral3
Arun Patidar
Avatar
Level 3
Yes there is OOTB show hide feature available which used target value concept.
Please refer below link for detailed implementation
https://techrevel.blog/tag/showhide/
Hope this helps
Avatar
Correct answer by
Community Advisor
Arun Patidar
