6 Replies Latest reply on Dec 7, 2018 7:07 AM by SergioMatos
    Extract Alt-Texts
    nadine wohlfahrt Level 1
      Hi everyone,
      extracting Alt-Texts directly out of the Indesign-document would be great.
      here is my exact Problem right now:
      I have an older document, with about 200 pictures with Alt-Texts.
      The Alt-Texts are unfortunately entered per hand with the Object-Export-Options in indesign, not in the Picture information itself.
      Now we need only the Alt-Texts somehow extracted in a single Text-File or if possible a thumbnail of the pic with its Alt-Text beneath it.
      Has anybody a solution for this Problem yet?
      I would appreciate a good workflow or workaround without klicking every picture by hand and copy and paste the Text.
      Thank you very much in advance
      Nadine
        • 1. Re: Extract Alt-Texts
          oleh.melnyk Level 3
          So, basically you need to get the plain text out of InDesign, right?
          How about this workflow: export to PDF file, then open PDF in Adobe Acrobat and resave as plain text
          Alternatively, you should be able to open PDF file in Microsoft Word
          • 2. Re: Extract Alt-Texts
            This brings me just all the plain texts, and not the extracted ALT-texts from the images to the text document.
            Even if it also would extract the alt-texts (but I didn’t see any of them in my first try – did I do something wrong?) I would have to copy and paste the 200 snippets of alt-text out of that document, right?  – It would still be a first solution of the problem, of course.
            • 3. Re: Extract Alt-Texts
              oleh.melnyk Level 3
              Sorry, I probably misunderstood what alt-text is - I thought that was image captions
              Can you clarify what you mean by "extracting alt-texts"? Maybe some screenshots?
              UPD
              Oh, now I understand what is alt texts... what you need probably can be done with custom InDesign script
              • 4. Re: Extract Alt-Texts
                oleh.melnyk Level 3
                OK, try this script:
                Dropbox - ExportAltText.jsx
                https://indesignsecrets.com/how-to-install-scripts-in-indesign.php
                So, basically, all you need is to open your InDesign document, then "open" (double-click) on my script.
                It will go through all images in the document and get all Alt Text, then save them to the desktop txt file in the format:
                IMAGE_NAME
                ALT_TEXT
                IMAGE_NAME
                ALT_TEXT
                • 5. Re: Extract Alt-Texts
                  Wow, this seems to work!
                  I tested it only on a small file yet, and will try the bigger one in the next days, because I’m not on my workstation right now.
                  Thank you very much for this script – you are a lifesaver!
                  Best regards, happily,
                  Nadine
                  • 6. Re: Extract Alt-Texts
                    SergioMatos Level 1
                    Hello,
                    This might not be possible but with the Export Alt Text Script above, can this be then reversed after?
                    After an Export, if I needed to change any of the alt text in the AltText.txt file then import it back to Indesign?
                    AltText-Export.jsx
                    //DESCRIPTION: This script will export all all text into single txt document on your desktop.
                    #target indesign
                    var images = app.activeDocument.allGraphics; // .itemLink.name
                    var altTextFilePath = "~/Desktop/AltText.txt";
                    var file = new File(altTextFilePath);
                    file.open('w');
                    for(var i=0; i < images.length; i++){
                        file.write(  images[i].itemLink.name + "\n" + images[i].parent.objectExportOptions.customAltText + "\n\n" );
                    file.close();
                    alert('You can find "AltText.txt" file on your desktop', "Done");
