I imported my design into Illustrator to vectorize it. My challenge is, my letters overlap and I can't work on them individually. Ungrouping them the standard way won't work because they were designed together as is.
Do you have any suggestions?
Thank you!
Adobe Capture makes shapes of everything. And of course all the shapes are connected.
You really only want to color the insides of the letters?
In that case just leave the trace as it is and then use the live paint feature to fill the letters.
Make sure to activate the gap detection in Object > Live Paint > Gap detection.
How to create and work with Live Paint groups in Illustrator
You will need to cut this in order to break them apart.
First Expand the Image trace, then use the obvious tools
https://helpx.adobe.com/illustrator/using/adjust-path-segments.html
Expand is unavailable when I have the shape selected. Any thoughts?
Then you can edit right away
Yes, but my letter shapes are still connected and I can't edit them individually. I must be missing something.
Did you read the link I posted?
You will need to cout paths and re-connect other paths in order to edit this.
What do you want to do? Colorize them?
I did read it. I'll need to slow down and read more carefully again. And yes, I'd like to color the letters and add gradients where they overlap, etc.
Thank you, Monika. I'll definitely re-read the article you sent.
This is a raster image that you want to trace, am i understanding correctly?
An image trace will produce artwork with the same overlap, so you will not have much room for edits.
However, if you trace with the pen tool, you can draw the letters complete, on seperate layers giving you more options
It originated as an inked drawing and I imported it with Capture to vectorize it. I applied an Image Trace to it already. Does that mean I'm left using the pen tool?
I wanted to add color, but at this point it will obviously fill more than one area.
In that case, making it a Live Paint object may work for adding color, but I have limited experience with that function.... anyone?
My pre- LivePaint coloring method:
Expand the object to turn any lines to shapes ( I believe this is where you're at)
Select this lineart and use "Unite" ( makes it one peice)
Draw a filled box around the artwork, filled with any color but black or white
Send this box behind the artwork ( Object > Arrange > Send to back )
Select everything, and use the Merge command in the Pathfinder
Now you can use the direct select tool to select the colored fill areas and change their color as you please. ( as well as selecting the outside filled area and delete it)
* Edit, forgot the third step
I'll check that out Scooter. Thanks!
I copied your image into illustrator from the post above
applied image trace
expanded lines and fills
was able to select individual letters and color as needed. (see results at bottom)
*You might want to start with just the scan/jpg to image trace. Your nodes in screenshot above seem to show that only the outer lines of the letters were traced. See yellow area below.
-Dax
True, after live image trace Make+Expand you can select the filled areas with the direct select tool and edit them ( the fills will be white)
Cool Dax! I have to step away for a bit, but I’ll check out your suggestion.
Thank you!
I'm still not figuring this thing out. The image was vectorized with Capture, I've tried using "cut path" and I still can't edit one portion at a time.
I can't even do what @maxwithdax did above!
I still have the same issue as seen in the pic. Bummer!
Check out this video I threw together regarding your image. It should shed some light on what you might be missing and a few things you can do to clean it up. As always, there are 10 different ways to do anything in Adobe programs, so the way I did it in this video is just one way. But at least it should point you in the right direction.
How to Image trace a simple logo - YouTube
- Dax
Super! Thank you very much @maxwithdax! I appreciate you helping me out with the great video. I'll dive in shortly and get to work!
Im not sure what your desired end result is-
If you just want to add/edit colors in the piece than all of the above methods will work. If you are trying to move the individual letters around independently, you will probably be better off tracing the art with the pen tool. It is possible to cut all these paths apart and try and fill in the gaps, but IMO it would be more time efficient to pen tool out the letters. (Just the outlines of the letters, the linework and flourishes can be easily salvaged)
Thank you ScooterD76​! That definitely could be an option.
