Using typographer's quotes and straight quotes in the same block of text
Dec 07, 2018 Dec 07, 2018
I would like to be able to use both straight and "curly" quotes within the same sentence or paragraph without having to go into the app preferences change it, type the text, go in and change it again, etc.
Typical example of a sentence I would need to do this for:
The IRT's platforms are 510' long, and each car is 51'5".
Can I create a character style that forces straight quotes when the default setting is typographer's quotes? I would say I need straight quotes maybe 5% of the time (if that), but when I need them, creating them is a royal pain. Even copying-pasting doesn't work as the pasted versions are curly.
Thanks in advance.
10.4K
Community Expert , Dec 08, 2018 Dec 08, 2018
Letting us know the version is important.
Those are the shortcuts for current versions:
but they are not listed for CS6. You can use the Type menu in CS6 or define the shortcuts via Edit > Keyboard Shortcuts.
~Barb
Set your preferences to default to curly quotes. When you need a straight quote, press Ctrl+[ and Ctrl+] for straight single quotes and Shift+Ctrl+[ and Shift+Ctrl+] for straight double quotes (or the Mac equivalents of those keys). You can review/change these keys in the keyboard shortcut editor.
Unfortunately this does not seem to work for me (holding down the control key and the left square-bracket simultaneously, or control and right square-bracket, or control, shift, etc). None of those combinations work using ID CS6 on a PC running Windows 10.
~Barb
Well that's even easier, and it works like a charm. Thanks, Barb!
Dec 09, 2018 Dec 09, 2018
Mixed up my straight and curlies there!
Participant ,
Jan 05, 2023 Jan 05, 2023
I tried using your keyboard combination, but no luck. Just an FYI. But since Illustrator and so easy to manually add this "special character" of the elusive single or double uncharactertistic vertical line known as the "foot mark" and "inch mark".
Participant ,
Oops. Now we're back to the drawing board and no straight quotes (single or double), and running latest version 27.1.1.
Hi @KansasSteve:
This is the InDesign forum. This 2018 was addressing quotes in InDesign, not Illustrator.
~Barb
Participant ,
Goodness. I'm so sorry. I was in the Illustrator forum, and searched and searched within it. Finally found "inch and marks", but didn't realize I was in a different forum at that point.
Insert the specific character using alt codes, or a macro/key programmed to enter them if you have the capability and the often-enough need.
I keep a chart of Alt Code characters handy, and it's often much faster than burrowing down three or four levels of a never-quite-remembered Insert menu. 🙂
Under Windows, Alt-34 inserts a straight double quote — " — and Alt-39 inserts a straight single quote/apostrophe — ' . Not sure of Mac equivalents.
ETA after Barb's correction: "...in pretty much all apps."
â•Ÿ Word & InDesign to Kindle & EPUB: a Guide to Pro Results (Amazon) â•¢
Feb 09, 2024 Feb 09, 2024
I can't believe 5 years later there isn't a clean solution to this. I wish you could set the preference for typographer's quotes by paragraph or character style!! Is there an official way of requesting things like this?
Quotes follow the used language. I use text in English or German, and it will use the correct quotes for each language. For everithing without a language like formulas, I use "no language". When a text has no language (applied via Paragraph or Character Style) sreight quotes are used automatically. That is correct and in m,y opinion this is the solution.
Feb 13, 2024 Feb 13, 2024
thank you! Is this automatic or is there a way to set the style of quotes for that specific language?
