클립보드로 링크 복사
복사됨
어도비cs6 cd로 설치하려 합니다.
그런데 set-up파일을 누르면 설치프로그램에서 초기화를 실패하였습니다.라고 하는데
왜 그런가요?
When you ask a question you need to provide some basic information
-Forum quick start https://forums.adobe.com/docs/DOC-5601
Mac or Windows, and EXACTLY which version of the operating system?
Recent Mac AND Windows operating systems have been known to cause "odd" problems
Are you using a computer Administrator account with full read/write permission?
You do not specify Mac or Windows, so notes for both
Mac
CS6 and earlier programs HAVE NOT BEEN TESTED AND WILL NOT BE UPDATED for Mac El Capitan or newer
...클립보드로 링크 복사
복사됨
Mac
CS6 and earlier programs HAVE NOT BEEN TESTED AND WILL NOT BE UPDATED for Mac El Capitan or newer operating systems
-which means that you try to use CS6 and earlier at YOUR risk of having problems due to Apple updates
-Apple did not maintain backward compatibility with old programs in El Capitan or newer operating systems
--Adobe has a workaround to Apple's problem of not maintaining backward compatibility
--READ HERE https://forums.adobe.com/thread/2301916 for an Adobe solution to installing old programs, including a link to installing the old Java runtime that is required
--Also read for more information https://forums.adobe.com/thread/2458382
--and https://helpx.adobe.com/x-productkb/global/install-or-run-applications-new.html
--and https://www.macworld.co.uk/how-to/mac-software/open-apps-wont-work-mojave-photoshop-3684425/
Windows
Two ideas that MAY work to install and/or run old programs in Windows 10
-RIGHT click the program icon or EXE and select a compatibility mode in the pop up option window
-or Run as Administrator http://forums.adobe.com/thread/969395 to assign FULL Windows permissions may help... this says Encore, but is sometimes required for ALL Adobe programs (this is NOT the same as using an Administrator account) so follow the instructions, substituting the name and location of your specific program for Encore
-also https://helpx.adobe.com/x-productkb/global/create-local-administrator-account-windows.html
클립보드로 링크 복사
복사됨
Moving this query to Downloading, Installing, Setting Up community.
