I recently updated from Lightroom Classic CC 7.5 to Lightroom Classic 8.0, in both versions for some months now I have been unable to import photos using the "Import Photos and Videos . . ." option on the file menu. When I open that, it goes to the card or file folder I have specified, but it doesn't find any images there. How do I fix it.
I have been using an auto-import folder as a work-around and that works. But I would like to be able to go back to doing it directly.
I'm running Lightroom on Windows 10 Pro, version 1809.
Thanks.
Is the Destination Panel expanded and pointing to an actual folder that exists?
Please share a screen shot of your import windows, the entire window, both sides, top and bottom, with the SD card in
Sure! Here is a screen shot after I put the card in:
What happens if you expand the Destination panel on the right side of the Import dialog box? Is it pointing to a folder that actually exists?
Hi. Sorry I've been off line for a few days.
If I point to a folder that exists and has pictures, it doesn't find images regardless of whether the folder is on an SD card or a hard drive.
Example looking at a C drive folder
Lightroom import function:
Actual folder in the file browser:
Example looking at SD Card:
And the file explorer window:
You have to troubleshoot this step by step:
1: Reset the preferences. Corrupted preferences can cause all kind of strange behavior, and Lr7.5 and Lr8 share the same preference file. https://www.lightroomqueen.com/how-do-i-reset-lightrooms-preferences/
2: If that does not work, check that this is not catalog corruption. Create a brand new catalog and try with that one.
3: If that does not work either, uninstall and reinstall Lightroom.
This may sound crazy, but it has worked for people in the past
- Click on COPY. (Yes, I know you want to do an ADD, but click on COPY anyway)
- Expand the Destination Panel on the right. If the Destination Panel is not present, then right-click on File Handling and select Destination from the dropdown menu that appears)
- Click back on ADD
His second screenshot (the one with the SD card) already shows that copy doesn’t work either.
It doesn't show the destination expanded and set, which is where the problem lies. The fix for this weird behavior that sometimes works is to expand and set a destination and then simply switch back to add.
- Click back on ADD
The second screen shot does not show the Destanation panel expanded and properly pointing to a folder that exists.
On second screen, SD card, uncheck Dont import suspected duplicates. Mind you if that was the issue why does the first screen not work.
Also in the SD card copy attempt, go back and top left, go thru the steps to select a destination, make sure it will navigate into your hard drive directory structure. Maybe pick a different location (diagnostic step)
Based on what is highlighted in your shot, you are looking in the wrong place.
Followup. Looks like I am wrong on my above.
Inquiry: does being selective on when you place your SD card into the reader affect what LR presents you?
In other words
If the SD card is in before u=you start LR, does it fail.
Or, if the SD card is in after you start LR but before you try an import?
Or if you place the SD card in after you try the import?
Three possible workflows around inserting the SD card and running LR and trying the import.
I was going to suggest exactly what dj just suggested. There is a weird bug that sometimes (not always) makes images not show up if the destination is not set or set to a nonexistent location even when not using copy or move. Don't know if that's it but would be first suggestion. It can also be that these images simply already exist in your catalog but you probably checked that.
Just in case, some info might be usefully, or at least will eliminate possibility of a odd little quirk.
In LR click on help, click on system information, click on copy, paste that into a reply (down to just after plugins, rest of that is for Adobe Nerds)
