I have already trimmed & arranged some clips in the timeline.
And next, I want it to "automate to sequence".
But after I select & drag those clips from timeline to out in the new bin, its order get misplaced.
It does not match with the order from the timeline.
How to drag several clips from timeline to bin with timeline clip order?
So I can do "automate to sequnce" later.
OR
Is it possible to do "automate to sequence" directly on the timeline?
There is no such option.
You will have to order them manually.
When you have 1000+ videos, it's so difficult to order them manually in a bin. That's why I arranged in a timeline.
So I could drag those clips to new bin and use "automate to sequence" on unnumbered markers later.
But...they're already in the sequence.
Yes. But I don't want that bin order. I want it exactly same as the new order that I've arranged on the timeline.
For instance, suppose
Bin order is - 01, 02, 03, 04, 05
when we drag it to timeline we get an order like 01, 02, 03, 04, 05. I don't want like this.
So I rearranged those clips in order 04, 05, 02, 03, 01.
Next, I want to arrange a new order on music's beat.
So I have to manually do it or I can use "automate to sequence".
But we can't do directly on the timeline.
But we can do this - create a new bin, add clips and then do automation.
But after dragging those clips in the new bin, its order get misplaced.
So this is my problem. I just want same order as on timeline. To do further work.
samtor wrote
I want it exactly same as the new order that I've arranged on the timeline....
In these parts pilgrim, that's what we call editing...
So, you already have the timeline in the order you want, now wouldn't you just clean up the timing of those clips?
You seem to be going 'round 'n 'round.
What's wrong with the sequence you have, just adjust the clips now for the timing you need. Otherwise get a sorting software, rename the clips in the order you want them, then you can import and then Automate to Sequence.
If you have your sequence markers all set in a different sequence, you can copy them over to the timeline you have your trimmed clips in.
Their nothing wrong with the sequence. Just I want to edit faster.
Getting a sorting software, No.
It is simple problem. Why Pr cant store clips in a bin by user order, Order which sorted on a timeline.
And it could be better if - "automate to sequence" option available for timeline window.
That is working backwards.
Select the clips on the timeline. Right click on any one of the selected clips and from the drop down menu choose Make Subsequence.
If you want to edit that subsequence into another sequence, you can either do so as a single unit (one clip will appear in the destination timeline that will contain all the clips in the subsequence, or you can edit the subsequence into another sequence as the separate clips contained in the subsequence - depending on the toggle status of this button:
MtD
That is correct. That's what editing is.
I notice no useful reply so far. Did you find a solution by the way? I am looking for same answer
Well just after asking back this question, i found "One Answer", may be there could be more methods.
Answer is:
1. in your bin first select icon view
2. Now select and drag you clips from timeline to this bin
3. Order will be same as in timeline
