Whenever I export my project, premiere pro crashes as it renders audio files, help?
Try resetting the preferences:
FAQ: How to reset preferences in Premiere Pro?
If that doesn't work, try resetting the Workspaces:
Reset a workspace
Reset the current workspace to return to its original, saved layout of panels.
- Do one of the following:
- Click the Workspace menu icon and select Reset to Saved Layout.
- Choose Window > Workspace > Reset to Saved Layout.
from here:
https://helpx.adobe.com/premiere-pro/using/workspaces.html
If that doesn’t work,,try updating or rolling back your graphics driver directly from the video card manufacturer’s site.
If it still doesn't work:
FAQ: What information should I provide when asking a question on this forum?
None of the things above worked. I'm using premiere pro 13.0.02. I'm using windows 10, version 1803. One camera was recorded in mp4 but I cant find what the other camera was recorded in. But they are being exported to h.264. My computer specs are a Ryzen 5 1400 cpu, a rx 570 graphics card and 8 gbs of ram.
Heres a quick video I posted of the problem
[edit video to show in forum ussnorway]
My first thought is to check Step 4D below.
Thanks for the help but I turned out to be corrupted clip, but its weird that I could still edit it. But Thanks for taking the time to try and help me.
You need only post once. Everyone can see it.
EthanH,
Try transcoding the footage some test clips and report back with the results.
Kevin
