Hi, I've been trying to post my Flash/Animate extension to Adobe Exchange, but when I upload the .zxp I get the following error.
"Ensure the XML in your MXI file or CEP manifest file is well-formed."
Here are the contents of my MXI file, what can I do to get rid of this error?
<?xml version="1.0" encoding="utf-8" standalone="no"?>
<macromedia-extension
name="Boiler"
version="1.6.0"
id="com.megacharlie.boiler"
mxiversion="5.0"
requires-restart="true">
<author name="Megacharlie159" />
<products>
<product
familyname="Flash"
version="12"
primary="true"
required="true" />
</products>
<update />
<description>
<![CDATA[
Easily add boiling to your animations with Boiler!
Huge thanks to @slurpbert for the website and suggestions,
and thanks to @KenaleBros for finding some really bad buges I just fixed.
</description>
<ui-access>
<![CDATA[
New version: 1.6.0
You can now simply select all your frames and boiler will boil whatever drawings were on those frames!
To add Boiler to your workflow, go to Window/Other Panels/Boiler. I would suggest using about 20 for your brush smoothing while drawing. Boiler will only work with vector shapes, for example: Drawings, outlines, and traced bitmaps.
Huge thanks to @slurpbert for making the website for Boiler, and helping me figure out how to make this the best possible thing it could be!
</ui-access>
<license-agreement>
<![CDATA[
<b>My license</b>
</license-agreement>
<files>
<file source="Boiler.swf" destination="$flash/WindowSWF" file-type="ordinary" />
<file source="boil_multi.jsfl" destination="$flash/WindowSWF" file-type="ordinary" />
<file source="boil_single.jsfl" destination="$flash/WindowSWF" file-type="ordinary" />
<file source="interfacecolor.txt" destination="$flash/WindowSWF" file-type="ordinary" />
<file source="getcolor.jsfl" destination="$flash/WindowSWF" file-type="ordinary" />
</files>
</macromedia-extension>
Hi megacharlie159​,
That kind of error sounds particularly frustrating.
Have you had a look at our new guide's section on writing the manifest file? Also check out the related section of the CEP Cookbook.
Let me know if this helps!
Hi megacharlie159​,
