Under the recent download a software Adobe Effects CC(2017), but how can not start the software, has been showing the picture of the problem, there are deeted after the re-download, so I would like to ask how to do, Thank you !
在下近日下載了Adobe Effects CC(2017),可是卻怎麼也無法啟動該軟件,一直都是現實圖片中的文字,也有刪除重新下載,可一樣還是如此,所以借此想詢問一下我該問麼做,謝謝。
Adobe After Effects supports Simplified Chinese.
Change the language settings of your computer to Simplified Chinese, and then launch the application.
For more information please check this: Known issues in After Effects CC 2017
Kulpreet Singh
Have you followed the directions in the message? You must ensure your OS, browser, and software download are set to Chinese Simplified.
教學影片都是英文影片裡的選項也是英,何必硬性規定使用者的系統一定要簡体中文才能啟動?根本是在搞政治問題或打壓使用繁體中文的國家。
Kulpreet Singh
我並不是特別在乎簡體中文跟繁體中文
問題是官方今天收了錢,這種有問題不修丟在一邊的態度很不可取。
Hi kulpreet, I believe that the best solution for the traditional Chinese user is to download the English version of After Effect directly if Adobe team are not going to develop current language into traditional Chinese. And I think in normal workflow/ process no one would happy to see changing different OS system language every time just for one software that is very disturb. Thanks for understanding.
This is no helping.
Traditional chinese is our daily language, and is clearly different to simplify chinese. Although they both called chinese, the character and the translation are greatly different.
Making traditional chinese user to change the entire os language to simplify chinese is a ridiculous and rather rude reply.
Hope you can reconsider your advise.
無法認同你更多,為了一個軟體竟然要改變我整個系統語言,簡直荒謬至極。
AE still has this bug,come on man !!
很顯然他們根本沒有回答到問題,是Adobe他們軟體設定的問題。
我們的電腦就是繁體中文,為什麼要突然改變OS成簡體中文?
I met the same problem. I have modified the computer system to Simplified Chinese, but still can not start.
我也是這樣,已經都修改OS簡體並重新下載,還是無法開啟,甚至也將 Creative Cloud 偏好設定改為簡體中文,或是改為英文,都一樣顯示同樣Licensing Error,快瘋掉!剛剛在線上問adobe客服,他還是無法幫我解決,試用都不行,怎麼敢買...
我自己試的方法是
1.先移除現有的AE (我是用Mac,用adobe的uninstall)
2.更改CC(creative cloud)偏好設定成英文
3.再下載一次AE(應該是英文版的)
之後開啟AE都不要透過CC,用launchpad來開,就沒有問題了,你可以試試看。
*我真的不知道Adobe是在回答什麼! 花了錢還要受氣!
這個方法可行, 成功了!
我有試了,只是下載的是英文版的AE,可以開啟,但仍無法下載中文(簡體)版的AE
用launchpad,不懂這意思什麼?
這是Mac才有的功能,PC應該使用程式集去開啟。
真的只能在「偏好設定」改為English,才能下載後,「正常」運作~~前提也是…在「程式集」開啟==!!!
我的電腦是WIN10,剛將「creative cloud」偏好設定改為「簡体中文」,雖然也是可以正常下載,但是~就是一直跳出license error的問題。後來又去改電腦語言,裝來裝去都不行~~真是…搞什麼鬼~
到底這軟体啥時才會出個…繁体中文版呀~~
對 覺得很奇怪 ,為什麼為了一個軟體要把全部電腦系統變成簡中!!火
無言,用個程式還要受限於語言
那乾脆直接限制繁體中文使用者
只能下載英文版不就好了
還要切換電腦語言版本根本擾民
而且他們根本不打算解決這個問題,都過多久了?
不太了解為什麼願意做簡體中文,不做繁體中文?
繁中使用者的月費有比較便宜嗎?
根本沒解決!!!
WTF~
Adobe 根本在鬼打牆!
就繁體中文用戶硬要我們用簡體是怎樣?!
2020年的五月底,在我付費完後發現居然有這問題,PC有找到解決方法影片,但我才剛換了MAC........要我把AE丟在旁邊無解的意思?
我PS也遇到一樣的問題 但AI凡中卻沒問題~我認真不解
Illustrator and After Effects are TWO DIFFERENT PROGRAMS. They weren't even developed by the same company. Software developers don't change their code unless they have to. So to assume that both programs are now both owned by Adobe means nothing. Adobe has done nothing to make the two applications work perfectly together.
If you assume Adobe has done so, you are foolish.
從四月發現問題到現在,反映了也沒用,他們更新了兩個版本也沒見到要修正的意願,我建議還是安裝舊版2017.0的來使用就可以了(比較納悶的是以前的版本都可以用,為何這幾次的更新都沒辦法在繁體中文的系統下使用,擺明要壟斷繁體中文系統的市場),先撇開介面文字的問題,重要的是要能在任何語系的系統下執行才是最基本的吧!
