I tried to export as a jpeg 60x80 inch and it didn't work at 300 dpi. I shrunk it to 15x20 but I'm worried it will pixelate when printed 60x80. The adobe illustrator information I read said u could make something as big as a billboard, so what do I need to do?
Why do you export a JPEG for printing? Won't PDF work?
Thank u but under file / export as I can't find Pdf. do u make pdfs a different way?
Go to File > Save As… or Save a Copy… . Near the bottom of the window is a Format menu, where you may select Adobe PDF. Click Save, and the following window allows you to set PDF options.
Its a photo blanket at walmart and they only take jpeg. I tried pdf, png, and tif and they wont allow it. I can't figure out how to make jpegs more than 300 dpi and my file is 15 x 20 inch with the end print size 60 x 80 inch. What should I do?
Open your AI file in Photoshop and let Photoshop rasterize it to the desird size.
But for a blanket (= printed on fabric) 300 ppi would be overkill most probably anyway.
I dont have photoshop so I settled for a 60x80 jpg at 225 dpi. Now I'm trying to enlarge this file from 20x20 inch to 80x80 inch for the second photo blanket. I created a 80x80 inch file and placed the smaller jpg into it. But now when I hold shift and pull the corner it doesn't stretch the image like I can always do. Instead it moves the entire artboard around. Here's a pic. How do I stretch the image to fill the artboard?
It appears you have the Artboard Tool active. Try the Scale tool (keyboard shortcut is the “S” key).
I can't imagine anyone would use JPEG for such a large print format, except in very special cases (such as a pure photograph with no text or design additions, which you wouldn't use Illustrator for anyway).
Export it at 1/4 the size but 4 times the resolution since Illustrator has limited size.
Example 15 X 20 at 1200dpi.
If it doesn't work try the TIFF format with LZW compression.
Then resize without resampling in Photoshop to it's intended size.
No.
If you really think you need a raster format, then let Photoshop open your PDF (or the AI file saved with PDF compatibility) and raster it. Photoshop can do higher resolutions.
There is no need to use 300ppi at 100% in grand format. The file should be scaled down, yes, but use a raster document setting of 300ppi ( High ) at 15 x 20. Then convert to PDF. Tell the billboard company to enlarge the PDF 400% in the RIP.
We print everything as eps, pdf, or tiff
max 150dpi for tifs and that's at full scale. Sometimes as low as 50dpi . example 60 x 80 = approx 316MB
Rules of thumb
1. all vector AND no gradients = eps or pdf print
2. all vector WITH gradients = pdf print or tif
3. mix of raster and vector = rgb tiff
4. 3rd party files that will not come in properly go right to photoshop and saved out as rgb tif.
