Adobe premiere elements; Error (Code = 146)
Jan 10, 2019 Jan 10, 2019
I work with Windows 10 and am trying to install premiere elements.
It doesn't work because I have the message:
"FATAL: Error (Code = 146) executing in command 'MoveFileCommand' for package: 'AdobeCameraRawProfile8.0All', version:11.1.0.79
FATAL: Error occurred in install of package (Name: AdobeCameraRawProfile8.0All Version: 11.1.0.79). Error code: '146'
WARN: Unable to move file at "G:\adobeTemp\ETR4C6.tmp\4\SharedApplicationData\Adobe\CameraRaw\CameraProfiles\Adobe Standard\Canon EOS 10D Adobe Standard.dcp" to "C:\ProgramData\Adobe\CameraRaw\CameraProfiles\Adobe Standard\Canon EOS 10D Adobe Standard.dcp" Error 2 Le fichier spécifié est introuvable.. Try setting correct permissions to the specified file/folder or parent folder, so that admin has rights to modify it."
There is no file "G:\adobeTemp\ETR5EC6.tmp\4\SharedApplicationData\Adobe\CameraRaw\CameraProfiles\Adobe Standard\Canon EOS 1100D Adobe Standard.dcp" between Canon EOS 10D Adobe Standard.dcp and Canon EOS 1200D Adobe Standard.dcp.
How to overpass this?
470
Adobe Employee ,
Moving this thread to Downloading, Installing, Setting Up community.
Hi Pierricke9088291,
As you have mentioned you are getting Error code 146 while trying to install Photoshop Elements on your machine.
The following document is for Creative Cloud, however, the same troubleshooting steps will apply here as well to resolve the issue: Resolve Error Code 146 or 147 encountered while installing Adobe Creative Cloud apps.
Let us know if this helps.
I have already look at this issue.
The problem is because I want to  install on a disk (internal) G and not with the default settings.
When I try to install on G, it fails. And it works with the default settings. For me the problem is not resolved. I think that there is a "verrue" (in french) in the installation program to avoid the error code 146 with the default settings. And a big lack of tests for an expensive program.
Adobe Employee ,
Jan 11, 2019 Jan 11, 2019
Thanks for the update. As you have said that it fails when you try to install the apps on a different drive location, could please check and confirm if you are following the steps shared in the following thread to do so: Hardisk full
Share the results with us.
