I have a simple cartoon with about 10 symbols, one animation and one sound file. I test once and it is fine, the second time I test it I receive this error:
"A javascript error occurred."
and in the output box it says:
An unexpected error occurred during export. [JSX]
When I remove the sound file, I can test as many times as I like.
I was able to publish it, it plays in Google chrome, and Edge, but there is no sound on anything from APPLE.
Any Ideas would be of great help.
In the publish settings turn off the Export document as texture feature and every thing works fine File -> Publish -> (Uncheck) Export file as texture.
are you clicking something on your canvas to trigger the sound to start?
I have the same problem. Canvas document. Added sound that extends the full length of the 6 sec. timeline. Did the new auto-sync. Now it won't play sound and I can't test or output to html except for the first time after I open the file (tried this a few times to test it). No button to trigger the sound.
add your sound to a button listener and test.
I found that if I design and test as an action script 3.0 document, since I have no javascript code, I can just convert to HTML5 canvas and publish. I have not tried the button yet but will, thanks for all your help.
you’re welcome.
I found a solution to the problem. If you don't place two of the same symbols on the same layer, for example a pair of eyes, the HTML5 canvas tests fine as many times as you like.
