i tried to make an action :
1...
2...
3. Transform selection with "Dialog", Where i can make selection myself.
4...
5...
Everything seem working fine when i make some change on transform selection. But when there is NO change, the script stopped unintended.
How can i solve this ?
It actually may not be a bug if the transform selection is not changed enter cancels the transforn Selection.
The way I have always coded around this is to always have the transform make a change. What? I simply record the interactive transform selection rotated 180 degrees. The rotated selection is identical the the non rotated selection. If the user hits enter to commit the transform the identical 180 degree selection is committed and the action continues the transform is not canceled. The
...Copy link to clipboard
$.level = 0; try{/*code for transformation*/}catch(err){}
You may also do it without try...catch statement by adding to your transformation code the part that I guess is missing:
dsc = new ActionDescriptor()
dsc.putUnitDouble(stringIDToTypeID('width'), stringIDToTypeID('percentUnit'), 100.000001)
dsc.putUnitDouble(stringIDToTypeID('height'), stringIDToTypeID('percentUnit'), 100.000001)
Note that dsc is the same you use in last line of your code before DialogModes.ALL, so you must change it to proper one.
Hi Kukurykus,
I am new on this so my question is how i can edit those codes?
Actually, i record action and then use File => automate => batch => with action recorded.
Save it as "Transform Selection.jsx" (with Notepad incl. double quotion marks) to 'Presets/Scripts' folder of your Photoshop.
sTT = stringIDToTypeID
ref = new ActionReference(), dsc1 = new ActionDescriptor(), dsc2 = new ActionDescriptor()
ref.putEnumerated(sTT('layer'), sTT('ordinal'), sTT('targetEnum')), dsc1.putReference(sTT('null'), ref)
dsc1.putEnumerated(sTT('freeTransformCenterState'), sTT('quadCenterState'), sTT('QCSAverage'))
dsc2.putUnitDouble(sTT('horizontal'), sTT('pixelsUnit'), 0), dsc2.putUnitDouble(sTT('vertical'), sTT('pixelsUnit'), 0)
dsc1.putUnitDouble(sTT('width'), sTT('percentUnit'), t = 100.000001), dsc1.putUnitDouble(sTT('height'), sTT('percentUnit'), t)
dsc1.putEnumerated(sTT('interfaceIconFrameDimmed'), sTT('interpolationType'), sTT('bicubic'))
dsc1.putObject(sTT('offset'), sTT('offset'), dsc2), executeAction(sTT('transform'), dsc1, DialogModes.ALL)
Then relaunch Ps and instead of 'Transform Selection' step choose from dropdown Action panel menu 'Select Item' and then from 'File / Scripts' choose 'Transform Selection' item. Now this way 'Transform Selection' doesn't have to be made.
This is similar to the bug in many versions of CC (in 2018 there is exactly).
Instead of calling the menu, use the transform command with small parameters, for example, 100.01%
Actually that can be done by sole actions which I don't use from long, but now I remember I had the same problem I solved by recording minimal transformation that did not affect anything when I applied trasnsformation without transofrmation. So yes, it needs only to choose during transformation in upper bar 1/10 higher percent for width and height.
The way I have always coded around this is to always have the transform make a change. What? I simply record the interactive transform selection rotated 180 degrees. The rotated selection is identical the the non rotated selection. If the user hits enter to commit the transform the identical 180 degree selection is committed and the action continues the transform is not canceled. The user must hit ESC to cancel the transform to stop the action. The user can then hit Play to retry doing the 180rotated transform selection again.
Nice workaround!
How to be in this case?
Rotate: 0° + H Skew: 180° … or ... Rotate: 0° + V Skew: 180° ... or ... Rotate: 0° + H Skew: 180° V Skew: 180° ?
In this case, the selection also changes due to the inaccuracy of Photoshop.
He writes something like this into Action.
var d = new ActionDescriptor();
var r = new ActionReference();
r.putProperty(stringIDToTypeID("channel"), stringIDToTypeID("selection"));
d.putReference(stringIDToTypeID("null"), r);
d.putEnumerated(stringIDToTypeID("freeTransformCenterState"), stringIDToTypeID("quadCenterState"), stringIDToTypeID("QCSAverage"));
var d1 = new ActionDescriptor();
d1.putUnitDouble(stringIDToTypeID("horizontal"), stringIDToTypeID("percentUnit"), -2.96059473233375e-15);
d1.putUnitDouble(stringIDToTypeID("vertical"), stringIDToTypeID("percentUnit"), 0);
d.putObject(stringIDToTypeID("offset"), stringIDToTypeID("offset"), d1);
d.putEnumerated(charIDToTypeID("Intr"), stringIDToTypeID("interpolationType"), stringIDToTypeID("bicubic"));
executeAction(stringIDToTypeID("transform"), d, DialogModes.NO);
This is equivalent to the minimal transformation. But also does not always work on CC.
If the selection is not semertric I would create the pototype selection off a bit and rotate it a small amount in the interactive transform selection step. However I have only use this in aspect ratio cropping and framing actions. My selections were always rectangular.
It was never a problem for me in a script I only needed a work around in Actions.
try{
//doAction("Interactive Transform", "Actions for Scripts"); // Let the user have the final word
InteractiveTransform()
catch(e){alert("Image Transform Canceled");}
try{
//doAction("Interactive Transform", "Actions for Scripts"); // Let user have last say
catch(e){}
//==================== Interactive Transform ==============
function InteractiveTransform() {
// Menu Edit>Free transform
var desc1 = new ActionDescriptor();
var ref1 = new ActionReference();
ref1.putEnumerated(cTID('Mn '), cTID('MnIt'), cTID('FrTr'));
desc1.putReference(cTID('null'), ref1);
executeAction(cTID('slct'), desc1, DialogModes.NO);
Thanks JJMack, your solution 180degree rotation solve my problem. I usually use rectange selection.
Thanks Kukury and r-bin.
