      • EspaƱol
      • FranƧais
      • PortuguĆŖs
  • ę—„ęœ¬čŖžć‚³ćƒŸćƒ„ćƒ‹ćƒ†ć‚£
  • ķ•œźµ­ ģ»¤ė®¤ė‹ˆķ‹°
Media Encoder 2018 and AE 2018 Dynamic Link Error
Dec 26, 2017 Dec 26, 2017
I have  After Effects 2018 (Version 15) and the latest Media Encoder 2018 (Version 12) installed.
When I add to Media encoder queue from AE 2018, it does not link. Same when I try to add a project inside the Media Encoder.
The error that is shown is "Could not connect to Adobe After Effects. Please verify that Adobe After Effects and Adobe Dynamic Link components are installed"
Dynamic link , Error or problem
24.0K
Adobe Employee ,
Dec 27, 2017 Dec 27, 2017
Moving to Adobe Media Encoder (AME)ā€‹
Adobe Employee ,
Jan 02, 2018 Jan 02, 2018
Hi jobingeorgejacob,
Sorry for the inconvenience. It seems like an issue with the installation. Please uninstall & reinstall Adobe Media Encoder.
Vidya.
Jan 08, 2018 Jan 08, 2018
Can you please confirm if the issue that you were facing has been resolved or not?
Kulpreet Singh
Feb 09, 2018 Feb 09, 2018
I have the same problem!!!
Feb 12, 2018 Feb 12, 2018
same here,
not resolved.
Apr 17, 2018 Apr 17, 2018
Any solutions on this issue. It started doing this for me after new updates.
Aug 31, 2018 Aug 31, 2018
Same here. As soon as I updated AE I got the error. Playing with preferences checkboxes does nothing. This has been an issue since 20012 apparently? Nice job, adobe.
Feb 24, 2019 Feb 24, 2019
it is necessary to reinstall or update also
I had same problems million times. Sometime link works good, sometimes it take 3-4 minutes and sometimes it don't work at least. Restart computer helps me. We don't have another software except Adobe =( It like a MS Windows. Don't work good, but everybody use it.
ditto same issue
AME 12.0.1
AE 15.0.1
Mar 14, 2018 Mar 14, 2018
Is someone from Adobe going to respond to this? It seems like a fairly common problem. I've uninstalled and reinstalled and still have the same problem. I also ran the Adobe CC cleaner, as suggested in another post.
I used the CC installer to install both AE and the AME so I know they are both the same versions.
Any suggestions would be appreciated!
ch
Apr 06, 2018 Apr 06, 2018
Same problem for the 6 month. The programs is updating t newer versions, but problems is still unresolved Oo
Participant ,
I ran into this problem last summer (June, 2017). The Adobe folks came up with this, which worked for me:
I looked into this further and find out this problem happens when the following conditions are both met.
- AE Preferences > General > "Show Start Screen at Startup" is disabled
- AE Preferences > New Project > "New Project loads template" is enabled
I changed one (or both, I don't remember) settings and it's worked peachy for me since.
May 08, 2018 May 08, 2018
didnt work for me
Sep 06, 2018 Sep 06, 2018
Same issue, was fine till I updated 09-04-2018. Have uninstalled both AME & AE, reinstalled. still didn't work.
Sep 16, 2018 Sep 16, 2018
Same here... but I have seen this problem since media encoder has been released. I don't get why they moved all the good containers and codecs  features from the render queue to this garbage app...at least they should have let us the option to render our videos with the software we want! Right now my workflow is: render a .mov with animation codec in AE, then import the .mov in ME to render my .mp4 with H265... what a wast of time! We use to be able to render those directly with AE but not anymore. Thanks to  the broken ME dynamic link...
Oct 22, 2018 Oct 22, 2018
The same case here, after update...
HARDWARE: iMac (Retina 5K, 27-inch, Late 2015)
SOFTWARE: Mac OS Mojave
Adobe app updates to:
1. After Effects CC 2019 16.0.0
2. Media Encoder CC 2019 13.0
Export from AE to AME didn't work!
Sometimes it's work when I try when I export Composition from AE "Render Queue" using button "Queue in AME"
but only when I have AME App closed. After that the Dynamic Links still didn't work.
Everytime I try close application I only see the same error:
Process:               Adobe Media Encoder CC 2019 [1001]
Path:                  /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/MacOS/Adobe Media Encoder CC 2019
Identifier:            com.adobe.ame.application.CC13
Version:               13.0.203 (13.0.203)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Adobe Media Encoder CC 2019 [1001]
User ID:               501
Date/Time:             2018-10-22 16:03:30.827 +0200
OS Version:            Mac OS X 10.14 (18A391)
Report Version:        12
Anonymous UUID:        BD390E2C-8B07-B8E1-A2BF-80F1FA44586B
Sleep/Wake UUID:       924F7A28-235C-477F-9715-6DEFF2B2A062
Time Awake Since Boot: 4700 seconds
Time Since Wake:       840 seconds
System Integrity Protection: enabled
Crashed Thread:        15
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       EXC_I386_GPFLT
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Segmentation fault: 11
Termination Reason:    Namespace SIGNAL, Code 0xb
Terminating Process:   exc handler [1001]
Thread 0:: Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib         0x00007fff7654cade madvise + 10
1   libsystem_malloc.dylib         0x00007fff765cbe2d mvm_madvise_free + 87
2   libsystem_malloc.dylib         0x00007fff765cbd44 tiny_free_scan_madvise_free + 577
3   libsystem_malloc.dylib         0x00007fff765c2f91 tiny_free_no_lock + 2120
4   libsystem_malloc.dylib         0x00007fff765c2631 free_tiny + 483
5   com.adobe.GPUFoundation.framework 0x000000010f6ffb27 std::__1::__tree<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::__map_value_compare<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, true>, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > >::destroy(std::__1::__tree_node<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, void*>*) + 87
6   com.adobe.GPUFoundation.framework 0x000000010f6ffafd std::__1::__tree<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::__map_value_compare<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, true>, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > >::destroy(std::__1::__tree_node<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, void*>*) + 45
7   com.adobe.GPUFoundation.framework 0x000000010f6ffaf1 std::__1::__tree<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::__map_value_compare<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, true>, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > >::destroy(std::__1::__tree_node<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, void*>*) + 33
8   com.adobe.GPUFoundation.framework 0x000000010f6ffafd std::__1::__tree<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::__map_value_compare<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, true>, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > >::destroy(std::__1::__tree_node<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, void*>*) + 45
9   com.adobe.GPUFoundation.framework 0x000000010f6ffafd std::__1::__tree<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::__map_value_compare<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, true>, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > >::destroy(std::__1::__tree_node<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, void*>*) + 45
10  com.adobe.GPUFoundation.framework 0x000000010f6ffafd std::__1::__tree<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::__map_value_compare<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, true>, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > >::destroy(std::__1::__tree_node<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, void*>*) + 45
11  com.adobe.GPUFoundation.framework 0x000000010f6ffafd std::__1::__tree<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::__map_value_compare<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, std::__1::less<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > >, true>, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > >::destroy(std::__1::__tree_node<std::__1::__value_type<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >, void*>*) + 45
12  com.adobe.GPUFoundation.framework 0x000000010f6fd666 GF::DeviceModuleManagerCommon::ResetDiscoveredModulesCache() + 70
13  com.adobe.GPUFoundation.framework 0x000000010f6f2a10 GF::Device::DestroyContext(bool) + 576
14  com.adobe.GPUFoundation.framework 0x000000010f6fc5a2 GF::Terminate() + 98
15  FLT.dylib                     0x000000013d007bff FLT_Death() + 271
16  com.adobe.aelib.framework     0x00000001399ae938 aelib::TerminateIterator::operator--() + 504
17  com.adobe.aelib.framework     0x00000001399a91f8 Terminate + 40
18  com.adobe.dvacore.framework   0x000000010075f966 dvacore::config::lazyloader::Terminate(char const*) + 1398
19  com.adobe.ame.application.CC13 0x000000010004eb3e AME::app::AMEAppInitializer::~AMEAppInitializer() + 78
20  com.adobe.ame.application.CC13 0x000000010002ae2d AME::app::AMEApp::TerminateApplication() + 221
21  com.adobe.exo.framework       0x000000010b7f4307 exo::app::AppBase::Terminate() + 39
22  com.adobe.ame.application.CC13 0x00000001000368ae AME::RunTheApp(exo::app::AppInitArgs&, std::__1::vector<std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::__1::allocator<std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > >&) + 10046
23  com.adobe.ame.application.CC13 0x0000000100077ecf main + 399
24  libdyld.dylib                 0x00007fff76412085 start + 1
Thread 1:: com.apple.NSURLConnectionLoader
0   libsystem_kernel.dylib         0x00007fff7654ac2a mach_msg_trap + 10
1   libsystem_kernel.dylib         0x00007fff7654b174 mach_msg + 60
2   com.apple.CoreFoundation       0x00007fff4937e05e __CFRunLoopServiceMachPort + 337
3   com.apple.CoreFoundation       0x00007fff4937d5ad __CFRunLoopRun + 1654
4   com.apple.CoreFoundation       0x00007fff4937cce4 CFRunLoopRunSpecific + 463
5   com.apple.CFNetwork           0x00007fff48280ef5 -[__CoreSchedulingSetRunnable runForever] + 195
6   com.apple.Foundation           0x00007fff4b6d3234 __NSThread__start__ + 1218
7   libsystem_pthread.dylib       0x00007fff7660433d _pthread_body + 126
8   libsystem_pthread.dylib       0x00007fff766072a7 _pthread_start + 70
9   libsystem_pthread.dylib       0x00007fff76603425 thread_start + 13
Thread 2:
0   libsystem_kernel.dylib         0x00007fff76551052 kevent + 10
1   com.adobe.dvatransport.framework 0x0000000105a0e23d boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_operation>&) + 253
2   com.adobe.dvatransport.framework 0x0000000105a0dc48 boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost::asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 232
3   com.adobe.dvatransport.framework 0x0000000105a0d9b5 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 165
4   com.adobe.dvatransport.framework 0x0000000105a02c87 SkyConnectionEnv::MainLoop() + 151
5   com.adobe.dvatransport.framework 0x0000000105a02569 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
6   com.adobe.boost-threads.framework 0x0000000100542b7c boost::(anonymous namespace)::thread_proxy(void*) + 156
Thread 3:
0   libsystem_kernel.dylib         0x00007fff7654e1b2 __psynch_cvwait + 10
1   libsystem_pthread.dylib       0x00007fff766075cb _pthread_cond_wait + 724
2   com.adobe.dvatransport.framework 0x0000000105a0dce7 boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost::asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 391
4   com.adobe.dvatransport.framework 0x0000000105a1956f boost::asio::detail::resolver_service_base::work_io_service_runner::operator()() + 47
5   com.adobe.dvacore.framework   0x00000001007fddf0 boost_asio_detail_posix_thread_function + 16
6   libsystem_pthread.dylib       0x00007fff7660433d _pthread_body + 126
7   libsystem_pthread.dylib       0x00007fff766072a7 _pthread_start + 70
8   libsystem_pthread.dylib       0x00007fff76603425 thread_start + 13
Thread 4:: com.apple.CFSocket.private
0   libsystem_kernel.dylib         0x00007fff76551e82 __select + 10
1   com.apple.CoreFoundation       0x00007fff493abc83 __CFSocketManager + 639
2   libsystem_pthread.dylib       0x00007fff7660433d _pthread_body + 126
3   libsystem_pthread.dylib       0x00007fff766072a7 _pthread_start + 70
4   libsystem_pthread.dylib       0x00007fff76603425 thread_start + 13
Thread 5:
0   libsystem_kernel.dylib         0x00007fff7654ac7e semaphore_timedwait_trap + 10
1   com.apple.CoreServices.CarbonCore 0x00007fff4a6f900d MPWaitOnSemaphore + 74
2   ???                           0x000000013132ba77 0 + 5120375415
3   ???                           0x00000001312e27f2 0 + 5120075762
4   libsystem_pthread.dylib       0x00007fff7660433d _pthread_body + 126
5   libsystem_pthread.dylib       0x00007fff766072a7 _pthread_start + 70
6   libsystem_pthread.dylib       0x00007fff76603425 thread_start + 13
Thread 6:
2   ???                           0x000000013132c5f7 0 + 5120378359
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
2   com.adobe.dvacore.framework   0x0000000100725c21 boost::condition_variable::wait(boost::unique_lock<boost::mutex>&) + 65
3   com.adobe.dvacore.framework   0x000000010072588b dvacore::threads::ThreadSafeQueueBase::Pop(void*&, int) + 315
4   com.adobe.dvacore.framework   0x000000010086866e dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::__1::auto_ptr<dvacore::threads::AllocatedFunctionT<boost::function<void ()> > >&, int) + 142
5   com.adobe.dvacore.framework   0x0000000100866b8c dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 140
6   com.adobe.dvacore.framework   0x0000000100863fba dvacore::threads::(anonymous namespace)::LaunchThread(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 362
7   com.adobe.boost-threads.framework 0x0000000100542b7c boost::(anonymous namespace)::thread_proxy(void*) + 156
8   libsystem_pthread.dylib       0x00007fff7660433d _pthread_body + 126
9   libsystem_pthread.dylib       0x00007fff766072a7 _pthread_start + 70
10  libsystem_pthread.dylib       0x00007fff76603425 thread_start + 13
Thread 15 Crashed:
0   com.adobe.AMEDynamicLinkServer.framework 0x000000010c31fd14 AME::DynamicLinkServer::AMEEncoderImpl::AddItemShared(dvacore::utility::Guid const&, dvacore::filesupport::File const&, dvacore::utility::Guid const&, dynamiclink::PointProduct, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvacore::filesupport::File const&) + 180
1   com.adobe.AMEDynamicLinkServer.framework 0x000000010c321d69 AME::DynamicLinkServer::AMEEncoderImpl::AddItem_1(dvamarshal::Responder&, dvacore::utility::Guid const&, dvacore::filesupport::File const&, dvacore::utility::Guid const&, dynamiclink::PointProduct, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 777
2   com.adobe.AMEDynamicLinkServer.framework 0x000000010c3354bf AME::DynamicLinkServer::AMEEncoderServerImpl::AddItem_1(dvamarshal::Responder&, dvacore::utility::Guid const&, dvacore::filesupport::File const&, dvacore::utility::Guid const&, dynamiclink::PointProduct, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 799
3   com.adobe.AMEDynamicLinkServer.framework 0x000000010c36a649 boost::enable_if_c<(boost::function<void (dvamarshal::Responder&, dvacore::utility::Guid const&, dvacore::filesupport::File const&, dvacore::utility::Guid const&, dynamiclink::PointProduct, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>::arity) == (7), void>::type dvamarshal::DoHandleRequest<boost::function<void (dvamarshal::Responder&, dvacore::utility::Guid const&, dvacore::filesupport::File const&, dvacore::utility::Guid const&, dynamiclink::PointProduct, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)> >(boost::function<void (dvamarshal::Responder&, dvacore::utility::Guid const&, dvacore::filesupport::File const&, dvacore::utility::Guid const&, dynamiclink::PointProduct, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)> const&, dvamarshal::Responder&, std::__1::vector<boost::shared_ptr<boost::any>, dvacore::utility::SmallBlockAllocator::STLAllocator<boost::shared_ptr<boost::any> > > const&) + 201
4   com.adobe.dvamarshal.framework 0x0000000105ae5ff2 dvamarshal::DispatchRequest(boost::shared_ptr<dvatransport::Session> const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, long long, boost::shared_ptr<std::__1::vector<unsigned char, std::__1::allocator<unsigned char> > > const&, boost::shared_ptr<boost::any>&) + 466
5   com.adobe.dvamarshal.framework 0x0000000105afae7b dvamarshal::RPCServerGremlin::OnRequestReceived(boost::shared_ptr<dvatransport::Session> const&, boost::shared_ptr<std::__1::vector<unsigned char, std::__1::allocator<unsigned char> > > const&) + 715
6   com.adobe.dvamarshal.framework 0x0000000105af9b0a dvamarshal::RPCServerGremlin::StaticOnRequestReceived(boost::weak_ptr<dvamarshal::RPCServerGremlin> const&, boost::shared_ptr<dvatransport::Session> const&, boost::shared_ptr<std::__1::vector<unsigned char, std::__1::allocator<unsigned char> > > const&) + 74
7   com.adobe.dvatransport.framework 0x00000001059f4929 boost::function2<dvatransport::TransportError, boost::shared_ptr<dvatransport::Session>, boost::shared_ptr<std::__1::vector<unsigned char, std::__1::allocator<unsigned char> > > >::operator()(boost::shared_ptr<dvatransport::Session>, boost::shared_ptr<std::__1::vector<unsigned char, std::__1::allocator<unsigned char> > >) const + 89
8   com.adobe.dvatransport.framework 0x00000001059f43a4 dvatransport::TransportListenerManager::Process_SessionRecvMessage(boost::shared_ptr<dvatransport::SessionFacade>, boost::shared_ptr<std::__1::vector<unsigned char, std::__1::allocator<unsigned char> > > const&) + 372
9   com.adobe.dvatransport.framework 0x00000001059f465f dvatransport::TransportListenerManager::Process_SessionRecvMessage(boost::shared_ptr<dvatransport::SessionFacade>, boost::shared_ptr<std::__1::vector<unsigned char, std::__1::allocator<unsigned char> > > const&) + 1071
10  com.adobe.dvatransport.framework 0x00000001059fabb1 dvatransport::GenericTransporter::SessionTable_RecvMessage(boost::shared_ptr<dvatransport::GenericSession>, boost::shared_ptr<std::__1::vector<unsigned char, std::__1::allocator<unsigned char> > > const&) + 161
11  com.adobe.dvatransport.framework 0x00000001059fc253 dvatransport::GenericTransporter::NotifyIncomingExecute(unsigned long long) + 563
12  com.adobe.dvatransport.framework 0x00000001059f779a dvatransport::GenericTransporter::StaticNotifyIncomingExecute(boost::weak_ptr<dvatransport::GenericTransporter>, unsigned long long) + 58
13  com.adobe.dvatransport.framework 0x00000001059ffd52 boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::weak_ptr<dvatransport::GenericTransporter>, unsigned long long), boost::_bi::list2<boost::_bi::value<boost::weak_ptr<dvatransport::GenericTransporter> >, boost::_bi::value<unsigned long long> > >, void>::invoke(boost::detail::function::function_buffer&) + 50
14  com.adobe.dvacore.framework   0x0000000100866bc1 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 193
15  com.adobe.dvacore.framework   0x0000000100863fba dvacore::threads::(anonymous namespace)::LaunchThread(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 362
16  com.adobe.boost-threads.framework 0x0000000100542b7c boost::(anonymous namespace)::thread_proxy(void*) + 156
17  libsystem_pthread.dylib       0x00007fff7660433d _pthread_body + 126
18  libsystem_pthread.dylib       0x00007fff766072a7 _pthread_start + 70
19  libsystem_pthread.dylib       0x00007fff76603425 thread_start + 13
Thread 16:
Thread 17:: com.apple.NSEventThread
5   com.apple.AppKit               0x00007fff468dc581 _NSEventThread + 160
Thread 18:
Thread 19:
Thread 20:: MPSupport Worker
2   MultiProcessor Support         0x000000015ffb379b boost::condition_variable::wait(boost::unique_lock<boost::mutex>&) + 59
3   MultiProcessor Support         0x000000015ffb36bb ThreadFunctor::operator()() + 203
4   MultiProcessor Support         0x000000015ffd581b boost::(anonymous namespace)::thread_proxy(void*) + 151
5   libsystem_pthread.dylib       0x00007fff7660433d _pthread_body + 126
6   libsystem_pthread.dylib       0x00007fff766072a7 _pthread_start + 70
7   libsystem_pthread.dylib       0x00007fff76603425 thread_start + 13
Thread 21:: MPSupport Worker
Thread 22:: MPSupport Worker
Thread 23:: MPSupport Worker
Thread 24:: MPSupport Worker
Thread 25:: MPSupport Worker
Thread 26:: MPSupport Worker
Thread 27:
0   libsystem_pthread.dylib       0x00007fff76603408 start_wqthread + 0
1   ???                           0x0000000054485244 0 + 1414025796
Thread 28:
Thread 29:
Thread 30:
1   libdispatch.dylib             0x00007fff763c4428 _dispatch_sema4_timedwait + 76
2   libdispatch.dylib             0x00007fff763c4b19 _dispatch_semaphore_wait_slow + 58
3   libdispatch.dylib             0x00007fff763d1b5a _dispatch_worker_thread + 328
Thread 31:
Thread 32:
Thread 33:
Thread 15 crashed with X86 Thread State (64-bit):
  rax: 0x6000000015dd0f87  rbx: 0x0000700005481610  rcx: 0x0000000000000001  rdx: 0x0000000030af8836
  rdi: 0x00000000000000a4  rsi: 0x00006000005546a0  rbp: 0x0000700005481250  rsp: 0x0000700005480f20
   r8: 0x00000000000001ff   r9: 0x00000000000007fb  r10: 0x00000000000006a0  r11: 0x0000000000000020
  r12: 0x00007000054815f8  r13: 0x0000000000000001  r14: 0x00007000054815c0  r15: 0x00007000054815b0
  rip: 0x000000010c31fd14  rfl: 0x0000000000010206  cr2: 0x00000001313282d0
Logical CPU:     0
Error Code:      0x00000000
Trap Number:     13
Binary Images:
       0x100000000 -        0x10029efff +com.adobe.ame.application.CC13 (13.0.203 - 13.0.203) <01ABA88F-4FCF-3FCD-8C03-B5338EECA22E> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/MacOS/Adobe Media Encoder CC 2019
       0x100512000 -        0x100517ffb +com.adobe.AdobeCrashReporter (7.7 - 7.7.5) <F5F5AC4D-28D0-3301-82A5-AB220B99B648> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
       0x100523000 -        0x100524ffb +com.adobe.boost-system.framework (13.0.0 - 13.0.0.203) <562EF604-D7EA-3B85-A0F9-E4536F666FE0> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
       0x10052c000 -        0x100530ff7 +com.adobe.boost-date-time.framework (13.0.0 - 13.0.0.203) <12A44D23-8586-3282-AEB4-A02D91AF65D1> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
       0x100541000 -        0x10054dff7 +com.adobe.boost-threads.framework (13.0.0 - 13.0.0.203) <5CE44423-A6ED-3DFE-972A-03B1A7C5CFE4> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
       0x10056b000 -        0x100579ff7 +com.adobe.boost-filesystem.framework (13.0.0 - 13.0.0.203) <392990B5-875F-3F70-8F69-EDD8597C80DC> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
       0x10058f000 -        0x100630ff7 +com.adobe.boost-regex.framework (13.0.0 - 13.0.0.203) <04E7AF20-54F0-31C2-BB95-13993B78468E> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
       0x1006a7000 -        0x1006c9ff7 +com.adobe.dvaunittesting.framework (13.0.0 - 13.0.0.203) <FD5FEB25-C69E-3B76-82E5-0AD399B2F5A8> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
       0x100709000 -        0x100ac4fff +com.adobe.dvacore.framework (13.0.0 - 13.0.0.203) <81CAF27D-ABB1-3BF6-B382-6465953A58D9> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
       0x100e39000 -        0x100eb9ff7 +com.adobe.dvamediatypes.framework (13.0.0 - 13.0.0.203) <CAE64C97-2E32-3B76-82DD-A6DA43721AFE> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
       0x100f85000 -        0x101054ff7 +com.adobe.dvaaudiofilterhost.framework (13.0.0 - 13.0.0.203) <221D6A53-C9AF-3A83-BDA6-AA1E3275F08F> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaaudiofilterhost.framework/Versions/A/dvaaudiofilterhost
       0x10118d000 -        0x10122dfff +com.adobe.dvaappsupport.framework (13.0.0 - 13.0.0.203) <CE9D01EE-918E-3B09-AA46-04E8D2FEC659> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaappsupport.framework/Versions/A/dvaappsupport
       0x10130d000 -        0x101a5bfff +com.adobe.dvaui.framework (13.0.0 - 13.0.0.203) <0FB79951-D2E4-3219-B84D-ACA26BDA2E6F> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
       0x102683000 -        0x102742ff7 +com.adobe.dvaeve.framework (13.0.0 - 13.0.0.203) <A5E61C03-81DE-3D4F-AC07-80E0D887B328> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
       0x1028a1000 -        0x1028a4fff +com.adobe.PRM.framework (13.0.0 - 13.0.0.203) <CFC7671D-BEF7-34B5-BE22-71360D0E55C6> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
       0x1028b0000 -        0x102909fff +com.adobe.ASLFoundation.framework (13.0.0 - 13.0.0.203) <8CC86FFC-BE5A-3835-9905-AD9D95F8DBEE> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
       0x10296c000 -        0x1029aafff +com.adobe.MediaCoreUI.framework (13.0.0 - 13.0.0.203) <A6C1887B-85AB-3364-9682-7EDF37D0F9F9> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
       0x102a0a000 -        0x102ad5fff +com.adobe.dvanet.framework (13.0.0 - 13.0.0.203) <FB9113A0-C39B-36BE-A37C-95B258C106C1> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
       0x102c01000 -        0x1034a0ff7 +com.adobe.EAClient.framework (13.0.0 - 13.0.0.203) <3522C659-91AE-3D9A-A99B-223B90EC74B0> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/EAClient.framework/Versions/A/EAClient
       0x104015000 -        0x104235fff +com.adobe.EACodec.framework (13.0.0 - 13.0.0.203) <FBECA19B-4D86-3239-99D0-0AF47C3FAA49> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/EACodec.framework/Versions/A/EACodec
       0x10430c000 -        0x10460cff7 +com.adobe.EAMedia.framework (13.0.0 - 13.0.0.203) <503291FC-E1E8-3D77-99AB-ED558FA05511> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/EAMedia.framework/Versions/A/EAMedia
       0x1049bc000 -        0x104f0afff +com.adobe.EAProjectBridge.framework (13.0.0 - 13.0.0.203) <88DFF4B8-BBB0-389A-A7FB-216418A7EDB0> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/EAProjectBridge.framework/Versions/A/EAProjectBridge
       0x1055c9000 -        0x10576bfff +com.adobe.EAPrBridge.framework (13.0.0 - 13.0.0.203) <C54048D6-B0B1-3C8D-A18D-23A179EC4F62> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/EAPrBridge.framework/Versions/A/EAPrBridge
       0x1059ea000 -        0x105a43fff +com.adobe.dvatransport.framework (13.0.0 - 13.0.0.203) <8444344E-B6BD-39B3-8262-5B3B97966239> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
       0x105ae2000 -        0x105b05fff +com.adobe.dvamarshal.framework (13.0.0 - 13.0.0.203) <5B1783FB-B1AB-3E48-A2F4-C62577DAB848> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
       0x105b4a000 -        0x105d37fff +com.adobe.dynamiclink.framework (13.0.0 - 13.0.0.203) <08D84697-8EAA-39E4-B0B1-64B392F4AF29> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
       0x10605d000 -        0x1069d4fff +com.adobe.dvaaccelerate.framework (13.0.0 - 13.0.0.203) <9CE283C8-9F9E-3192-8C81-6EEC75A06D04> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaaccelerate.framework/Versions/A/dvaaccelerate
       0x106bb2000 -        0x106e2bfef +com.adobe.dvaaudiodsp.framework (13.0.0 - 13.0.0.203) <91F7ADF7-CEA9-3770-BC71-83BF6CF669FC> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaaudiodsp.framework/Versions/A/dvaaudiodsp
       0x1070fa000 -        0x1070fcff7 +com.adobe.Memory.framework (13.0.0 - 13.0.0.203) <DFAEF13E-7840-3B5C-8B4C-C6972F1CD8ED> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
       0x107104000 -        0x1071c3fff +com.adobe.MediaFoundation.framework (13.0.0 - 13.0.0.203) <F8C2C587-BE26-35DE-B6B2-25CFE7F7AFA2> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
       0x1072bb000 -        0x10733aff7 +com.adobe.AudioRenderer.framework (13.0.0 - 13.0.0.203) <74B7B8BE-450A-36BB-8388-AD30FC2F3BD2> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
       0x107404000 -        0x107563fff +com.adobe.dvacaptioning.framework (13.0.0 - 13.0.0.203) <B843D987-6223-3EB3-9B68-1649B9EE97FD> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvacaptioning.framework/Versions/A/dvacaptioning
       0x10766d000 -        0x1076bdff7 +com.adobe.dvatemporalxmp.framework (13.0.0 - 13.0.0.203) <4862F9A2-4A3B-3A66-A0AF-D2B91E8721E5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
       0x1076f4000 -        0x1077bafff +com.adobe.dvametadata.framework (13.0.0 - 13.0.0.203) <E68E703C-9B04-3FD0-BE25-B53A22D592B5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
       0x1078b1000 -        0x108708fff +com.adobe.Backend.framework (13.0.0 - 13.0.0.203) <0AE70367-A3A6-35A5-AE46-9A530FD8580D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
       0x109878000 -        0x1098f2ff7 +com.adobe.DynamicLinkMedia.framework (13.0.0 - 13.0.0.203) <8AAC47EB-56CA-3B58-B8EF-B6FF96F360D6> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
       0x1099fc000 -        0x109a2afff +com.adobe.MLFoundation.framework (13.0.0 - 13.0.0.203) <6A856708-20DB-3933-8EF8-0505ABAFBC9F> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
       0x109a89000 -        0x109bfcff7 +com.adobe.ImageRenderer.framework (13.0.0 - 13.0.0.203) <9F64BECA-1F82-39E0-8AF0-813D5566F998> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
       0x109d61000 -        0x109dd1ff7 +com.adobe.VideoFrame.framework (13.0.0 - 13.0.0.203) <ECED4A28-131E-3C62-889D-2CB784985D05> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
       0x109e4f000 -        0x109ea6fff +com.adobe.PluginSupport.framework (13.0.0 - 13.0.0.203) <1FD8C301-DD73-3CA8-95F2-D9E917816225> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
       0x109f15000 -        0x109f44fff +com.adobe.SweetPeaSupport.framework (13.0.0 - 13.0.0.203) <03974591-B39D-32B1-8627-4D7920C300BB> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
       0x109f8c000 -        0x10a0d7ff7 +com.adobe.VideoRenderer.framework (13.0.0 - 13.0.0.203) <C0F68542-0E79-3F33-8040-57C5315E7E00> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
       0x10a27c000 -        0x10a2bdff7 +com.adobe.AudioSupport.framework (13.0.0 - 13.0.0.203) <99DD0C0E-F571-36A2-AD00-4A7812BAC761> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
       0x10a342000 -        0x10a35eff7 +com.adobe.MediaUtils.framework (13.0.0 - 13.0.0.203) <730292D2-91AC-35BD-9DCB-78A206A82E82> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
       0x10a389000 -        0x10a56dff7 +com.adobe.ImporterHost.framework (13.0.0 - 13.0.0.203) <941DD855-0F0B-3D0E-8931-1633594AEED1> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
       0x10a843000 -        0x10a933fff +com.adobe.ExporterHost.framework (13.0.0 - 13.0.0.203) <28EBC949-8A5C-3C46-B042-81A8A2882323> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
       0x10aa5f000 -        0x10aab7ff7 +com.adobe.ScriptLayer.framework (13.0.0 - 13.0.0.203) <7FE60339-B590-3BFC-A19F-81EBF7E94CE4> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ScriptLayer.framework/Versions/A/ScriptLayer
       0x10aba2000 -        0x10abc6ff7 +com.adobe.cloudservices.framework (13.0.0 - 13.0.0.203) <E37365C7-5821-3442-8FC5-82A84EF63F9E> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/cloudservices.framework/Versions/A/cloudservices
       0x10ac08000 -        0x10ac14ff7 +com.adobe.SharedSettings.framework (13.0.0 - 13.0.0.203) <E8609417-F1D9-3D21-B198-F1222A5004EE> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/SharedSettings.framework/Versions/A/SharedSettings
       0x10ac48000 -        0x10acc66a7  dyld (625.13) <D6387150-2FB8-3066-868D-72E1B1C43982> /usr/lib/dyld
       0x10ad29000 -        0x10ae77fff +com.adobe.VideoFilterHost.framework (13.0.0 - 13.0.0.203) <BFDEA03D-1E21-3975-A3D2-102A6E95E1DD> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
       0x10b019000 -        0x10b1ddff7 +com.adobe.EncoderHost.framework (13.0.0 - 13.0.0.203) <15852DFE-E263-3178-92B9-C3085A6A939D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
       0x10b400000 -        0x10b544fff +com.adobe.dvaworkspace.framework (13.0.0 - 13.0.0.203) <0220F8C9-BDDE-3BEE-8C06-D1AAC851A909> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
       0x10b7f1000 -        0x10b8d5ff7 +com.adobe.exo.framework (13.0.0 - 13.0.0.203) <46EEBB30-81CA-3BBE-8AE6-A1D9F80F423E> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/exo.framework/Versions/A/exo
       0x10bac7000 -        0x10bca2fff +com.adobe.Batch.framework (13.0.0 - 13.0.0.203) <698B7533-FC22-3660-BD26-078CD736B78B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/Batch.framework/Versions/A/Batch
       0x10c044000 -        0x10c09ffff +com.adobe.AMEDynamicLinkClient.framework (13.0.0 - 13.0.0.203) <D228ABE4-0EC5-32D1-A88B-0B588D2B7DBC> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AMEDynamicLinkClient.framework/Versions/A/AMEDynamicLinkClient
       0x10c150000 -        0x10c2a9ff7 +com.adobe.dvametadataDB.framework (13.0.0 - 13.0.0.203) <040396E9-2C1E-3D47-A459-CCDF5B8B07C8> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvametadataDB.framework/Versions/A/dvametadataDB
       0x10c2f4000 -        0x10c392fff +com.adobe.AMEDynamicLinkServer.framework (13.0.0 - 13.0.0.203) <1C8FB5E8-9C1C-391C-91BD-01B432AB318B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AMEDynamicLinkServer.framework/Versions/A/AMEDynamicLinkServer
       0x10c4dc000 -        0x10c500ff7 +com.adobe.AMEAppFoundation.framework (13.0.0 - 13.0.0.203) <B43F5621-CC58-37E2-8E55-85D5EF999927> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
       0x10c555000 -        0x10c5a1ff7 +com.adobe.dynamiclinkUI.framework (13.0.0 - 13.0.0.203) <A7F58EF1-114B-3885-97A8-A23C69F60BE2> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dynamiclinkUI.framework/Versions/A/dynamiclinkUI
       0x10c63e000 -        0x10c980ff7 +com.adobe.AMEFrontend.framework (13.0.0 - 13.0.0.203) <D7F6D1F9-893D-36D4-9B7C-5C994C9E9011> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AMEFrontend.framework/Versions/A/AMEFrontend
       0x10cebb000 -        0x10ced9ff7 +com.adobe.IngestGlue.framework (13.0.0 - 13.0.0.203) <FE902A9C-B30C-3C8C-AADA-71F2002244E5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/IngestGlue.framework/Versions/A/IngestGlue
       0x10cf20000 -        0x10cf3cfff +com.adobe.postprocess.framework (13.0.0 - 13.0.0.203) <0F4AA40E-4C05-3AA5-B767-5520E34D546B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/postprocess.framework/Versions/A/postprocess
       0x10cf79000 -        0x10d2e4ff7 +com.adobe.SettingsUI.framework (13.0.0 - 13.0.0.203) <FF5E3499-A314-3658-BF02-FB111CD08B00> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
       0x10d89f000 -        0x10d901ff7 +com.adobe.WatchFolder.framework (13.0.0 - 13.0.0.203) <95CB373E-A002-3173-AA01-96757DB499D3> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/WatchFolder.framework/Versions/A/WatchFolder
       0x10d9d9000 -        0x10da35ff7 +com.adobe.AudioFilterHost.framework (13.0.0 - 13.0.0.203) <6013D086-C222-30D2-80B4-0C6856F8F7B2> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
       0x10dacc000 -        0x10db02ff7 +com.adobe.AudioFilters.framework (13.0.0 - 13.0.0.203) <8C30BB00-F920-3B5B-BA47-FCD73510E76D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
       0x10db76000 -        0x10db7dfff +com.adobe.dvabravoinitializer.framework (13.0.0 - 13.0.0.203) <09C0EC02-8E33-3381-B93D-7450F961FE97> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvabravoinitializer.framework/Versions/A/dvabravoinitializer
       0x10db8e000 -        0x10dbb6fff +com.adobe.ImmersiveVideo.framework (13.0.0 - 13.0.0.203) <F86DA200-997A-3AF3-B355-1255CB4DB7A6> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ImmersiveVideo.framework/Versions/A/ImmersiveVideo
       0x10dbd6000 -        0x10dc51fff +com.adobe.DisplaySurface.framework (13.0.0 - 13.0.0.203) <5F67F404-A170-37BF-ACC8-781D522E5653> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/DisplaySurface.framework/Versions/A/DisplaySurface
       0x10dce4000 -        0x10ddfcfff +com.adobe.dvascripting.framework (13.0.0 - 13.0.0.203) <8B669103-C770-3730-B5A9-4895E7F8C4A3> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvascripting.framework/Versions/A/dvascripting
       0x10e0a0000 -        0x10e0f2fff +com.adobe.FontEngine.framework (13.0.0 - 13.0.0.203) <1DEAFDB4-5D66-39AB-A36C-B542142E154B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/FontEngine.framework/Versions/A/FontEngine
       0x10e185000 -        0x10e19eff7 +com.adobe.TitleLayer.framework (13.0.0 - 13.0.0.203) <D1FFEEB1-3AD8-3096-B8F7-57BB4C4FF368> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TitleLayer.framework/Versions/A/TitleLayer
       0x10e33b000 -        0x10e343ff7 +com.adobe.TitleImageManager.framework (13.0.0 - 13.0.0.203) <1A48B078-57EA-369E-87D7-8275E7BD7738> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TitleImageManager.framework/Versions/A/TitleImageManager
       0x10e352000 -        0x10e3d0fff +com.adobe.TitleCharacterFactory.framework (13.0.0 - 13.0.0.203) <5FF7EB84-D328-3311-8291-A2E65386D303> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TitleCharacterFactory.framework/Versions/A/TitleCharacterFactory
       0x10e422000 -        0x10e57eff7 +com.adobe.TitleCG.framework (13.0.0 - 13.0.0.203) <9E3AFED1-0D33-32E8-9A3C-384B624DA978> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TitleCG.framework/Versions/A/TitleCG
       0x10e68c000 -        0x10e8bafff +com.adobe.TitleLayout.framework (13.0.0 - 13.0.0.203) <5FB0F02B-77A2-31CE-AE44-B37D8D71EB69> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TitleLayout.framework/Versions/A/TitleLayout
       0x10edcb000 -        0x10ee20ff7 +com.adobe.TitleRenderer.framework (13.0.0 - 13.0.0.203) <89144B40-A3A3-393A-8D62-6530A7A89363> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TitleRenderer.framework/Versions/A/TitleRenderer
       0x10eeb6000 -        0x10f0b1fff +com.adobe.MBCProvider.framework (13.0.0 - 13.0.0.203) <A4C0B806-625F-3E87-8FD6-B90627F14DF1> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/MBCProvider.framework/Versions/A/MBCProvider
       0x10f20c000 -        0x10f27eff7 +com.adobe.PlayerHost.framework (13.0.0 - 13.0.0.203) <9D04191D-ADDF-3FA8-80E0-21E29AEAB330> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
       0x10f36d000 -        0x10f380ff7 +com.adobe.ProjectConverterHost.framework (13.0.0 - 13.0.0.203) <C12B992C-9A09-3FE8-A3D8-6D9BC3A1EEDD> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A/ProjectConverterHost
       0x10f3a8000 -        0x10f3c2fff +com.adobe.ProjectSupport.framework (13.0.0 - 13.0.0.203) <69A4F771-7B11-34AB-A0FD-FB7F81CEC303> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
       0x10f3fa000 -        0x10f4daff7 +com.adobe.CodecSupport.framework (13.0.0 - 13.0.0.203) <5CFC4BF1-CE90-3A0C-B277-76D329B47067> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/CodecSupport.framework/Versions/A/CodecSupport
       0x10f59f000 -        0x10f5c3ff7 +com.adobe.dvavulcansupport.framework (13.0.0 - 13.0.0.203) <C9FA1F27-3BA2-3653-8B08-835FB355963C> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvavulcansupport.framework/Versions/A/dvavulcansupport
       0x10f5fb000 -        0x10f661fff +com.adobe.csxsmanager.framework (13.0.0 - 13.0.0.203) <6E063E9E-DE4B-3C80-B5E3-4AA878E9B9A5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/CSXSManager.framework/Versions/A/CSXSManager
       0x10f6ec000 -        0x10f8fcff7 +com.adobe.GPUFoundation.framework (13.0.0 - 13.0.0.203) <8759DCAB-1EEB-33B8-95E8-EEA81C7481EE> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/GPUFoundation.framework/Versions/A/GPUFoundation
       0x10fa5b000 -        0x10fc48ff7 +com.adobe.RendererGPU.framework (13.0.0 - 13.0.0.203) <6EA0F2D3-56C4-3B02-9E56-660407184EFC> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/RendererGPU.framework/Versions/A/RendererGPU
       0x10fd9e000 -        0x10fdfcff7 +com.adobe.dvamediaui.framework (13.0.0 - 13.0.0.203) <A6724084-499D-3D7C-A9E0-3E1B434D2922> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvamediaui.framework/Versions/A/dvamediaui
       0x10febf000 -        0x110042fff +com.adobe.dvamediabrowser.framework (13.0.0 - 13.0.0.203) <83330B99-6595-3F49-AB8B-6C38C96AF964> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvamediabrowser.framework/Versions/A/dvamediabrowser
       0x110325000 -        0x110441ff7 +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 145 - 79.163499) <7CE7074B-ED39-31E5-9998-4A29FBD07EE9> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
       0x1105a1000 -        0x110712ff7 +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.7 -f 51 - 79.163499) <D9246333-E422-3CBC-8841-4D75836763AD> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
       0x110873000 -        0x110908fff +com.adobe.sccore.framework (4.5.6 - 4.5.6.1) <1EB545A5-0EEF-3BDF-B625-4ADF18A8E686> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/sccore.framework/Versions/A/sccore
       0x1109a3000 -        0x110a3cfff +com.adobe.extendscript.framework (4.5.6 - 4.5.6.1) <3D784486-7FBA-3666-96BF-894172D1D142> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/extendscript.framework/Versions/A/extendscript
       0x110ae8000 -        0x110bf3ff7 +com.adobe.ACE (AdobeACE 2.20.02.41706 - 2.20.02.41706) <FC3950C6-2B16-3AA2-B185-F70F87B9F5DA> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
       0x110c0c000 -        0x1110e2fff +com.adobe.AGM (AdobeAGM 4.30.87.41706 - 4.30.87.41706) <EA4ABA10-5017-3B6B-95CC-D92B461BDD7B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
       0x11118f000 -        0x1111a5fff +com.adobe.BIB (AdobeBIB 1.2.03.41706 - 1.2.03.41706) <E6EC9F2C-B761-333F-A528-FD05C70068DE> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
       0x1111ae000 -        0x1114a4ff7 +com.adobe.CoolType (AdobeCoolType 5.17.00.41706 - 5.17.00.41706) <570DEEF4-688C-31D8-83FB-AA718115E5F5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
       0x1114f6000 -        0x11169efff +com.adobe.headlights.LogSessionFramework (8.0.0.46.47979) <C8618457-89D1-384A-8EAD-43823AEF86AB> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
       0x11183c000 -        0x111ac6fc7 +com.adobe.PlugPlug (9.2.1.39 - 9.2.1.39) <5BAB72EB-96AE-36EA-9E82-9C7377D5ADD5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
       0x111d43000 -        0x111e41ff3 +ZXPSignLib-minimal-dylib.dylib (0) <B50C7884-6179-3925-AF15-0013257D0F6B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ZXPSignLib-minimal-dylib.dylib
       0x111e6f000 -        0x111e8bffb +com.adobe.libzip.framework (13.0.0 - 13.0.0.203) <0CD835FB-18D5-3424-BF11-FDD7B09EABCC> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libzip.framework/Versions/A/libzip
       0x111ea3000 -        0x111ec7fff +VulcanControl.dylib (5.4.0.12 - 5.4.0.12 Copyright 2017, Adobe Systems Incorporated. All rights reserved.) <28EE3D33-EA55-38D6-91AA-63225B82B0A5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/VulcanControl.dylib
       0x111ef4000 -        0x111f2fff7 +VulcanMessage5.dylib (5.3.0.18 - 5.3.0.18 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <9E8F32A6-84F5-33EF-854C-9D0590105050> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/VulcanMessage5.dylib
       0x111f79000 -        0x112105ff7 +com.adobe.dvaaudiofilters.framework (13.0.0 - 13.0.0.203) <C233BAD2-EE4D-375C-8706-DC39C209FAF3> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaaudiofilters.framework/Versions/A/dvaaudiofilters
       0x112334000 -        0x1125e5ff7 +libxerces-c-3.1.dylib (0) <226354C7-81DD-3502-9CCB-500EC181627A> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libxerces-c-3.1.dylib
       0x112795000 -        0x1127aefff +com.adobe.TeamProjectsLocalClient.framework (13.0.0 - 13.0.0.203) <AFAC943A-3298-311E-BBFC-46FC6AB17D51> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TeamProjectsLocalClient.framework/Versions/A/TeamProjectsLocalClient
       0x1127e8000 -        0x1128a9fff +com.adobe.AdobeXMPCompareAndMerge (Adobe XMP Compare And Merge 2.0 -c 7 - 79.163499) <1381AAF4-3CBB-38C1-BBCF-FED0F2AF34D3> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeXMPCompareAndMerge.framework/Versions/A/AdobeXMPCompareAndMerge
       0x112a14000 -        0x112accff7 +com.adobe.ColorSpaceConverter.framework (13.0.0 - 13.0.0.203) <A574E6AB-237C-3DBA-AD31-FD8F8FB982F1> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ColorSpaceConverter.framework/Versions/A/ColorSpaceConverter
       0x112b42000 -        0x112b52ff7 +com.adobe.ACEWrapper.framework (13.0.0 - 13.0.0.203) <27E32138-F1FA-352A-AAE6-355EA81C88B3> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ACEWrapper.framework/Versions/A/ACEWrapper
       0x112b75000 -        0x112b94ff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.41706 - 1.1.41706) <571B5070-B38D-3D5A-8658-33C16CB963C8> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
       0x112b9c000 -        0x112bb2ff7 +com.adobe.RuntimeInstaller.framework (13.0.0 - 13.0.0.203) <1630DF90-9199-336D-8B25-9EF5F3AA7C63> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/RuntimeInstaller.framework/Versions/A/RuntimeInstaller
       0x112bd1000 -        0x112cd2fff +com.mainconcept.mc.mfimport (10.5 - 10.5.18.0000) <239D9891-75B3-35DA-9523-52DF4F1B81EF> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_mfimport.framework/Versions/10/mc_mfimport
       0x112ce3000 -        0x113054fe7 +com.mainconcept.mc.enc.avc (10.5 - 10.5.18.0000) <88B2A327-A7BD-365D-BFC5-A47FCB6CA834> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_enc_avc.framework/Versions/10/mc_enc_avc
       0x11318d000 -        0x11339ffc7 +com.mainconcept.mc.dec.avc (10.5 - 10.5.18.0000) <0001E005-5103-3A41-B642-15F4525DBB2E> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_dec_avc.framework/Versions/10/mc_dec_avc
       0x1133e3000 -        0x113674ff7 +com.mainconcept.mc.mux.mp4 (10.5 - 10.5.18.0000) <CEC9696E-3BCE-36A7-B2D1-FD8E616EDE74> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_mux_mp4.framework/Versions/10/mc_mux_mp4
       0x1136a1000 -        0x11383afef +com.mainconcept.mc.dec.mp2v (10.5 - 10.5.18.0000) <5439586D-D789-30B7-8D74-7688C4149491> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_dec_mp2v.framework/Versions/10/mc_dec_mp2v
       0x113849000 -        0x113adbfcf +com.mainconcept.mc.bc.dec.avc (10.5 - 10.5.18.0000) <DB8F4720-6CB8-3876-9620-3CAC63EE187E> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_bc_dec_avc.framework/Versions/10/mc_bc_dec_avc
       0x113af2000 -        0x113ccafe7 +com.mainconcept.mc.dec.mp4v (10.5 - 10.5.18.0000) <3A6C38F7-AB6D-3520-BE1E-C75E3EDFCD33> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_dec_mp4v.framework/Versions/10/mc_dec_mp4v
       0x113cdd000 -        0x115246fef +com.canon.CrmSdk (2.0.0.35 - 2.0.0.35) <975241B6-A7F7-3ED4-A5F4-65EC2B948400> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/CrmSdk.framework/Versions/A/CrmSdk
       0x115442000 -        0x1155b5fef +com.mainconcept.mc.trans.video.colorspace (10.5 - 10.5.18.0000) <32A0CE5A-A476-324A-93E3-59EF0F32C95B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_trans_video_colorspace.framework/Versions/10/mc_trans_video_colorspace
       0x1155c2000 -        0x11560bfdf +com.adobe.ProResOpt.framework (13.0.0 - 13.0.0.203) <208036B1-BDF3-354B-826E-4A392CAFF42D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ProResOpt.framework/Versions/A/ProResOpt
       0x115654000 -        0x115660fff +com.adobe.QT64Utils.framework (13.0.0 - 13.0.0.203) <8D0E177E-C4C9-3363-BD2E-A813157D48E2> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/QT64Utils.framework/Versions/A/QT64Utils
       0x115677000 -        0x115b58fc7 +libDNxHR.dylib (0) <16E89552-7DB0-3ABA-87A1-C9111E71CE84> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libDNxHR.dylib
       0x115c47000 -        0x115db6ff7 +libSonyRawDev.dylib (3.1) <0128E0CE-B6D4-316B-B125-008B8AC7C40B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libSonyRawDev.dylib
       0x115e52000 -        0x1171c8fff +libArriRawSDK.dylib (0) <F09C8C7E-AD5F-339E-900B-2E47789A5A9B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libArriRawSDK.dylib
       0x117900000 -        0x1179dcfe7 +libmp4decMT.dylib (1.1.3) <A663DA9C-874F-742A-58B2-B5665D99CA03> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libmp4decMT.dylib
       0x117a3b000 -        0x117b45fff +libCFHDDecoder.dylib (1) <0C9B6356-F555-39E0-9054-81E3FAC4DE55> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libCFHDDecoder.dylib
       0x117be6000 -        0x117ce8fff +libCFHDEncoder.dylib (1) <A3B4AE2B-D61C-339A-8DD1-B2E523640425> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libCFHDEncoder.dylib
       0x117d97000 -        0x117ec5ff3 +libkdu_as7AR.dylib (0) <4953AF4F-BB7F-3CFE-9594-77748AD230CB> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libkdu_as7AR.dylib
       0x117f2a000 -        0x118097feb +libkdu_vs7AR.dylib (0) <11C608BE-DC34-352B-90B6-C1A9428AA898> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libkdu_vs7AR.dylib
       0x1180db000 -        0x118118ff7 +libcudart.6.5.dylib (6.5.14) <D461AB76-19EE-3BDD-A579-3942130A15B0> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libcudart.6.5.dylib
       0x118124000 -        0x11823cfdf +libiomp5.dylib (0) <C97AB725-E5D2-31C7-81BD-8CAA641357CD> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libiomp5.dylib
       0x1182a4000 -        0x1182eaff7 +libtbb.dylib (0) <8B2D7D64-9404-3E6D-A7A5-6B76038F4450> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libtbb.dylib
       0x11833f000 -        0x11836ffef +libtbbmalloc.dylib (0) <3CE44609-95E5-35E1-8167-17A4F4DA2378> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libtbbmalloc.dylib
       0x1183b5000 -        0x1183e8ff7 +com.adobe.QTParser.framework (13.0.0 - 13.0.0.203) <D8BB20B2-701F-3814-B5F3-9D5F373B1FEA> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
       0x118410000 -        0x1184f5fdf +libProResDecoder.dylib (0) <04FA87AB-AC1C-3B5E-A76B-B74F2367BCAA> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libProResDecoder.dylib
       0x118536000 -        0x118571fff +libcudart.dylib (0) <6E55D67C-1A95-3C2B-B2C1-C3F5827A3F03> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libcudart.dylib
       0x11857f000 -        0x118595ff7 +com.adobe.CCLibrariesSupport.framework (13.0.0 - 13.0.0.203) <DC2EA830-56E3-3172-904E-B80097F80C4B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/CCLibrariesSupport.framework/Versions/A/CCLibrariesSupport
       0x1185cc000 -        0x118732fcf +com.adobe.atl-audio.framework (13.0.0 - 13.0.0.203) <1228A4DE-DF78-387E-BE75-80D907CC9737> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/atl_audio.framework/Versions/A/atl_audio
       0x118770000 -        0x11889ffff +com.adobe.dvaaudiodevice.framework (13.0.0 - 13.0.0.203) <8D5B04E5-5271-3A41-B9D1-A50EC7D7861A> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
       0x118b34000 -        0x118bddfff +com.adobe.AdobeSensorManager (Adobe Sensor Manager 2.0 -s 041 - 79.163581) <D83DE453-EEA5-396C-8BA2-FF58EE15CF1F> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeSensorManager.framework/Versions/A/AdobeSensorManager
       0x118c80000 -        0x118d58fff +com.adobe.OpticalFlow.framework (13.0.0 - 13.0.0.203) <2092497B-0EB7-3B4A-B329-620C710948AF> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/OpticalFlow.framework/Versions/A/OpticalFlow
       0x118e20000 -        0x119315fff +com.adobe.ATEWrapper.framework (13.0.0 - 13.0.0.203) <0A3B11DF-C9F8-3FA9-B8D6-F812EB739BB9> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ATEWrapper.framework/Versions/A/ATEWrapper
       0x119890000 -        0x11b190fff +com.adobe.ICUData (58.2 - 3.61) <8E068A48-E220-3267-8756-3D2A19B07964> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ICUData.framework/Versions/58.2/ICUData
       0x11b1e5000 -        0x11b2baff7 +com.adobe.ICUConverter (58.2 - 3.61) <7E138985-1007-3EF5-A253-50740FE803FB> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ICUConverter.framework/Versions/58.2/ICUConverter
       0x11b2fe000 -        0x11b42dff3 +com.adobe.ICUUnicode (58.2 - 3.61) <DCF3DD51-98E8-3780-87CB-EB4598F0742C> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ICUUnicode.framework/Versions/58.2/ICUUnicode
       0x11b49c000 -        0x11b658ff7 +com.winsoft.wrservices (WRServices 14.0.0 - 14.0.0) <8912A48C-5441-3D15-93FB-C91BD026FD32> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/wrservices.framework/Versions/A/WRServices
       0x11b6e1000 -        0x11b709ff7 +com.adobe.TimeCarving.framework (13.0.0 - 13.0.0.203) <7E3DE647-2952-3DB2-A437-8CCE38D53990> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TimeCarving.framework/Versions/A/TimeCarving
       0x11b74f000 -        0x11b765ff7 +com.adobe.dvanetsync.framework (13.0.0 - 13.0.0.203) <B413BE97-9F3E-3733-BCF5-265995686B50> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvanetsync.framework/Versions/A/dvanetsync
       0x11b7a3000 -        0x11b7dfff7 +com.adobe.boost-serialization.framework (13.0.0 - 13.0.0.203) <8D18D56C-9E1B-3707-8D3D-F8CD015892EC> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/boost_serialization.framework/Versions/A/boost_serialization
       0x11b8ac000 -        0x11be95fff +com.adobe.TeamProjectsLocalLib.framework (13.0.0 - 13.0.0.203) <0746F0AC-81AC-3189-B5C7-A3D7CC38C20B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TeamProjectsLocalLib.framework/Versions/A/TeamProjectsLocalLib
       0x11c4df000 -        0x11c512fff +com.adobe.boost-program-options.framework (13.0.0 - 13.0.0.203) <DA4144EF-A9CC-339A-9F8B-5AEDAD8C8DD3> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/boost_program_options.framework/Versions/A/boost_program_options
       0x11c571000 -        0x11c6afff7 +com.adobe.dvastorage.framework (13.0.0 - 13.0.0.203) <D42FD183-549D-3D95-8066-AA69967613A1> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvastorage.framework/Versions/A/dvastorage
       0x11c724000 -        0x11c7dbff7 +com.adobe.dvacapsule.framework (13.0.0 - 13.0.0.203) <1EB00660-0C87-3776-A9AA-50E862F4BB3E> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvacapsule.framework/Versions/A/dvacapsule
       0x11c8eb000 -        0x11c99dfff +libgit2.dylib (0) <DB34258D-83CF-3F30-ABCA-1F2FA4D52D53> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libgit2.dylib
       0x11c9c1000 -        0x11ca95ff7 +com.adobe.cclibmanager.framework (13.0.0 - 13.0.0.203) <B08A8625-2BB8-360B-A5E7-EF398BA77694> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/cclibmanager.framework/Versions/A/cclibmanager
       0x11ccbf000 -        0x11cd3aff7 +com.adobe.RecorderHost.framework (13.0.0 - 13.0.0.203) <0E017E76-4F38-36D5-B0AC-5775F77C28AF> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/RecorderHost.framework/Versions/A/RecorderHost
       0x11ce4a000 -        0x11d29efff +com.adobe.UIFramework.framework (13.0.0 - 13.0.0.203) <CA8B6D99-E5E7-38A5-AED3-97CA8055DAC5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/UIFramework.framework/Versions/A/UIFramework
       0x11dbce000 -        0x11e7e6ff7 +com.adobe.Mezzanine.framework (13.0.0 - 13.0.0.203) <936F1AEB-AFEC-30A1-B198-E3E4B84E2373> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/Mezzanine.framework/Versions/A/Mezzanine
       0x11f591000 -        0x11fb21ff7 +com.adobe.Dialogs.framework (13.0.0 - 13.0.0.203) <282AA77D-4ED3-37CA-BE71-3B6CF27590EB> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/Dialogs.framework/Versions/A/Dialogs
       0x120167000 -        0x120390fff +com.adobe.IngestCore.framework (13.0.0 - 13.0.0.203) <DF22E48C-58D1-3BA4-A7B8-5F79A385440B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/IngestCore.framework/Versions/A/IngestCore
       0x12070a000 -        0x120750ff7 +com.adobe.TransmitHost.framework (13.0.0 - 13.0.0.203) <FB95225F-CDA0-382D-AAF1-F2F1CFEC8F81> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TransmitHost.framework/Versions/A/TransmitHost
       0x1207b7000 -        0x120858ff7 +com.adobe.dvascriptedworkflow.framework (13.0.0 - 13.0.0.203) <EE1E1AA2-B659-32BE-8107-9A2DC0B7D3D6> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvascriptedworkflow.framework/Versions/A/dvascriptedworkflow
       0x1209db000 -        0x120a64fff +com.adobe.MediaFinder.framework (13.0.0 - 13.0.0.203) <F9F1BB7E-AADC-3B65-82A3-2C4A60436A67> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/MediaFinder.framework/Versions/A/MediaFinder
       0x120b72000 -        0x120d1bfff +com.adobe.SynKitLib (1.0.0.91 - 1.0.0.91) <FB3028A1-2329-311E-AB97-90CECA1870A9> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/SynKitLib.framework/Versions/A/SynKitLib
       0x120e47000 -        0x120e90ff7 +com.adobe.ahclientframework (4.0.0.0 - 4.0.0.0) <51C89AA8-9D51-31E7-BD87-F0949DF0EB2A> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
       0x120ecd000 -        0x120ed3ff7 +com.adobe.dvaundo.framework (13.0.0 - 13.0.0.203) <6A0B8CAD-FD7B-3420-B3AB-AC51439736C0> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaundo.framework/Versions/A/dvaundo
       0x120ee1000 -        0x120f99ff7 +com.adobe.essentialsound.framework (13.0.0 - 13.0.0.203) <30B0F423-9CB1-3A41-A945-3443DF615814> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/essentialsound.framework/Versions/A/essentialsound
       0x1210b0000 -        0x121117ff7 +com.adobe.dvaaudiofilterhostui.framework (13.0.0 - 13.0.0.203) <B8DC34B3-615C-3509-A3F1-046799D542B2> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaaudiofilterhostui.framework/Versions/A/dvaaudiofilterhostui
       0x12120f000 -        0x121305ff7 +com.adobe.dvametadataUI.framework (13.0.0 - 13.0.0.203) <CD8078DC-2718-3C0D-8A07-1B360C193015> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
       0x121463000 -        0x12146dff7 +com.adobe.dvamarkerUI.framework (13.0.0 - 13.0.0.203) <3118720C-98C7-3DD0-A1F4-4BA8B1D8D49E> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvamarkerUI.framework/Versions/A/dvamarkerUI
       0x121492000 -        0x1214bcff7 +com.adobe.dvatypekit.framework (13.0.0 - 13.0.0.203) <60768F27-70A6-3DD1-8333-5424CA8B080D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvatypekit.framework/Versions/A/dvatypekit
       0x1214fd000 -        0x1215a8fff +com.diaquest.pro4.omf (1.0.0.1022 - 1.0.0.1022) <CC5C6568-78E8-3E2C-B900-2F4392A0309D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/Pro4OMF.framework/Versions/A/Pro4OMF
       0x1215d4000 -        0x121607fff +com.adobe.dvacontrolsurfacehost.framework (13.0.0 - 13.0.0.203) <27E95B18-6783-304B-905E-5227DF2A0692> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvacontrolsurfacehost.framework/Versions/A/dvacontrolsurfacehost
       0x121694000 -        0x1216d2fff +com.adobe.dvaaudiodeviceui.framework (13.0.0 - 13.0.0.203) <DE5CA40B-3C2D-3248-8B25-31963C74CF4B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaaudiodeviceui.framework/Versions/A/dvaaudiodeviceui
       0x121738000 -        0x1219a4fff +com.adobe.Registration.framework (13.0.0 - 13.0.0.203) <FDF6544B-8765-37B8-92F1-E6174CA79B20> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/Registration.framework/Versions/A/Registration
       0x121bd5000 -        0x121c85fff +com.adobe.dvascriptingES.framework (13.0.0 - 13.0.0.203) <14354C9C-B1D1-374E-8E85-651E0C625410> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvascriptingES.framework/Versions/A/dvascriptingES
       0x121d98000 -        0x121e7dff7 +com.adobe.IngestDialog.framework (13.0.0 - 13.0.0.203) <3B9AA0E2-B902-3AA1-9253-8FFDF21258EC> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/IngestDialog.framework/Versions/A/IngestDialog
       0x124dc8000 -        0x124de0fff  com.apple.security.csparser (3.0 - 58286.200.222) <7BC2CE7B-69F5-3A24-B4C2-52A7E075D9AD> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
       0x1271e4000 -        0x1271e6ffb  com.apple.textencoding.unicode (5.0 - 5.0) <8F8EAF7E-BE4A-363A-A855-B817C81CF951> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
       0x127289000 -        0x1272affef +com.mainconcept.mc.enc.dv (10.5 - 10.5.18.0000) <EA916625-DD33-3B51-AAB8-00A9AAFEB2A2> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_enc_dv.framework/mc_enc_dv
       0x1272c4000 -        0x1272c8fff  com.apple.audio.AppleHDAHALPlugIn (282.10 - 282.10) <94DDF962-09E0-3B3E-B887-9A0301022190> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
       0x12aa15000 -        0x12aa1bff7 +com.adobe.ExporterPNG.framework (13.0.0 - 13.0.0.203) <684C3499-A212-310C-970F-484F2353DC3A> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterPNG.bundle/Contents/MacOS/ExporterPNG
       0x12aa5e000 -        0x12aa65fff +com.adobe.ExporterAIFF.framework (13.0.0 - 13.0.0.203) <D42AD785-5CED-394D-A2A0-577FE73CBE14> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterAIFF.bundle/Contents/MacOS/ExporterAIFF
       0x12c6b2000 -        0x12c6eafff +com.adobe.pip (8.0.0.46.47979) <EAE71E0D-9079-34DF-97E2-341DCA74223D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
       0x12c7b8000 -        0x12c7bbffb +com.adobe.AfterEffects.Standard3D (0) <6F4D96AD-D80E-35BB-94C5-1FC47F6FF45C> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/Required/Standard3D.plugin/Contents/MacOS/Standard3D
       0x12c904000 -        0x12c907ff7 +FastCore (18.1.0 - 18.1.0) <7ACD8C31-E08B-303E-A024-73A7F35BD451> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/(AdobePSL)/extensions/FastCore.plugin/Contents/MacOS/FastCore
       0x12ec5e000 -        0x12edaeff7 +IMSLib.dylib (10.0.0.35 - 10.0.0.35) <0F67F73D-2BD4-3432-AB6F-47C632068CBB> /Library/Application Support/Adobe/*/IMSLib.dylib
       0x12edd2000 -        0x12ef43ff7 +imshelper.dylib (1.0.0.22 - 1.0.0.22) <D1014FA3-607E-3AA8-8D56-04723CF5EFB1> /Library/Application Support/Adobe/*/imshelper.dylib
       0x12f4a4000 -        0x12f4a7047  libobjc-trampolines.dylib (750) <B81473FA-927B-3852-BC34-66E66AAE24F4> /usr/lib/libobjc-trampolines.dylib
       0x12f4ad000 -        0x12f4cdff7 +com.adobe.ExporterDPX.framework (13.0.0 - 13.0.0.203) <38972A33-9C81-38CD-8878-5605614B1BBD> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterDPX.bundle/Contents/MacOS/ExporterDPX
       0x12f56d000 -        0x12f574ff7 +com.adobe.ExporterTIFF.framework (13.0.0 - 13.0.0.203) <4DB0D288-0373-3628-B6D0-0E6E5883A889> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterTIFF.bundle/Contents/MacOS/ExporterTIFF
       0x12f608000 -        0x12f61cfff +com.adobe.ExporterWave.framework (13.0.0 - 13.0.0.203) <38E080CE-E893-3992-993A-DCD891A171E6> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterWave.bundle/Contents/MacOS/ExporterWave
       0x12f6ca000 -        0x12f6cffff +com.adobe.ExporterTarga.framework (13.0.0 - 13.0.0.203) <165302D2-314E-36B8-B172-6C40E33F2263> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterTarga.bundle/Contents/MacOS/ExporterTarga
       0x12f815000 -        0x12f833fff +com.adobe.ExporterJPEG.framework (13.0.0 - 13.0.0.203) <6CB210B1-1B6B-3588-AC16-240FCC6F4F05> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterJPEG.bundle/Contents/MacOS/ExporterJPEG
       0x12fde2000 -        0x12fdebfff +com.adobe.ExporterGIF.framework (13.0.0 - 13.0.0.203) <D6676312-9542-3234-9DEE-86FEF1034EA5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterGIF.bundle/Contents/MacOS/ExporterGIF
       0x12fe9c000 -        0x12ffccff7 +com.adobe.ExporterP2.framework (13.0.0 - 13.0.0.203) <996AA587-A522-3CDB-9A66-B0FD740A9A33> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterP2.bundle/Contents/MacOS/ExporterP2
       0x130106000 -        0x130147fff +com.adobe.ExporterMPEGPreview.framework (13.0.0 - 13.0.0.203) <4BA1C714-0416-36FE-93A2-2AD3DF7C0D4D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterMPEGPreview.bundle/Contents/MacOS/ExporterMPEGPreview
       0x1301e5000 -        0x13021eff7 +com.mainconcept.mc.enc.aac (10.5 - 10.5.18.0000) <705CFB3A-7678-3F89-B96A-83657D1415FA> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_enc_aac.framework/Versions/10/mc_enc_aac
       0x1304b9000 -        0x130510fe7 +com.adobe.ExporterMP3.framework (13.0.0 - 13.0.0.203) <28B09975-319E-3986-8958-5754823E4B7F> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterMP3.bundle/Contents/MacOS/ExporterMP3
       0x13061b000 -        0x1306e4ff7  com.apple.AMDRadeonX4000GLDriver (2.0.36 - 2.0.0) <0A445D3B-E2FC-3808-AB69-0AF62ED70D14> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
       0x13172f000 -        0x131748fff +com.adobe.ImporterAVFoundation.framework (13.0.0 - 13.0.0.203) <E0C67E09-34CF-3BAF-B4CB-A7745093DB98> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ImporterAVFoundation.bundle/Contents/MacOS/ImporterAVFoundation
       0x13176d000 -        0x1317a1fff +com.adobe.PlatformAudioCodecs.framework (13.0.0 - 13.0.0.203) <AE4A2D98-0BD5-3EBE-A0C7-8DBFEA6B9158> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PlatformAudioCodecs.framework/Versions/A/PlatformAudioCodecs
       0x1317d4000 -        0x1317daff7 +com.mainconcept.mc.enc.mp2sr (10.5 - 10.5.18.0000) <B17D83C0-6733-3984-9DB4-56181F934BF2> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_enc_mp2sr.framework/Versions/10/mc_enc_mp2sr
       0x1317e0000 -        0x13180aff7 +libMOG_Framework.5.0.15.dylib (0) <85570972-CC5B-3B3A-BB97-43F74815F910> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMOG_Framework.5.0.15.dylib
       0x131828000 -        0x131837fff +com.mainconcept.mc.enc.mpa (10.5 - 10.5.18.0000) <F1C0C327-9096-34E6-B97D-EF0208AA0D07> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_enc_mpa.framework/Versions/10/mc_enc_mpa
       0x1348f1000 -        0x1349c9ff7 +REDMetal.dylib (0) <0C988F53-14FA-35D8-9F57-9A11C47CF981> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/REDMetal.dylib
       0x134cfb000 -        0x134d0bff7 +com.adobe.TransitionsMetaPlugin.framework (13.0.0 - 13.0.0.203) <8B08B8A2-75F4-34F5-B2F7-81AFC0094624> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/TransitionsMetaPlugin.prmp/Contents/MacOS/TransitionsMetaPlugin
       0x134d1f000 -        0x134d29fff +com.adobe.PremiereFiltersMetaPlugin.framework (13.0.0 - 13.0.0.203) <49ADBE01-36A9-3FDF-ACC4-3B11BC8DC8FE> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/PremiereFiltersMetaPlugin.prmp/Contents/MacOS/PremiereFiltersMetaPlugin
       0x135100000 -        0x135195fff +com.adobe.ImporterRED.framework (13.0.0 - 13.0.0.203) <C37B9839-199A-341A-8EB0-3E5346C1DF16> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ImporterRED.bundle/Contents/MacOS/ImporterRED
       0x1354a1000 -        0x1354b7ff7 +com.adobe.ImporterSensorManager.framework (13.0.0 - 13.0.0.203) <C1FDF1AA-1596-3DEC-BA05-C0790D51B639> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ImporterSensorManager.bundle/Contents/MacOS/ImporterSensorManager
       0x1354dc000 -        0x1354e3ff7 +LIST.dylib (0) <5189A970-DAC7-34AD-BF82-523E6349000A> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/LIST.dylib
       0x1354f4000 -        0x1354f7ffb +VAL.dylib (0) <6A7593E4-44AA-3361-9EF6-0EC7A4041BC4> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/VAL.dylib
       0x135600000 -        0x1357d0fe7 +com.adobe.PremierePro.OpenEXR (1.0 - 1.0) <5923A225-A8ED-05D1-CA50-B4A7EFA35DF0> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/OpenEXR Premiere.bundle/Contents/MacOS/OpenEXR Premiere
       0x135da0000 -        0x135e99fff +com.mainconcept.mc.demux.mp2 (10.5 - 10.5.18.0000) <4060AF33-C621-36CA-90DE-7FD1692B538F> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_demux_mp2.framework/Versions/10/mc_demux_mp2
       0x135eab000 -        0x135f66ff7 +com.adobe.ExporterXDCAMHD.framework (13.0.0 - 13.0.0.203) <ECAEABAB-6270-3C2C-BF11-48A907DB58C3> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterXDCAMHD.bundle/Contents/MacOS/ExporterXDCAMHD
       0x13602f000 -        0x13635afef +com.mainconcept.mc.enc.avcsr (10.5 - 10.5.17.9603) <677C9D0F-DFCF-39C0-AB6A-D5E9F8852AF2> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_enc_avcsr.framework/Versions/10/mc_enc_avcsr
       0x13647e000 -        0x13666ffe7 +com.mainconcept.mc.enc.mp2v (10.5 - 10.5.18.0000) <CD9D9A4B-F450-3CF9-82D8-B134AB167E80> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_enc_mp2v.framework/Versions/10/mc_enc_mp2v
       0x1366c3000 -        0x136a3cfff +com.mainconcept.mc.bc.enc.avc (10.5 - 10.5.18.0000) <CEC65258-20AA-3957-BE94-BC16FCF47E0D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_bc_enc_avc.framework/Versions/10/mc_bc_enc_avc
       0x136b76000 -        0x137301fff +libMXF_SDK.5.0.15.dylib (0) <9385AD7F-8D09-3761-8A2E-EFCDF6C8D1DF> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK.5.0.15.dylib
       0x1378c3000 -        0x1378f3fff +com.adobe.ARE (AdobeARE 1.5.02.41706 - 1.5.02.41706) <63D929CD-D174-328F-A35C-3F8336FC3070> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
       0x137c00000 -        0x137d5cfe7 +com.adobe.ExporterMPEG4.framework (13.0.0 - 13.0.0.203) <C294D9F9-98FD-319D-9584-7240A1CAC5F7> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterMPEG4.bundle/Contents/MacOS/ExporterMPEG4
       0x137e10000 -        0x137f24ff7 +com.mainconcept.mc.mux.mp2 (10.5 - 10.5.18.0000) <0146E5C7-A69D-3B7E-9DD5-ECD50804334D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_mux_mp2.framework/Versions/10/mc_mux_mp2
       0x137f3c000 -        0x137f75ff7 +com.adobe.RendererCPU.framework (13.0.0 - 13.0.0.203) <1BC4BE7F-C36E-3570-B241-966C77D3BA3B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/RendererCPU.framework/Versions/A/RendererCPU
       0x137fbc000 -        0x137fc9ff7 +BEZ.dylib (0) <A11BA203-09D8-3B06-9056-8782289120A9> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/BEZ.dylib
       0x137fd5000 -        0x137fe6fff +com.adobe.GPUKernels.framework (13.0.0 - 13.0.0.203) <AAEE818C-49D6-37F9-A990-2FF3E6CCE2E5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/GPUKernels.framework/Versions/A/GPUKernels
       0x138800000 -        0x138c55fff +quvis.wraptor (1.0 - 1) <540DAE90-F54B-3780-861A-D694BFB06310> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/wraptor.bundle/Contents/MacOS/wraptor
       0x139118000 -        0x1392e6fff +com.mainconcept.mc.enc.mp4v (10.5 - 10.5.18.0000) <B081472A-D511-3B55-BC6C-6DA4ACC5C428> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/mc_enc_mp4v.framework/Versions/10/mc_enc_mp4v
       0x13932a000 -        0x1393d1fcf +com.adobe.IPPMPEGDecoder.framework (13.0.0 - 13.0.0.203) <DEDBD963-5AEB-3893-B279-F74651C9BC1F> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/IPPMPEGDecoder.framework/Versions/A/IPPMPEGDecoder
       0x13950a000 -        0x13964cfff +com.adobe.ExporterMXF.framework (13.0.0 - 13.0.0.203) <5ED6FE2A-86D6-35DB-8ADB-3E27CB4F4F6C> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterMXF.bundle/Contents/MacOS/ExporterMXF
       0x1396f5000 -        0x139754fff +com.adobe.PlayerMediaCore.framework (13.0.0 - 13.0.0.203) <41019EB6-5746-379B-80AB-EF96B7145E1C> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/PlayerMediaCore.bundle/Contents/MacOS/PlayerMediaCore
       0x1397c3000 -        0x139844fff +com.adobe.ExporterMPEG2.framework (13.0.0 - 13.0.0.203) <7956252C-072A-3DC7-8AA6-D278340ABF6A> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterMPEG2.bundle/Contents/MacOS/ExporterMPEG2
       0x1398ab000 -        0x139900fff +com.adobe.ExporterQuickTimeHost.framework (13.0.0 - 13.0.0.203) <831886A5-DF0C-3400-A8A9-9976960A9C8E> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/Common/ExporterQuickTimeHost.bundle/Contents/MacOS/ExporterQuickTimeHost
       0x139943000 -        0x13995dff7 +com.adobe.QTWriter.framework (13.0.0 - 13.0.0.203) <CDC072A1-E088-3A76-9BEA-99C6CCA9BD61> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/QTWriter.framework/Versions/A/QTWriter
       0x13998a000 -        0x139a69fff +com.adobe.aelib.framework (16.0.0 - 16.0.0.235) <8823DA6F-48D2-3343-B369-98BFD1D13CEC> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/aelib.framework/aelib
       0x139bbb000 -        0x139c27fff +com.adobe.boost-test.framework (13.0.0 - 13.0.0.203) <C18C91E8-842C-35C0-AF3D-78A3427133A6> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/boost_test.framework/Versions/A/boost_test
       0x139cbc000 -        0x139d7eff7 +com.adobe.JP2K (1.2.2 - 1.2.2.41336) <5210D413-6DF1-337C-AE4B-EED426047288> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
       0x139dc6000 -        0x13a11dfff +com.adobe.MPS (AdobeMPS 5.8.1.41653 - 5.8.1.41653) <F4E72D92-835F-3736-892D-641BCDF3A25A> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
       0x13a198000 -        0x13a9b7fff +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 15.0.0.41785) <508ACD0B-9ED6-332B-B5A6-48B78DDF8FA5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
       0x13afcb000 -        0x13aff1ff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.41336 - 3.8.0.41336) <1C2D547C-0F9E-3170-AE6D-793E811E2601> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
       0x13b016000 -        0x13b03cfff +com.adobe.AXE16SharedExpat (AdobeAXE16SharedExpat 3.8.0.41336 - 3.8.0.41336) <0B10C368-525F-3F7B-B8BA-EA0B283F0B07> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedExpat
       0x13b061000 -        0x13b127ff7 +com.adobe.drawbotagm.framework (13.0.0 - 13.0.0.203) <D8340A84-F6D9-39F8-A119-7C6A479B06F8> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/drawbotagm.framework/Versions/A/drawbotagm
       0x13b1fb000 -        0x13b2befff +U.dylib (0) <38031625-81A5-39BC-B1A0-B861522AACC4> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/U.dylib
       0x13b3b3000 -        0x13b4c4ff7 +MEE.dylib (0) <1C0A0E74-2165-3FC3-B558-CBBCBE57C273> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/MEE.dylib
       0x13b5d7000 -        0x13b615ff7 +aedisplay.dylib (0) <98CC64CD-4E41-3D28-B7BB-3C479599A231> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/aedisplay.dylib
       0x13b659000 -        0x13b67efff +FILE.dylib (0) <746CEFCF-DDC4-3BE3-8340-DE3E02AA17F1> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/FILE.dylib
       0x13b6b4000 -        0x13b70bff7 +SLU.dylib (0) <B11E31A5-162E-3D40-9076-F7C78E9E03C2> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/SLU.dylib
       0x13b79e000 -        0x13b7b8ff7 +PREF.dylib (0) <E25E39F9-4352-317D-A55C-0867E74E0322> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PREF.dylib
       0x13b7da000 -        0x13b829fff +TDB.dylib (0) <F29DF640-2AC4-3F5F-8757-3F6ABE77302E> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TDB.dylib
       0x13b897000 -        0x13b8ccff7 +MC.dylib (0) <07433EE7-634D-3C89-9A25-5001D01C3E31> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/MC.dylib
       0x13b91e000 -        0x13b955ff7 +COR.dylib (0) <AC2F5434-9FFA-36B2-B17A-16FD3C8A001B> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/COR.dylib
       0x13b9b0000 -        0x13bca8fff +PF.dylib (0) <C37F67B1-402A-3487-AA1D-0C379FF79BBE> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PF.dylib
       0x13be29000 -        0x13c2f5fff +TXT.dylib (0) <81AE9D74-96BB-3408-810C-3E3D292E521D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TXT.dylib
       0x13c8d2000 -        0x13c924ff7 +TDL.dylib (0) <C0FB9135-9749-350D-9FF0-4A91C2200A4A> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/TDL.dylib
       0x13c964000 -        0x13c9a1fff +OM.dylib (0) <C0B9C6B8-B818-380B-8765-61AFFC811011> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/OM.dylib
       0x13c9df000 -        0x13ca03ff7 +P.dylib (0) <A2BA2BAE-BD87-39C6-9C15-DA1600D05806> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/P.dylib
       0x13ca1d000 -        0x13ca49ff7 +PREM.dylib (0) <0765EE18-9C08-3F46-BA9F-7A62B74E84FF> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PREM.dylib
       0x13ca99000 -        0x13cae0fff +SND.dylib (0) <C6321453-49CE-38D2-9B88-49162B04AD3A> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/SND.dylib
       0x13cb48000 -        0x13cd8ffff +PIN.dylib (0) <049E15C0-3FFE-3AC1-A90F-5FEF35BD751C> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PIN.dylib
       0x13cf86000 -        0x13cfb8ff7 +RG.dylib (0) <0A3F298F-0C59-386B-B79B-355E7A7AC193> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/RG.dylib
       0x13cffc000 -        0x13d0c3ff7 +FLT.dylib (0) <03BDE5DF-B369-394D-BE18-D539E0301EC5> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/FLT.dylib
       0x13d218000 -        0x13d26bfff +MSK.dylib (0) <FE09B94F-BC3E-3765-AAD9-AAFBAE3EE185> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/MSK.dylib
       0x13d2be000 -        0x13d379fff +FRP.dylib (0) <C5A05F27-84CF-32BF-92A7-5B97C0B162C1> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/FRP.dylib
       0x13d470000 -        0x13d489ff7 +PR.dylib (0) <D576175E-C0A4-3468-93B3-86ADE8F1B2C8> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PR.dylib
       0x13d4be000 -        0x13e71cff7 +BEE.dylib (0) <67085929-55A3-3D68-A1E9-CBDBEEBEBC52> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/BEE.dylib
       0x13fb1a000 -        0x13fb60ff3 +FLO.dylib (0) <B6454703-8E51-306B-8B3C-0FB138C7BFF1> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/FLO.dylib
       0x13fb82000 -        0x13fb92ff7 +PLUG.dylib (0) <CBB15694-EECE-344A-9AD0-E5E8DA8AAC73> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/PLUG.dylib
       0x13fbaf000 -        0x13fe03fd7 +com.adobe.AIDE (1.5.0 - 1.5.0.41688) <0342B9A3-C636-3CB7-BCC8-E1C672E393C6> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
       0x13fe37000 -        0x13ff1afff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.41336 - 3.8.0.41336) <F77B6193-5D17-304C-AEB1-51E8A543D747> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
       0x13ffc4000 -        0x140085ff7 +com.adobe.dvaplayer.framework (13.0.0 - 13.0.0.203) <3FDE29C3-7D4B-3C76-94DC-15CC13013161> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/dvaplayer.framework/Versions/A/dvaplayer
       0x14021e000 -        0x140236fff +com.adobe.eaurl.framework (13.0.0 - 13.0.0.203) <DA45BD43-AFCD-3F1E-8202-44D2A9739097> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/eaurl.framework/Versions/A/eaurl
       0x140264000 -        0x14254aff7 +com.adobe.psl (AdobePSL 15.1.0.41703 - 15.1.0.41703) <BF0F550E-CDE7-38EF-81A9-610D9896FA95> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
       0x142868000 -        0x143727fe7 +libmkl_intel_lp64.dylib (0) <783D2EDB-A8C3-3084-99DA-C78F4E3FC565> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libmkl_intel_lp64.dylib
       0x14392f000 -        0x145adaff7 +libmkl_intel_thread.dylib (0) <B4F72FD0-8AE6-3B01-B3F7-F1C1865ACE3A> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libmkl_intel_thread.dylib
       0x146340000 -        0x14a38ff37 +libmkl_avx512.dylib (0) <ACF63D70-A801-3F03-9FD4-85F3E63631BD> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libmkl_avx512.dylib
       0x14a655000 -        0x14e132f8f +libmkl_core.dylib (0) <18885A1C-38C8-3737-B201-15A9BEE85707> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/libmkl_core.dylib
       0x14eb00000 -        0x14ebe8ff7 +com.adobe.adobe_caps (adobe_caps 11.0.0.14 - 11.0.0.14) <471DBB2B-FEA4-31CF-AC2D-F9C37073B804> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
       0x15cb0e000 -        0x15cb56ff7 +com.adobe.AfterEffects.PNGIO (0) <27D8032D-35D7-3825-AA25-77F2567D3B8F> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/Format/PNGIO.plugin/Contents/MacOS/PNGIO
       0x15d09d000 -        0x15d105fff +com.adobe.AfterEffects.Advanced3D (0) <715DC996-5FB3-38BF-A335-60F16A7E69ED> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/Required/Advanced3D.plugin/Contents/MacOS/Advanced3D
       0x15d1ba000 -        0x15d214fff +com.adobe.AfterEffects.TIFF (0) <C7BB14B5-D3E7-3577-9D0D-7A6A758FAC16> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/Format/TIFF.plugin/Contents/MacOS/TIFF
       0x15db78000 -        0x15dc6eff7 +com.adobe.AfterEffects.Anywhere2 (0) <DF47357A-27A4-30B4-B39B-1BBF2372C19D> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/Extensions/Anywhere2.plugin/Contents/MacOS/Anywhere2
       0x15de00000 -        0x15f24cff7 +com.imagineersystems.mochashapeconverter4ae (6.0.0 - 6.0.0f23.g37cb12555413) <7B58BAE3-E703-30E9-A153-B25ECC682623> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/Effects/mochaAE/mocha shape converter for AE.plugin/Contents/MacOS/mochashapeconverter4ae
       0x15f464000 -        0x15f681fef +com.adobe.AfterEffects.OpenEXR (???) <415CEBC3-0C65-C2B9-DA34-EF176DF31828> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/Format/OpenEXR.plugin/Contents/MacOS/OpenEXR
       0x15f879000 -        0x15fcdbfed +com.adobe.ProImportAE (Pro Import AE version 8.00 - 8.00) <AC4080BD-55B3-9433-7BE1-371B4F0A5629> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/Format/ProImport/Pro Import AE.plugin/Contents/MacOS/Pro Import AE
       0x15fe96000 -        0x15fedeff7 +MMXCore (18.1.0 - 18.1.0) <71BD02ED-4F9F-37D8-A544-D619B7D18B43> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/(AdobePSL)/extensions/MMXCore.plugin/Contents/MacOS/MMXCore
       0x15ff6b000 -        0x15ffe3fff +MultiProcessor Support (18.1.0 - 18.1.0) <0E07BC92-23C7-3AF9-9514-AA673F811E02> /Applications/Adobe Media Encoder CC 2019/Adobe Media Encoder CC 2019.app/Contents/Plug-Ins/(AfterEffectsLib)/(AdobePSL)/extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
    0x7fff3e117000 -     0x7fff3e118ff7  libCyrillicConverter.dylib (73) <3C190A58-3420-3F4D-AA20-250F21679096> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
    0x7fff3e11c000 -     0x7fff3e137ff7  libJapaneseConverter.dylib (73) <5F03C58F-72BD-3CCB-833B-15590CD10BDB> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
    0x7fff3e138000 -     0x7fff3e159ffb  libKoreanConverter.dylib (73) <CFA3A1BE-55F8-3520-85BB-73B20E32F6EE> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
    0x7fff3e15a000 -     0x7fff3e15bff3  libLatin2Converter.dylib (73) <F977D9D7-9A61-336F-B0AD-8BC0C963711E> /System/Library/CoreServices/Encodings/libLatin2Converter.dylib
    0x7fff3e162000 -     0x7fff3e171ffb  libSimplifiedChineseConverter.dylib (73) <991F3402-E9C7-3BE3-BC60-73326DADB2D5> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
    0x7fff3e175000 -     0x7fff3e187ff3  libTraditionalChineseConverter.dylib (73) <CE960AF9-2041-321E-BC2C-3AD1347A18E2> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
    0x7fff3e19d000 -     0x7fff3e4faff7  com.apple.RawCamera.bundle (8.10.0 - 1031) <F311B880-6219-395B-8F79-02504DDA0010> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x7fff3e4fd000 -     0x7fff3e648ff7  com.apple.AMDMTLBronzeDriver (2.0.36 - 2.0.0) <39929A89-44C7-3534-B6A4-AA31B027414A> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
    0x7fff3e649000 -     0x7fff3edc0ff7  ATIRadeonX4000SCLib.dylib (2.0.36) <C19893B6-EE0A-3A4D-BF3F-5B1221942109> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib
    0x7fff452a4000 -     0x7fff452a8fff  com.apple.agl (3.3.2 - AGL-3.3.2) <81130C05-30AD-3BDA-BB9C-72ADDD5FAA2C> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x7fff452a9000 -     0x7fff45497ff3  com.apple.avfoundation (2.0 - 1540.118.2) <1EE74E35-F16B-3034-AEA5-723198E519F8> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
    0x7fff45498000 -     0x7fff45566ff7  com.apple.audio.AVFAudio (1.0 - ???) <727A6D92-D1F2-3179-80D3-51F1481F5A87> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
    0x7fff45674000 -     0x7fff45674fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <2C602CED-72CA-37C2-BDF5-31697FC9100B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff45675000 -     0x7fff4568bfe3  libCGInterfaces.dylib (506.19) <6455899E-BAC7-34D1-802B-FFE19A2337E2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fff4568c000 -     0x7fff45d2cfe3  com.apple.vImage (8.1 - ???) <65912AFB-D4C1-3494-AE97-DDFDAF3BE1EB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff45d2d000 -     0x7fff45fa4fd7  libBLAS.dylib (1243.200.4) <76710990-AE2B-300E-88BB-797ABAD74956> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff45fa5000 -     0x7fff46017fe7  libBNNS.dylib (38.200.5) <5F3A4021-8FF8-30E8-B84A-AA2BD70F4151> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
    0x7fff46018000 -     0x7fff463befff  libLAPACK.dylib (1243.200.4) <45722A8A-5788-3C4C-ADD9-1812763FA635> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff463bf000 -     0x7fff463d4ffb  libLinearAlgebra.dylib (1243.200.4) <E923DA33-B142-3A73-A80A-642878D19099> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fff463d5000 -     0x7fff463daff3  libQuadrature.dylib (3.200.2) <6FFAC142-415D-3AF0-BC09-336302F11934> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
    0x7fff463db000 -     0x7fff46458ffb  libSparse.dylib (79.200.5) <0D7E71A4-10D2-3979-B386-D2426ADAF6D7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
    0x7fff46459000 -     0x7fff4646cffb  libSparseBLAS.dylib (1243.200.4) <00D6FC17-B739-3259-90A4-92AC8BBE03D6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fff4646d000 -     0x7fff46651ff3  libvDSP.dylib (671.201.1) <716585BD-04D7-30A9-B315-689184275E38> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff46652000 -     0x7fff46707ff3  libvMisc.dylib (671.201.1) <EDA66C06-A11F-3EE5-96D5-B20893448899> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff46708000 -     0x7fff46708fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <DADD83A2-550F-3570-8D71-16614C6A4CE0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff468b9000 -     0x7fff476d8ff3  com.apple.AppKit (6.9 - 1671) <E1B2CAF1-9231-3B3D-BD9E-B770FE87F407> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff4772a000 -     0x7fff4772afff  com.apple.ApplicationServices (50.1 - 50.1) <1B71604B-9AC5-3A2F-8CB7-0EFA34A20F12> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff4772b000 -     0x7fff47796ff7  com.apple.ApplicationServices.ATS (377 - 453.11) <7599E619-EE21-3EB7-875B-AE3B8D3E13BB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff47797000 -     0x7fff47798ff7  ATSHI.dylib (453.11) <78D93611-C22F-39E6-AD4A-E0ABF620EE04> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
    0x7fff4782f000 -     0x7fff4794efff  libFontParser.dylib (228.6) <E800074F-62CF-340A-A5A7-B8BE5B560045> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fff4794f000 -     0x7fff4799afff  libFontRegistry.dylib (228.12) <480D472D-C8FB-321D-86EC-2EA6927A97AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff479f9000 -     0x7fff47a2cff7  libTrueTypeScaler.dylib (228.6) <D23BFDE4-8664-335A-B43B-A13A8EF29E40> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x7fff47a96000 -     0x7fff47a9aff3  com.apple.ColorSyncLegacy (4.13.0 - 1) <90641B6B-D07B-3577-B594-965825544B60> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
    0x7fff47b37000 -     0x7fff47b89ff3  com.apple.HIServices (1.22 - 627.14.2) <01F309D6-32E7-3C4F-A38B-8206EE3076CC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff47b8a000 -     0x7fff47b98ff3  com.apple.LangAnalysis (1.7.0 - 1.7.0) <67BC5855-B7A3-39E6-B5DD-52B287EB1532> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff47b99000 -     0x7fff47be5fff  com.apple.print.framework.PrintCore (14.0 - 503.7) <C13BC56A-65F4-35B1-9E33-51FE6F3B06FD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff47be6000 -     0x7fff47c21ff7  com.apple.QD (3.12 - 407.2) <94A30038-C545-327A-B1C0-E19C79D62BAB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff47c22000 -     0x7fff47c2eff7  com.apple.speech.synthesis.framework (8.0.15 - 8.0.15) <A96C744B-B1AD-32E3-BA72-7A221684BE3F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff47c2f000 -     0x7fff47ecbff7  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <89D2529D-CF36-3081-A700-70892F888718> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff47ecd000 -     0x7fff47ecdfff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <8B9A5ADB-E62C-3838-BB5E-AF20CAE449CC> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff47ece000 -     0x7fff4800eff3  com.apple.AudioVideoBridging (700.6 - 700.6) <B2BBFF05-AE27-36D2-8587-93C0DCB96C18> /System/Library/Frameworks/AudioVideoBridging.framework/Versions/A/AudioVideoBridging
    0x7fff48231000 -     0x7fff485f2ff7  com.apple.CFNetwork (974.1 - 974.1) <ACC604FA-5D40-34CE-9206-8091010306B7> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff48607000 -     0x7fff48607fff  com.apple.Carbon (158 - 158) <DAF95685-B793-34EB-96EA-3E292A9E3378> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff48608000 -     0x7fff4860bffb  com.apple.CommonPanels (1.2.6 - 98) <F1E1C47B-FD1A-30A4-B41B-87BD8B178B56> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff4860c000 -     0x7fff48913ff7  com.apple.HIToolbox (2.1.1 - 916.32) <B2ED8B1C-FC3E-3FA0-8F6D-E7A448E6FAA7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff48914000 -     0x7fff48917ffb  com.apple.help (1.3.8 - 66) <4392A63F-9B58-3248-BF73-B46AD3744E6E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff48918000 -     0x7fff4891dff7  com.apple.ImageCapture (9.0 - 1529.7) <364EDC6B-6374-31A7-A637-0044B73F8DBF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff4891e000 -     0x7fff489b2ff3  com.apple.ink.framework (10.9 - 225) <D6503F37-7EBC-32C1-95CC-A35EFC54E7ED> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff489b3000 -     0x7fff489cdfff  com.apple.openscripting (1.7 - 178) <D4A4D130-9C7B-3656-9D58-50F9D09C276E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff489ee000 -     0x7fff489effff  com.apple.print.framework.Print (14.0 - 267.3) <5CD250DF-98AD-30B8-A5D5-47634FF9E74D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff489f0000 -     0x7fff489f2ff7  com.apple.securityhi (9.0 - 55006) <C5308CBC-6736-31A7-905B-C635C6D43FDE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff489f3000 -     0x7fff489f9ff7  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <1C38B9CB-DD45-3A7B-9D4C-631855A4EE32> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff48b20000 -     0x7fff48b20fff  com.apple.Cocoa (6.11 - 23) <A520D2A3-032B-3C06-81E1-EFDD97C47ACE> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff48b2e000 -     0x7fff48bfafff  com.apple.ColorSync (4.13.0 - 3340) <0618DA46-5A5E-339D-BB2F-ED66A2BFCCF9> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff48d95000 -     0x7fff48e25fff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <5845D43B-BBB5-343B-A164-6F9E2C53CFA3> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff48e27000 -     0x7fff48e8aff7  com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <2156EBFF-88B6-38C5-A16E-F12ACE8DFB25> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
    0x7fff48e8b000 -     0x7fff48eb6ff7  com.apple.CoreBluetooth (1.0 - 1) <D2F48E3D-79FC-32D7-B281-658EAD2CC50B> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fff48eb7000 -     0x7fff49257feb  com.apple.CoreData (120 - 865.2) <90A5058F-A5AF-311A-81CC-B20C2AC9E85E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff49258000 -     0x7fff49341fff  com.apple.CoreDisplay (101.3 - 101.17.6) <4AE5C221-B8E1-3A4F-91E0-96ED5926E82B> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fff49342000 -     0x7fff49791fff  com.apple.CoreFoundation (6.9 - 1555.10) <4A4C87BC-4C8E-392A-ABEE-824D4074C485> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff49793000 -     0x7fff49e20fff  com.apple.CoreGraphics (2.0 - 1245.8.4.8) <FFFFEAF0-14DD-38A3-BD68-AA9AB2C672C1> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff49e22000 -     0x7fff4a147ff7  com.apple.CoreImage (14.0.0 - 700.2.220) <E9E7B27C-C4FD-3AD6-923E-DF7EAE36D1FF> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff4a1ca000 -     0x7fff4a226ff7  com.apple.audio.midi.CoreMIDI (1.10 - 88) <32CA3EA2-E1A4-34AC-97A6-5E71C2B10E6C> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
    0x7fff4a499000 -     0x7fff4a59aff3  com.apple.CoreMedia (1.0 - 2280.133.4) <5E733D6B-B683-3931-9D02-82300A43378D> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fff4a59b000 -     0x7fff4a5fdfff  com.apple.CoreMediaIO (900.0 - 5025) <BFB3978A-FDBB-352B-A96D-E8761FC51370> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
    0x7fff4a5fe000 -     0x7fff4a5fefff  com.apple.CoreServices (933 - 933) <B79C910E-93B9-3686-8E72-E0B63083AAE5> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff4a5ff000 -     0x7fff4a67dffb  com.apple.AE (768 - 768) <E795749D-CE50-3B8C-91A7-8C2618887288> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff4a67e000 -     0x7fff4a956ff7  com.apple.CoreServices.CarbonCore (1178.11 - 1178.11) <9FBE7BFB-3A81-37AC-8E15-E6F7932BBDC0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff4a957000 -     0x7fff4a9a1ff7  com.apple.DictionaryServices (1.2 - 284.16.3) <D9388630-E7F2-321E-81FF-EBD5F3B47A52> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff4a9a2000 -     0x7fff4a9aaffb  com.apple.CoreServices.FSEvents (1239.200.12 - 1239.200.12) <E40A3C4A-79C7-37D8-999B-D1169A06870B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fff4a9ab000 -     0x7fff4ab76ff7  com.apple.LaunchServices (933 - 933) <4614A4B4-C358-3460-9FA7-DF8D6C466806> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff4ab77000 -     0x7fff4ac19ffb  com.apple.Metadata (10.7.0 - 1191.51) <6B9CCA98-6F68-3908-A7A9-96D3E2AE5968> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff4ac1a000 -     0x7fff4ac65ff7  com.apple.CoreServices.OSServices (933 - 933) <A92C846F-872D-3534-B60E-6CD445A9BAEE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff4ac66000 -     0x7fff4acd4ff7  com.apple.SearchKit (1.4.0 - 1.4.0) <C6A34D09-9707-3F28-838F-63B59B8A12D5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff4acd5000 -     0x7fff4acf9ffb  com.apple.coreservices.SharedFileList (71.27 - 71.27) <B46A15E0-4C10-3616-BE49-58E07EC463FE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fff4b03c000 -     0x7fff4b1a1fff  com.apple.CoreText (352.0 - 584.24) <5B55B533-F4DE-32CE-8739-16FFFA1A64F8> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff4b1a2000 -     0x7fff4b1dffff  com.apple.CoreVideo (1.8 - 0.0) <C7BB7D0F-3AF2-3046-A387-A802BCA52A3A> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff4b1e0000 -     0x7fff4b276ffb  com.apple.framework.CoreWLAN (13.0 - 1370.8) <19E41424-B956-34DF-AE02-9822308FA3DC> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fff4b412000 -     0x7fff4b4ccff7  com.apple.DiscRecording (9.0.3 - 9030.4.5) <55E40DE0-500B-3AC4-81BA-4A54BC04740C> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x7fff4b4f3000 -     0x7fff4b4f8fff  com.apple.DiskArbitration (2.7 - 2.7) <C53C1905-9BCF-3AE8-8BB3-C8A2C7DB7D25> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff4b6c1000 -     0x7fff4ba8ffff  com.apple.Foundation (6.9 - 1555.10) <0CCAF9AF-F7AF-3174-98D4-6C188B1079CC> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff4bb00000 -     0x7fff4bb30ff3  com.apple.GSS (4.0 - 2.0) <74ACB1A1-A5A4-3180-AC00-688C94AA4434> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff4bc49000 -     0x7fff4bd52ff3  com.apple.Bluetooth (6.0.8 - 6.0.8f6) <6CB8A08E-1154-3333-83CC-2A939AC94562> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fff4bdb4000 -     0x7fff4be45fff  com.apple.framework.IOKit (2.0.2 - 1483.201.1) <DA4ED91F-2CC9-3CFD-9200-9D5D31EEE4F3> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff4be47000 -     0x7fff4be51ff7  com.apple.IOSurface (255.1 - 255.1) <538F0257-A408-36AF-AB1E-1D7037D6359E> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff4bea8000 -     0x7fff4c03cff7  com.apple.ImageIO.framework (3.3.0 - 1796.5.4.1) <9D078F50-BB75-3D04-8636-3FDDAB9C95DA> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff4c03d000 -     0x7fff4c041ffb  libGIF.dylib (1796.5.4.1) <93AD6FB9-03BA-350E-AF98-D371A2BFD58F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff4c042000 -     0x7fff4c127fef  libJP2.dylib (1796.5.4.1) <3780EB9B-5219-385D-9472-17B0397697A5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff4c128000 -     0x7fff4c14dff7  libJPEG.dylib (1796.5.4.1) <83CA8BEB-34BD-3B58-A704-C6A875984FAD> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff4c420000 -     0x7fff4c446fe7  libPng.dylib (1796.5.4.1) <9F30FA63-8AB2-3646-A6A8-FCE9F8436C35> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff4c447000 -     0x7fff4c449ff7  libRadiance.dylib (1796.5.4.1) <2C07887C-0584-3538-A9EC-3988AA5B234B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff4c44a000 -     0x7fff4c498fff  libTIFF.dylib (1796.5.4.1) <F420B0DC-D0F7-3DD5-9E17-00462441635C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff4c794000 -     0x7fff4d516ff7  com.apple.JavaScriptCore (14606 - 14606.1.36.1.9) <7FF80E53-3D6B-33BF-9538-A263513475EC> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x7fff4d52e000 -     0x7fff4d547fff  com.apple.Kerberos (3.0 - 1) <8BE3D524-257D-3663-A937-F1AC76BDF4D9> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff4d548000 -     0x7fff4d57dffb  com.apple.LDAPFramework (2.4.28 - 194.5) <DC361FB9-4B59-311E-8CC5-07FF9A9C673F> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x7fff4d804000 -     0x7fff4d80efff  com.apple.MediaAccessibility (1.0 - 114.4) <29D89F2B-6254-3D0D-BD0C-8472FCA373F4> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
    0x7fff4d8c8000 -     0x7fff4df64ff7  com.apple.MediaToolbox (1.0 - 2280.133.4) <FB1C3DD9-A91B-3952-A892-9F009B854F8F> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x7fff4df66000 -     0x7fff4dff9fff  com.apple.Metal (157.55 - 157.55) <49CD402F-20CB-3930-B997-BBDC495ABF64> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fff4dffb000 -     0x7fff4e015ff3  com.apple.MetalKit (1.0 - 113) <8949A0FA-337E-3C28-94D1-35853D69761B> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
    0x7fff4e016000 -     0x7fff4e036ff7  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <9A841A76-43BC-3220-A4DA-99137C42A0BC> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
    0x7fff4e037000 -     0x7fff4e0b4fef  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <C469D1E5-F621-3E56-87AC-1BD889664FA3> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
    0x7fff4e0b5000 -     0x7fff4e0ddfff  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <8C57A3A2-8EBB-3401-87FC-368D1BE6DAAC> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
    0x7fff4e0de000 -     0x7fff4e205ff7  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <CE3201A3-4ACE-3E79-990B-8987C576B31B> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
    0x7fff4e206000 -     0x7fff4e221ff7  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <8F02CFCA-41E1-3194-915F-3106E8B48B32> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
    0x7fff4e222000 -     0x7fff4e222ff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <8B715D78-8357-38F4-A03C-926EE967CE71> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
    0x7fff4f421000 -     0x7fff4f42dffb  com.apple.NetFS (6.0 - 4.0) <529E29A9-5E77-3A8C-A982-CF55F949FE5D> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fff51ee4000 -     0x7fff51eecfe7  libcldcpuengine.dylib (2.9.6) <48AB98D8-1098-3B1D-8AFD-17B40F7A2F5D> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
    0x7fff51eed000 -     0x7fff51f46ff7  com.apple.opencl (2.12.1 - 2.12.1) <3EAE5BC8-E948-3926-9319-9DAC2A8B5484> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff51f47000 -     0x7fff51f63ff7  com.apple.CFOpenDirectory (10.14 - 207.200.4) <7E4EFF02-2596-31E6-88DE-29C89E2837E4> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff51f64000 -     0x7fff51f70ffb  com.apple.OpenDirectory (10.14 - 207.200.4) <52A3918E-0F7A-33FD-87EE-21A37B37D13B> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff528d3000 -     0x7fff528d5fff  libCVMSPluginSupport.dylib (17.0.37) <38A18A32-BBF2-3A0F-AE37-51734B6CA91A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fff528d6000 -     0x7fff528dbff3  libCoreFSCache.dylib (163.20) <BF8F04DD-C1A1-3D2A-BF3F-639FE907E28D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fff528dc000 -     0x7fff528e0fff  libCoreVMClient.dylib (163.20) <45A2C724-F3D1-316A-9A41-CAB8E2A390EC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff528e1000 -     0x7fff528e9ffb  libGFXShared.dylib (17.0.37) <267B40DF-2939-3D76-89FA-E8DBDEE96D92> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff528ea000 -     0x7fff528f5fff  libGL.dylib (17.0.37) <2E25A83B-B560-34A1-B474-3027C8B75BA4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff528f6000 -     0x7fff52930fef  libGLImage.dylib (17.0.37) <49C5F799-66E5-3A81-AF88-948DD0E583FA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff52931000 -     0x7fff52aa3ff3  libGLProgrammability.dylib (17.0.37) <8A5E29FF-04DA-33D4-9F5F-B896CC967386> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fff52aa4000 -     0x7fff52ae1fff  libGLU.dylib (17.0.37) <79555E42-B816-3106-8FA0-FC14A54AE8B3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff53491000 -     0x7fff534a0ff3  com.apple.opengl (17.0.37 - 17.0.37) <FA76EAA6-D035-3444-87F5-DD95446D651D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff534a1000 -     0x7fff53637ff7  GLEngine (17.0.37) <0A43977A-AA0D-3B05-AC7E-C7A8BFB3B449> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
    0x7fff53638000 -     0x7fff53660ff7  GLRendererFloat (17.0.37) <F7461A91-0F80-336E-9CC5-9A777A454D28> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x7fff542fc000 -     0x7fff54552fff  com.apple.QuartzCore (1.11 - 693.16.4.2) <2C9E3279-3F97-3440-B937-E5FE888232E2> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff54553000 -     0x7fff545acff7  com.apple.QuickLookFramework (5.0 - 775) <A4CA709A-2828-3F04-8786-7FAC8A95B98B> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x7fff54d87000 -     0x7fff54d9ffff  com.apple.ScriptingBridge (1.4 - 77) <3502C869-965C-3D65-AC25-D18636CBA127> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
    0x7fff54da0000 -     0x7fff550c6fff  com.apple.security (7.0 - 58286.200.222) <AEB638D9-BFE9-319E-A70B-557ACF41117A> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff550c7000 -     0x7fff55156fff  com.apple.securityfoundation (6.0 - 55185.200.14) <770D67D1-3DA6-3FD3-8531-376712BA4F60> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff55188000 -     0x7fff5518cff3  com.apple.xpc.ServiceManagement (1.0 - 1) <20DB899D-3BAF-36FD-86A6-F66A82074607> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fff55549000 -     0x7fff555b9ff3  com.apple.SystemConfiguration (1.17 - 1.17) <EED5BC9B-CE8D-343C-BCDC-04A79F704828> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff5581a000 -     0x7fff55b7cff7  com.apple.VideoToolbox (1.0 - 2280.133.4) <468A9F6D-33AB-31D3-A8A3-A6A432033C9E> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x7fff55e8a000 -     0x7fff56418ff7  libwebrtc.dylib (7606.1.36.1.9) <9D8EADA7-921A-377C-8B0F-5A1D42AC43A7> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
    0x7fff56419000 -     0x7fff57c99ff7  com.apple.WebCore (14606 - 14606.1.36.1.9) <099B8FA5-D49D-3C7E-B40A-613CA6E7B769> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
    0x7fff57c9a000 -     0x7fff57e89ffb  com.apple.WebKitLegacy (14606 - 14606.1.36.1.9) <60C1D461-49C9-3B8B-9BD4-B95F1D18335F> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
    0x7fff57e8a000 -     0x7fff58387fff  com.apple.WebKit (14606 - 14606.1.36.1.9) <5E4AF277-D207-3647-9D5C-A6F1543A2D4D> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
    0x7fff5881e000 -     0x7fff588c3ff7  com.apple.APFS (1.0 - 1) <CBE5EE83-7A5F-3C10-93FF-F6DA84DFB875> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
    0x7fff58e4c000 -     0x7fff58e52ff3  com.apple.accessibility.AXCoreUtilities (1.0 - 1) <A10AB2DC-7C65-3FC0-8416-246003D158A6> /System/Library/PrivateFrameworks/AXCoreUtilities.framework/Versions/A/AXCoreUtilities
    0x7fff592ff000 -     0x7fff59300ff3  com.apple.AggregateDictionary (1.0 - 1) <1DEBBE36-8945-3AD8-BD48-2850AD845711> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
    0x7fff598fb000 -     0x7fff59927ff7  com.apple.framework.Apple80211 (13.0 - 1375.14) <79EBF155-EAB2-37EE-BF8C-57BC453217B1> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fff59c03000 -     0x7fff59c12fcf  com.apple.AppleFSCompression (96.200.3 - 1.0) <E093776E-C367-3CCF-BFD5-623476A89E9A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fff59d10000 -     0x7fff59d1bfff  com.apple.AppleIDAuthSupport (1.0 - 1) <5362D9AD-A2AE-3436-97CE-C353124504E5> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
    0x7fff59d5c000 -     0x7fff59da5ff3  com.apple.AppleJPEG (1.0 - 1) <9A690E6E-F987-3660-BED6-B1A4D1906B6C> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fff59ff0000 -     0x7fff59ff4ff7  com.apple.AppleSRP (5.0 - 1) <B8E2BEC9-FAFB-3E26-BF26-E2E58C545006> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
    0x7fff59ff5000 -     0x7fff5a01dff7  com.apple.applesauce (1.0 - ???) <60BB16D6-DE7E-356A-B9DE-F73EE179934A> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
    0x7fff5a0e8000 -     0x7fff5a138fff  com.apple.AppleVAFramework (5.0.44 - 5.0.44) <F7B8CD3A-8671-3B2C-B67C-CE39C1442207> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fff5a183000 -     0x7fff5a199ffb  com.apple.AssertionServices (1.0 - 1) <8FB0D908-6C46-3399-92D6-4E7D4B5F4F19> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
    0x7fff5a3a6000 -     0x7fff5a3beff3  com.apple.AudioServerApplication (1.0 - 400.4) <3CEB592E-6FA6-37DA-9726-531F9E2F22E1> /System/Library/PrivateFrameworks/AudioServerApplication.framework/Versions/A/AudioServerApplication
    0x7fff5a4c9000 -     0x7fff5a76cffb  com.apple.AuthKit (1.0 - 1) <ED375339-69F6-34AE-825D-F16BF0618E3E> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
    0x7fff5a93d000 -     0x7fff5a946ff3  com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <972F41B3-7DF7-3BF1-ACCA-A093A4328ADF> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
    0x7fff5a947000 -     0x7fff5a9e9ff7  com.apple.backup.framework (1.10 - ???) <46534B04-DD0E-357B-9CB5-F88AAC6AF4ED> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fff5a9ea000 -     0x7fff5aa5bffb  com.apple.BaseBoard (360.18.4 - 360.18.4) <709EF03C-5BCE-3F47-BD58-A48C1F9378A5> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
    0x7fff5aae4000 -     0x7fff5ab20ffb  com.apple.bom (14.0 - 197) <8BD14107-DB70-3800-9377-618CA230B40A> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x7fff5b8fd000 -     0x7fff5b94afff  com.apple.ChunkingLibrary (194 - 194) <13F1F769-E8E7-372A-8F0B-2BB4B7753248> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fff5b9f2000 -     0x7fff5ba81ffb  com.apple.CloudDocs (1.0 - 575.120) <94232936-1B40-3EAF-B731-883A4872BCE4> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
    0x7fff5c60a000 -     0x7fff5c613fff  com.apple.CommonAuth (4.0 - 2.0) <7105F266-35C3-3582-9383-A2A9D7184A7B> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fff5cac3000 -     0x7fff5ce9afef  com.apple.CoreAUC (273.0.0 - 273.0.0) <288EC7ED-A86A-30D0-ADE2-56C33CD93AA8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x7fff5ce9b000 -     0x7fff5ceccfff  com.apple.CoreAVCHD (6.0.0 - 6000.4.1) <507AC58B-4527-353B-99CB-67FF183BD4D5> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
    0x7fff5cee9000 -     0x7fff5cf0bfff  com.apple.CoreAnalytics.CoreAnalytics (1.0 - 1) <698E1B63-B193-3431-A1C7-9B8D2D62088C> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
    0x7fff5d0f9000 -     0x7fff5d102fff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <8D971ACD-6A26-30A9-9C5B-BCBF60A661F1> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
    0x7fff5d310000 -     0x7fff5d323fff  com.apple.CoreEmoji (1.0 - 69.15.9) <011E7853-BDD6-3197-BA8D-D6B977EF56EB> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
    0x7fff5d8f9000 -     0x7fff5d96bff7  com.apple.CoreNLP (1.0 - 130.15.22) <401F5284-A984-32A1-A547-CC8156381070> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
    0x7fff5daee000 -     0x7fff5daf2ff7  com.apple.CoreOptimization (1.0 - 1) <AEF88F43-C928-3DCB-95D6-C6706B565422> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
    0x7fff5dc26000 -     0x7fff5dc2effb  com.apple.CorePhoneNumbers (1.0 - 1) <F47CA56F-6760-3282-BFD8-C8C8D2C33ECF> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
    0x7fff5dc2f000 -     0x7fff5dc8bfff  com.apple.CorePrediction (1.0 - 1) <BD34AB8C-8899-3BB1-95A2-0A2A1C901ADC> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
    0x7fff5ddbd000 -     0x7fff5ddeefff  com.apple.CoreServicesInternal (357 - 357) <2D012EB3-83BF-3E51-A2BE-41AF26F2DDF0> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fff5e1b3000 -     0x7fff5e241ff7  com.apple.CoreSymbolication (10.0 - 64235.3.1) <912C63C0-473B-3352-A255-60F7CA3FE3F2> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fff5e2d1000 -     0x7fff5e3fdfff  com.apple.coreui (2.1 - 498.46) <05F9736C-5A62-33B3-9607-551A332AEF28> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff5e3fe000 -     0x7fff5e57dffb  com.apple.CoreUtils (5.7 - 570.70) <2554BA12-16A2-399F-A13A-E5C8EB4FC1EC> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
    0x7fff5e5d4000 -     0x7fff5e637ffb  com.apple.framework.CoreWiFi (13.0 - 1370.8) <5C6ACF32-14D3-35FD-8A4A-629521090F41> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fff5e638000 -     0x7fff5e649ffb  com.apple.CrashReporterSupport (10.13 - 938.23) <36754BB2-680F-36AE-A5DE-548B4F41F0AE> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fff5e6cc000 -     0x7fff5e6dbff3  com.apple.framework.DFRFoundation (1.0 - 210) <61EF0583-E946-3201-932D-7D117BC62CB2> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
    0x7fff5e6dc000 -     0x7fff5e6e0ff7  com.apple.DSExternalDisplay (3.1 - 380) <B6B26BB3-2DC9-34D0-817E-EB612432EC96> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
    0x7fff5e763000 -     0x7fff5e7daffb  com.apple.datadetectorscore (7.0 - 590.24) <2D4CFF51-BCD4-3D08-AE73-AB2B8BEC8659> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fff5e828000 -     0x7fff5e869fff  com.apple.DebugSymbols (185 - 185) <01F561DA-4724-32FD-B2C7-6436F4CEB980> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fff5e86a000 -     0x7fff5e9c3ff7  com.apple.desktopservices (1.13 - ???) <053D3A96-9263-3242-8625-101DDB9350DE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff5eaf5000 -     0x7fff5ebc7ff7  com.apple.DiskImagesFramework (480.201.1 - 480.201.1) <54D2F7DC-DAA6-3667-9590-1407C7B738EC> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x7fff5ebc8000 -     0x7fff5ec8cfff  com.apple.DiskManagement (12.0 - 1530) <F844A618-613A-3609-9C31-621D92FB75DD> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
    0x7fff5ed32000 -     0x7fff5ed35fff  com.apple.EFILogin (2.0 - 2) <8FCA68D2-CEA5-39F6-B222-AC31FCF79D1D> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
    0x7fff5fa07000 -     0x7fff5fe2ffff  com.apple.vision.FaceCore (3.3.4 - 3.3.4) <CCBC466A-1AD4-3B0B-80B2-D6CFCBB37FC0> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fff5fe62000 -     0x7fff5feeeff7  com.apple.FileProvider (125.129 - 125.129) <31642A56-F183-3DA3-8713-745358CAE55D> /System/Library/PrivateFrameworks/FileProvider.framework/Versions/A/FileProvider
    0x7fff63751000 -     0x7fff63752fff  libmetal_timestamp.dylib (902.1.49) <F0C95234-16BA-3F0B-A11E-087ABDC8DD6C> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
    0x7fff64deb000 -     0x7fff64df6ff7  libGPUSupportMercury.dylib (17.0.37) <E8A195F4-E2E4-3EB5-AF21-856EBA145436> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
    0x7fff64df7000 -     0x7fff64dfcff7  com.apple.GPUWrangler (3.22.9 - 3.22.9) <A7FF28DC-3576-3E53-AFAF-0E29CB45E9AE> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
    0x7fff651ac000 -     0x7fff651d1ff7  com.apple.GenerationalStorage (2.0 - 285.101) <089301DF-60C9-3BED-9357-2F91336C1579> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fff65c5b000 -     0x7fff65c6afff  com.apple.GraphVisualizer (1.0 - 5) <C7040CD7-6CAB-3878-B29E-21F1665341D0> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
    0x7fff65c6b000 -     0x7fff65c78fff  com.apple.GraphicsServices (1.0 - 1.0) <F099E6ED-E08D-3F37-B381-0DF3109B27AA> /System/Library/PrivateFrameworks/GraphicsServices.framework/Versions/A/GraphicsServices
    0x7fff65d51000 -     0x7fff65dc5fff  com.apple.Heimdal (4.0 - 2.0) <793E1D31-6166-37F2-A989-F98FE1706E5D> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fff65dc6000 -     0x7fff65df5fff  com.apple.HelpData (2.3 - 184) <56A7277E-B1C3-3AD8-AF4B-8BAA41D6E640> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
    0x7fff67197000 -     0x7fff671a0fff  com.apple.IOAccelMemoryInfo (1.0 - 1) <A2E867B2-615D-393C-A2C7-D2B83B56756D> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
    0x7fff671a1000 -     0x7fff671a8ffb  com.apple.IOAccelerator (400.24 - 400.24) <01551ED8-6AE1-307D-A3F0-DCA85FAA5210> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fff671ac000 -     0x7fff671c5ff7  com.apple.IOPresentment (1.0 - 37) <751130A1-8639-3BDA-BF8F-A3BE54427E43> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
    0x7fff675d8000 -     0x7fff67607ff7  com.apple.IconServices (379 - 379) <BE9E71B4-C00E-317D-9093-6E637C905A09> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fff67732000 -     0x7fff67736fff  com.apple.InternationalSupport (1.0 - 10.15.6) <F0E300AD-1E67-3D57-B179-C2212F7CD00C> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
    0x7fff678a6000 -     0x7fff678b9fff  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <10A17A9D-564E-3841-A433-D6D7401ED733> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
    0x7fff678d4000 -     0x7fff679cbfff  com.apple.LanguageModeling (1.0 - 159.15.15) <E524CC46-42C7-3046-AD6C-5D5D768EA478> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fff679cc000 -     0x7fff67a0dff7  com.apple.Lexicon-framework (1.0 - 33.15.10) <90C1CFE1-9935-3F4F-8A9B-1DD697F2FF3D> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
    0x7fff67a14000 -     0x7fff67a1aff7  com.apple.LinguisticData (1.0 - 238.15.29) <D27B30BA-3F5D-3AF2-895C-3B64569EEA1B> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
    0x7fff68277000 -     0x7fff6827afff  com.apple.Mangrove (1.0 - 25) <8744DBF9-3375-392C-8EE6-24373E0D19E8> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
    0x7fff68398000 -     0x7fff683cbff3  com.apple.MediaKit (16 - 906) <15D4EDA2-AAAC-3CF3-BB2B-3A92AECC932D> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x7fff68774000 -     0x7fff6879cffb  com.apple.spotlight.metadata.utilities (1.0 - 1191.51) <7CD28A81-F0D6-3575-8F83-3D45D53F72BB> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
    0x7fff6879d000 -     0x7fff6882ffff  com.apple.gpusw.MetalTools (1.0 - 1) <60BE7793-D8DE-3DF1-94D7-503301EC1E72> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
    0x7fff68844000 -     0x7fff6885dfff  com.apple.MobileAssets (1.0 - 437.200.49) <0C9B7077-BFCF-3A2E-8F54-D7C2820893FD> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
    0x7fff6886f000 -     0x7fff689d8fc7  com.apple.mobiledevice (988.200.73.100.1 - 988.200.73.100.1) <EB2F212B-FDEB-30D8-9678-0F2DE2E2EBA6> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
    0x7fff689d9000 -     0x7fff689f4fff  com.apple.MobileKeyBag (2.0 - 1.0) <E9F2FF73-22D0-35B5-BD2C-9DD8FDB12BCC> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
    0x7fff68a82000 -     0x7fff68aacff7  com.apple.MultitouchSupport.framework (2400.15 - 2400.15) <A2BB198C-0B1A-3988-8611-9A9BCCE650B5> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff68d1e000 -     0x7fff68d28fff  com.apple.NetAuth (6.2 - 6.2) <55DC741A-A01A-380C-B2D3-244241DA1F2C> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fff695f3000 -     0x7fff69649fff  com.apple.OTSVG (1.0 - ???) <A0E0FC0B-B48F-3639-9C50-BAECC72988D5> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
    0x7fff6a7ac000 -     0x7fff6a7bbff3  com.apple.PerformanceAnalysis (1.217 - 217) <8560F263-31F4-3CCA-84B1-30C296DC1A7D> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fff6c323000 -     0x7fff6c335ff3  com.apple.PowerLog (1.0 - 1) <F921C10F-11EC-3D68-91FD-CA836F1B26CE> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
    0x7fff6c71c000 -     0x7fff6c773fff  com.apple.ProtectedCloudStorage (1.0 - 1) <737DEC8B-342E-3BB2-AF69-D4428D467E4E> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
    0x7fff6c774000 -     0x7fff6c792ff7  com.apple.ProtocolBuffer (1 - 263) <C5AC21FB-74AD-3FC2-B231-B1376751BBAE> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fff6c92a000 -     0x7fff6c940ff3  com.apple.QuickLookThumbnailing (1.0 - 1) <AAF7A93C-5553-3476-B2F2-B8B1DA2BEF54> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
    0x7fff6c941000 -     0x7fff6c999f0f  com.apple.ROCKit (24 - 24) <5437F6F7-453F-3D75-9E87-D2A090D82D25> /System/Library/PrivateFrameworks/ROCKit.framework/Versions/A/ROCKit
    0x7fff6ca5a000 -     0x7fff6ca66ff3  com.apple.xpc.RemoteServiceDiscovery (1.0 - 1336.201.2) <FB030135-1633-378F-A7A6-B1A81AD068A2> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
    0x7fff6ca79000 -     0x7fff6ca9cffb  com.apple.RemoteViewServices (2.0 - 128) <68530B4D-B2C0-3271-941B-D9EA62095727> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fff6ca9d000 -     0x7fff6cab1fff  com.apple.xpc.RemoteXPC (1.0 - 1336.201.2) <1E00A78B-1934-39A0-8F35-48CBEB93D04C> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
    0x7fff6d908000 -     0x7fff6d952ff7  com.apple.Safari.SafeBrowsing (606 - 606.1.36.1.9) <5ABFF535-18D9-395C-877F-66013774824D> /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/SafariSafeBrowsing
    0x7fff6e40a000 -     0x7fff6e529fff  com.apple.Sharing (1176.11 - 1176.11) <9881AEAD-5410-33F7-A852-770C7FE677C9> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fff6e52a000 -     0x7fff6e549ff3  com.apple.shortcut (2.16 - 101) <D724B49E-C972-31CC-B47C-8CB769A3E0B0> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
    0x7fff6f2db000 -     0x7fff6f58bff7  com.apple.SkyLight (1.600.0 - 336.80.6) <5F7D2312-0003-354C-82BC-DC346B1A98E6> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
    0x7fff6fd5a000 -     0x7fff6fd67fff  com.apple.SpeechRecognitionCore (5.0.21 - 5.0.21) <816EC315-3E76-37B7-A495-B4AE031DA439> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fff6fe24000 -     0x7fff7008cffb  com.apple.spotlight.index (10.7.0 - 1191.51) <583CD37E-9C0E-3842-B2C8-B809F0A6DD6D> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
    0x7fff7044c000 -     0x7fff7048bff3  com.apple.StreamingZip (1.0 - 1) <3F13DFEE-A6C9-3815-9120-B5CA6987662E> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
    0x7fff70bc8000 -     0x7fff70c55ff7  com.apple.Symbolication (10.0 - 64254.5) <7D5FB79E-1121-3DB0-9CBE-C023835ACE60> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fff70c56000 -     0x7fff70c5fffb  com.apple.SymptomDiagnosticReporter (1.0 - 820.207.88) <0D7B57B7-8563-3B6D-9084-AA5A1340CAA8> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
    0x7fff7115e000 -     0x7fff7116bff3  com.apple.TCC (1.0 - 1) <55C045F7-D8AB-3BE6-970B-9457FA78E7E3> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fff713da000 -     0x7fff714a1ff7  com.apple.TextureIO (3.8.4 - 3.8.1) <F9D5F55D-9A33-326E-8B2F-B533CC91DD64> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
    0x7fff714ce000 -     0x7fff714feff3  com.apple.TimeSync (1.0 - 700.7) <B2D2B1D8-0AF2-398C-80A3-0EC2ABB3773B> /System/Library/PrivateFrameworks/TimeSync.framework/Versions/A/TimeSync
    0x7fff7155b000 -     0x7fff7155cfff  com.apple.TrustEvaluationAgent (2.0 - 31.200.1) <BD0BE410-E172-3585-82B2-869A1FE43092> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fff71562000 -     0x7fff7171cfff  com.apple.UIFoundation (1.0 - 550.35) <1CAAA3AC-1477-3E24-B55C-07A704D7CA03> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fff7176b000 -     0x7fff71771fff  com.apple.URLFormatting (59 - 59.34) <D104A904-5B18-368E-8290-35212094D9F5> /System/Library/PrivateFrameworks/URLFormatting.framework/Versions/A/URLFormatting
    0x7fff7240a000 -     0x7fff724f3fff  com.apple.ViewBridge (400.1 - 400.1) <0BCCA232-710B-3F84-8341-A30F77B3A4E9> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
    0x7fff72973000 -     0x7fff72bdfffb  libAWDSupportFramework.dylib (865) <054B6F72-B75B-3AFC-9E9C-9929C9634200> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupportFramework.dylib
    0x7fff72be0000 -     0x7fff72bf1fff  libprotobuf-lite.dylib (865) <B69A744C-4920-3587-A987-A0D349437F4B> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf-lite.dylib
    0x7fff72bf2000 -     0x7fff72c54ff7  libprotobuf.dylib (865) <7867D62B-1FDC-3F06-B234-4B6CE5D10602> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf.dylib
    0x7fff72c55000 -     0x7fff72c9bfff  com.apple.awd (1.0 - 930.11) <534B230C-8453-3F01-B6B8-4C1226D3F1E8> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/WirelessDiagnostics
    0x7fff72d0e000 -     0x7fff72d11fff  com.apple.dt.XCTTargetBootstrap (1.0 - 1) <63A533F6-988D-3FED-A1C7-20BC725A0D4B> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
    0x7fff72d19000 -     0x7fff72d79ff7  com.apple.xquery (1.3.1 - 30) <DB666CD4-4C35-316A-8D7A-CF8CD6CEF36F> /System/Library/PrivateFrameworks/XQuery.framework/Versions/A/XQuery
    0x7fff73142000 -     0x7fff73144ff3  com.apple.loginsupport (1.0 - 1) <5F1E000D-0674-3413-AB3E-83F7974666FB> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fff73145000 -     0x7fff7315afff  com.apple.login (3.0 - 3.0) <474C5E41-1326-3E78-A154-218D618D6BD4> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
    0x7fff7336a000 -     0x7fff7337dffb  libAccessibility.dylib (2402.6.10.3) <3044BCB8-1470-3054-9FB6-3D88AA57115B> /usr/lib/libAccessibility.dylib
    0x7fff733fe000 -     0x7fff73436fff  libCRFSuite.dylib (41.15.4) <62EDD39F-6D1B-334B-A9A2-5800714255BB> /usr/lib/libCRFSuite.dylib
    0x7fff73439000 -     0x7fff73444ff7  libChineseTokenizer.dylib (28.15.3) <8CD1C213-7F62-3F02-BFB1-D0A5EFF92AB0> /usr/lib/libChineseTokenizer.dylib
    0x7fff73445000 -     0x7fff734d1ff7  libCoreStorage.dylib (546.50.1) <F56AD958-416C-38EA-9829-DEAAB1F0C155> /usr/lib/libCoreStorage.dylib
    0x7fff734d5000 -     0x7fff734d6ff7  libDiagnosticMessagesClient.dylib (107) <C542CB3C-AA44-3D7F-B88C-79CC31B481AB> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fff7350d000 -     0x7fff736d0ff7  libFosl_dynamic.dylib (18.3.2) <6EF1CB2A-2BDA-3458-B631-F794D72660FD> /usr/lib/libFosl_dynamic.dylib
    0x7fff73726000 -     0x7fff73745ffb  libMobileGestalt.dylib (645.200.76) <A2C32318-0E35-3963-B9B7-E1E92AD33BA6> /usr/lib/libMobileGestalt.dylib
    0x7fff73746000 -     0x7fff73746fff  libOpenScriptingUtil.dylib (178) <2EEBF84D-9E00-3570-AC0C-C49C8D25A8BF> /usr/lib/libOpenScriptingUtil.dylib
    0x7fff73887000 -     0x7fff73888ffb  libSystem.B.dylib (1252.200.5) <D5133811-9D66-3DEB-9521-0A67347C9A54> /usr/lib/libSystem.B.dylib
    0x7fff73889000 -     0x7fff73911ff7  libTelephonyUtilDynamic.dylib (3608) <05694AE8-9065-36CD-A03B-15D23D09414E> /usr/lib/libTelephonyUtilDynamic.dylib
    0x7fff73912000 -     0x7fff73913fff  libThaiTokenizer.dylib (2.15.1) <A8235B04-F541-3856-BE2E-B58EE0483AD9> /usr/lib/libThaiTokenizer.dylib
    0x7fff73926000 -     0x7fff7393cffb  libapple_nghttp2.dylib (1.24.1) <B8D45114-3868-3154-BC35-22597E3E7D8A> /usr/lib/libapple_nghttp2.dylib
    0x7fff7393d000 -     0x7fff73966ffb  libarchive.2.dylib (54.200.3) <B47C54A0-3A30-374A-BD99-2304B9B0EC82> /usr/lib/libarchive.2.dylib
    0x7fff73967000 -     0x7fff739e6fef  libate.dylib (1.13.8) <C647A80F-6F80-3FDA-A9B4-92800999F963> /usr/lib/libate.dylib
    0x7fff739ea000 -     0x7fff739eaff3  libauto.dylib (187) <01824E49-F2EF-3FC1-ABF3-782EFDF6CA17> /usr/lib/libauto.dylib
    0x7fff739eb000 -     0x7fff73ac1ff7  libboringssl.dylib (109.201.1) <EE1460C1-EA18-3BC8-BC43-BC916E09C790> /usr/lib/libboringssl.dylib
    0x7fff73ac2000 -     0x7fff73ad2ff3  libbsm.0.dylib (39.200.18) <5E5098D0-F7B2-32A1-8038-E709F6718D4E> /usr/lib/libbsm.0.dylib
    0x7fff73ad3000 -     0x7fff73ae1fff  libbz2.1.0.dylib (38.200.3) <4EE3C5E8-BEF3-3910-A231-B1AE2B437E01> /usr/lib/libbz2.1.0.dylib
    0x7fff73ae2000 -     0x7fff73b39ff7  libc++.1.dylib (400.9.4) <D4AB366F-48A9-3C7D-91BD-41198F69DD57> /usr/lib/libc++.1.dylib
    0x7fff73b3a000 -     0x7fff73b4ffff  libc++abi.dylib (400.17) <BA948A32-9024-3E55-98D4-18E31F6AED25> /usr/lib/libc++abi.dylib
    0x7fff73b50000 -     0x7fff73b50ff3  libcharset.1.dylib (51.200.6) <D998A58B-E4A8-3685-9A6A-43AFC28100EB> /usr/lib/libcharset.1.dylib
    0x7fff73b51000 -     0x7fff73b61ffb  libcmph.dylib (6.15.1) <5D776FF6-DF7F-3EDD-B920-C07ED76C672B> /usr/lib/libcmph.dylib
    0x7fff73b62000 -     0x7fff73b7affb  libcompression.dylib (52.200.13) <EA767836-CBDC-318D-AC14-963C90D6CC67> /usr/lib/libcompression.dylib
    0x7fff73e25000 -     0x7fff73e3bfff  libcoretls.dylib (155.200.6) <6E68F922-752C-311F-B56D-EE391E6AE1F7> /usr/lib/libcoretls.dylib
    0x7fff73e3c000 -     0x7fff73e3dff3  libcoretls_cfhelpers.dylib (155.200.6) <7300BA76-39D2-349E-9FB8-EBE5947A708A> /usr/lib/libcoretls_cfhelpers.dylib
    0x7fff73ef3000 -     0x7fff73fdbff7  libcrypto.0.9.8.dylib (76.200.2) <0B2819E5-A99F-3165-904D-3A659669D8C7> /usr/lib/libcrypto.0.9.8.dylib
    0x7fff73fdc000 -     0x7fff7416cff3  libcrypto.35.dylib (22.200.4) <B4F83304-FB35-3CA5-8949-DE7D75B8A9D9> /usr/lib/libcrypto.35.dylib
    0x7fff74307000 -     0x7fff7449fff7  libcrypto.42.dylib (22.200.4) <EFCEE49A-759B-3A9A-A164-ECD1A98D40F9> /usr/lib/libcrypto.42.dylib
    0x7fff744a0000 -     0x7fff744abff7  libcsfde.dylib (546.50.1) <65E8F1F1-665A-381E-8932-D7CBA451991B> /usr/lib/libcsfde.dylib
    0x7fff744b4000 -     0x7fff7450affb  libcups.2.dylib (462.9) <51E06E95-891F-3B88-A8C3-35B514C57239> /usr/lib/libcups.2.dylib
    0x7fff74534000 -     0x7fff74588ff3  libcurl.4.dylib (105.200.2) <607613FE-3D84-3035-9C79-C6F72AF287D7> /usr/lib/libcurl.4.dylib
    0x7fff74642000 -     0x7fff74642fff  libenergytrace.dylib (17.200.1) <D62ED169-B91C-3CCB-ADF5-E66AE4007B51> /usr/lib/libenergytrace.dylib
    0x7fff74643000 -     0x7fff7465cffb  libexpat.1.dylib (16.1.1) <D91D81FF-D190-36A7-B440-F4AEB4220C80> /usr/lib/libexpat.1.dylib
    0x7fff74674000 -     0x7fff74679ff7  libgermantok.dylib (17.15.2) <9CBF0658-E83B-32E6-B674-3EE72D22C041> /usr/lib/libgermantok.dylib
    0x7fff7467a000 -     0x7fff7467fff7  libheimdal-asn1.dylib (520.200.17) <58971629-3850-3905-A9A1-09FCF7A32815> /usr/lib/libheimdal-asn1.dylib
    0x7fff746ab000 -     0x7fff7479cff7  libiconv.2.dylib (51.200.6) <3240A278-F537-3EC8-BE0C-983797520A50> /usr/lib/libiconv.2.dylib
    0x7fff7479d000 -     0x7fff74a00ffb  libicucore.A.dylib (62107.0.1) <EAE6FC43-3AD2-3A53-9F7A-4E5E5F66D006> /usr/lib/libicucore.A.dylib
    0x7fff74a4d000 -     0x7fff74a4efff  liblangid.dylib (128.15.1) <F79B6250-C0B1-3E8E-851F-6CA33B4311A3> /usr/lib/liblangid.dylib
    0x7fff74a4f000 -     0x7fff74a67fff  liblzma.5.dylib (10.200.3) <3ADDFA63-F37A-3C9C-91E4-58EE3113B9A1> /usr/lib/liblzma.5.dylib
    0x7fff74a7f000 -     0x7fff74b2ffff  libmecab.1.0.0.dylib (779.15.23) <6A38FCDA-17CE-30C3-AB66-A714CF645384> /usr/lib/libmecab.1.0.0.dylib
    0x7fff74b30000 -     0x7fff74d6dfff  libmecabra.dylib (779.15.23) <30E102AA-F3D3-3572-A1AE-1F2287DEF696> /usr/lib/libmecabra.dylib
    0x7fff74f45000 -     0x7fff7529dfff  libnetwork.dylib (1229.200.109) <AD59D28C-CCB2-3B34-B904-8CCCEB2CF320> /usr/lib/libnetwork.dylib
    0x7fff7532e000 -     0x7fff75ab4fe7  libobjc.A.dylib (750) <2E868147-8818-359E-8CD7-A8B80665928F> /usr/lib/libobjc.A.dylib
    0x7fff75ac7000 -     0x7fff75acbffb  libpam.2.dylib (22.200.1) <8C419238-675A-3C41-B8D4-95E391CA630F> /usr/lib/libpam.2.dylib
    0x7fff75ace000 -     0x7fff75b04ff7  libpcap.A.dylib (79.200.4) <5939AB23-B2A9-3C03-B6C1-4F0E5A21D9FC> /usr/lib/libpcap.A.dylib
    0x7fff75b05000 -     0x7fff75b41ff3  libpcre.0.dylib (9) <E756BD3C-C54E-3D7D-85C3-90195F4342B5> /usr/lib/libpcre.0.dylib
    0x7fff75c1e000 -     0x7fff75c36ffb  libresolv.9.dylib (65.200.2) <0FEAEB01-B926-37FA-AB47-99BAC481C10B> /usr/lib/libresolv.9.dylib
    0x7fff75c75000 -     0x7fff75c87ff7  libsasl2.2.dylib (211) <205CC13E-4ED7-3CE9-987F-12B28C6115A7> /usr/lib/libsasl2.2.dylib
    0x7fff75c88000 -     0x7fff75c89ffb  libspindump.dylib (266) <0E60D709-0A48-3905-ACD1-9DDE6FD8B476> /usr/lib/libspindump.dylib
    0x7fff75c8a000 -     0x7fff75e61fe7  libsqlite3.dylib (274.20) <4434B695-BC65-30D6-AFED-1B6488DB3D2E> /usr/lib/libsqlite3.dylib
    0x7fff75e84000 -     0x7fff75ebdff7  libssl.0.9.8.dylib (76.200.2) <E4BDEEE8-0E93-3F06-9172-BEDDF0D9D93F> /usr/lib/libssl.0.9.8.dylib
    0x7fff75ebe000 -     0x7fff75f11ffb  libssl.35.dylib (22.200.4) <6C42D9B4-1E35-3102-BA4A-164AD070F519> /usr/lib/libssl.35.dylib
    0x7fff75f64000 -     0x7fff75fb1fff  libssl.44.dylib (22.200.4) <CF4931A6-5928-3E2B-8E31-1854F36B0C19> /usr/lib/libssl.44.dylib
    0x7fff75fb2000 -     0x7fff76003ff7  libstdc++.6.dylib (104.1) <0E48A478-4CFD-3111-8027-1047508A1D73> /usr/lib/libstdc++.6.dylib
    0x7fff7603a000 -     0x7fff7606afff  libtidy.A.dylib (16.1) <435FB24F-0289-3330-B485-713909D6DA44> /usr/lib/libtidy.A.dylib
    0x7fff7608e000 -     0x7fff760edff3  libusrtcp.dylib (1229.200.109) <07B2AEC8-5FD4-34BE-B35B-B595283D9DC9> /usr/lib/libusrtcp.dylib
    0x7fff760ee000 -     0x7fff760f1ffb  libutil.dylib (51.200.4) <91EE9BF4-FB06-3260-B502-7EFDAD5AF59B> /usr/lib/libutil.dylib
    0x7fff760f2000 -     0x7fff760fffff  libxar.1.dylib (404) <4B4D0206-0B62-3E89-AD07-E7BB9E4DFA68> /usr/lib/libxar.1.dylib
    0x7fff76104000 -     0x7fff761e7fff  libxml2.2.dylib (32.6) <BFF70F01-6755-36B9-B7AA-724743E63503> /usr/lib/libxml2.2.dylib
    0x7fff761e8000 -     0x7fff76210ff3  libxslt.1.dylib (16.1) <F191E8B9-7530-30CA-873B-2FA2BF2D6374> /usr/lib/libxslt.1.dylib
    0x7fff76211000 -     0x7fff76223ffb  libz.1.dylib (70.200.4) <99A3D725-8388-38B4-B66C-5E9006E6F072> /usr/lib/libz.1.dylib
    0x7fff76251000 -     0x7fff76252ffb  liblog_network.dylib (1229.200.109) <932F8E45-9A5A-3A42-9C5E-3FAE6CD8938E> /usr/lib/log/liblog_network.dylib
    0x7fff76294000 -     0x7fff76298ff3  libcache.dylib (81) <FE21A7E9-DBEB-33AC-836B-785AD036ACF4> /usr/lib/system/libcache.dylib
    0x7fff76299000 -     0x7fff762a3ff3  libcommonCrypto.dylib (60118.200.6) <78093D4F-91DB-35C8-981A-13375778B2E7> /usr/lib/system/libcommonCrypto.dylib
    0x7fff762a4000 -     0x7fff762abfff  libcompiler_rt.dylib (63.4) <A4D9CF37-D076-3CE9-95F1-DA89DA1601B6> /usr/lib/system/libcompiler_rt.dylib
    0x7fff762ac000 -     0x7fff762b5ff3  libcopyfile.dylib (146.200.3) <4BCDADBF-79F5-3829-B47D-64DA0D44BCBF> /usr/lib/system/libcopyfile.dylib
    0x7fff762b6000 -     0x7fff7633afff  libcorecrypto.dylib (602.200.50) <7AEC5B72-0B92-37E8-808B-6732DB714139> /usr/lib/system/libcorecrypto.dylib
    0x7fff763c0000 -     0x7fff763faff7  libdispatch.dylib (1008.200.78) <B8962879-AD55-3CF0-9B0A-5F1D57D1E14B> /usr/lib/system/libdispatch.dylib
    0x7fff763fb000 -     0x7fff7642afff  libdyld.dylib (625.13) <4B16C209-83D4-3817-9B62-C2F7FFB23755> /usr/lib/system/libdyld.dylib
    0x7fff7642b000 -     0x7fff7642bffb  libkeymgr.dylib (30) <A73AA788-C35C-3284-BFCA-95B1BBDF0CF3> /usr/lib/system/libkeymgr.dylib
    0x7fff7642c000 -     0x7fff76438ff7  libkxld.dylib (4903.201.2) <EAF1CF8D-3843-33BE-8126-30994685B8F0> /usr/lib/system/libkxld.dylib
    0x7fff76439000 -     0x7fff76439ff7  liblaunch.dylib (1336.201.2) <43E6698E-155E-3EAE-BAFF-CA5FCB35325C> /usr/lib/system/liblaunch.dylib
    0x7fff7643a000 -     0x7fff7643ffff  libmacho.dylib (917) <17BF7038-9C70-3EE1-9E96-3AE10D49669E> /usr/lib/system/libmacho.dylib
    0x7fff76440000 -     0x7fff76442ff3  libquarantine.dylib (86.200.11) <C70DA995-0D6E-302C-A15E-F7F03A3857B4> /usr/lib/system/libquarantine.dylib
    0x7fff76443000 -     0x7fff76444ff3  libremovefile.dylib (45.200.2) <D74A307B-3DC7-3992-B16C-DACB8207BE13> /usr/lib/system/libremovefile.dylib
    0x7fff76445000 -     0x7fff7645cff3  libsystem_asl.dylib (356.200.4) <EC9D8AD4-E5CB-3765-804A-9E1E9DC045D2> /usr/lib/system/libsystem_asl.dylib
    0x7fff7645d000 -     0x7fff7645dfff  libsystem_blocks.dylib (73) <26419398-C30C-30F1-B656-A92AFA9560F6> /usr/lib/system/libsystem_blocks.dylib
    0x7fff7645e000 -     0x7fff764e6fff  libsystem_c.dylib (1272.200.26) <3DEEE96E-6DF6-35AD-8654-D69AC26B907B> /usr/lib/system/libsystem_c.dylib
    0x7fff764e7000 -     0x7fff764eaff7  libsystem_configuration.dylib (963.200.27) <02CC3996-B34E-333C-8806-AE2699D34424> /usr/lib/system/libsystem_configuration.dylib
    0x7fff764eb000 -     0x7fff764eeff7  libsystem_coreservices.dylib (66) <254B6849-2C8F-302C-8616-B8324A11AB30> /usr/lib/system/libsystem_coreservices.dylib
    0x7fff764ef000 -     0x7fff764f5ffb  libsystem_darwin.dylib (1272.200.26) <974E9EF7-DE72-34B7-B056-0A81C10DF8EB> /usr/lib/system/libsystem_darwin.dylib
    0x7fff764f6000 -     0x7fff764fcff7  libsystem_dnssd.dylib (878.200.35) <FFC665AA-B257-35AD-BD8B-32FD42C2EEC1> /usr/lib/system/libsystem_dnssd.dylib
    0x7fff764fd000 -     0x7fff76549ff3  libsystem_info.dylib (517.200.9) <0707C387-D7DE-372E-8FF1-3DE5C91932D6> /usr/lib/system/libsystem_info.dylib
    0x7fff7654a000 -     0x7fff76571ff7  libsystem_kernel.dylib (4903.201.2) <45FAA4C0-D553-34FD-ADF8-884886AE0D2A> /usr/lib/system/libsystem_kernel.dylib
    0x7fff76572000 -     0x7fff765bdff7  libsystem_m.dylib (3158.200.7) <43D1796B-954F-37D6-B1AC-9D80DF0655A2> /usr/lib/system/libsystem_m.dylib
    0x7fff765be000 -     0x7fff765e2ff7  libsystem_malloc.dylib (166.200.60) <846F6898-117C-3427-A8FB-3772FFC2410B> /usr/lib/system/libsystem_malloc.dylib
    0x7fff765e3000 -     0x7fff765eeffb  libsystem_networkextension.dylib (767.200.40) <F84D5474-4DC1-3E1A-AE00-8CE9593278B4> /usr/lib/system/libsystem_networkextension.dylib
    0x7fff765ef000 -     0x7fff765f6fff  libsystem_notify.dylib (172.200.21) <BCCB222F-DC64-3954-A836-DCCE6659CA5A> /usr/lib/system/libsystem_notify.dylib
    0x7fff765f7000 -     0x7fff76600fef  libsystem_platform.dylib (177.200.16) <B75B04AD-69FE-3ADE-84D2-C17972FC8F49> /usr/lib/system/libsystem_platform.dylib
    0x7fff76601000 -     0x7fff7660bfff  libsystem_pthread.dylib (330.201.1) <87A6B136-E423-3B6D-A58A-137F392D7D9D> /usr/lib/system/libsystem_pthread.dylib
    0x7fff7660c000 -     0x7fff7660fff7  libsystem_sandbox.dylib (851.201.1) <FBA7E09B-F10F-3424-90EA-B4999B7FB461> /usr/lib/system/libsystem_sandbox.dylib
    0x7fff76610000 -     0x7fff76612ff7  libsystem_secinit.dylib (30.200.13) <CBEAB62B-F0A0-342F-9878-CADC14A3CB0D> /usr/lib/system/libsystem_secinit.dylib
    0x7fff76613000 -     0x7fff7661aff7  libsystem_symptoms.dylib (820.207.88) <B6E22FA8-0F7B-36FD-9D99-284056D3CB47> /usr/lib/system/libsystem_symptoms.dylib
    0x7fff7661b000 -     0x7fff76630ff7  libsystem_trace.dylib (906.200.86) <7983ED77-18B5-39A5-BE19-AE4F2832ADEA> /usr/lib/system/libsystem_trace.dylib
    0x7fff76632000 -     0x7fff76637ffb  libunwind.dylib (35.4) <41222EF6-2233-3CF4-947A-15D48CB8C030> /usr/lib/system/libunwind.dylib
    0x7fff76638000 -     0x7fff76668fff  libxpc.dylib (1336.201.2) <0A8747D1-33AA-37E1-B97A-BA9B95FE4E8C> /usr/lib/system/libxpc.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 1
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 2484
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.4G resident=0K(0%) swapped_out_or_unallocated=1.4G(100%)
Writable regions: Total=1.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.1G(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
ATS (font support)                32.2M        9
ATS (font support) (reserved)        4K        2         reserved VM address space (unallocated)
Accelerate framework               384K        3
Activity Tracing                   256K        2
CG backing stores                 62.9M        5
CG image                           136K       14
CG raster data                      32K        4
CoreAnimation                       52K        7
CoreGraphics                         8K        2
CoreImage                           24K        3
CoreUI image data                  952K       12
CoreUI image file                  516K        4
Foundation                          32K        4
Image IO                            80K        9
Kernel Alloc Once                    8K        2
MALLOC                           574.9M      120
MALLOC guard page                   48K       11
MALLOC_NANO (reserved)           384.0M        2         reserved VM address space (unallocated)
Memory Tag 242                      12K        2
Memory Tag 251                      32K        3
SQLite page cache                   64K        2
STACK GUARD                       56.1M       35
Stack                             32.3M       36
VM_ALLOCATE                       24.3M       60
__DATA                            86.1M      784
__FONT_DATA                          4K        2
__GLSLBUILTINS                    5176K        2
__LINKEDIT                       517.5M      288
__NV_CUDA                         6064K        3
__TEXT                           887.3M      621
__UNICODE                          560K        2
libnetwork                         640K        8
mapped file                      149.8M       78
shared memory                     7752K       23
TOTAL                              2.8G     2130
TOTAL, minus reserved VM space     2.4G     2130
Model: iMac17,1, BootROM IM171.0157.B00, 4 processors, Intel Core i7, 4 GHz, 32 GB, SMC 2.34f2
Graphics: AMD Radeon R9 M395, AMD Radeon R9 M395, PCIe
Memory Module: BANK 0/DIMM0, 16 GB, DDR3, 1867 MHz, 0x00, 0x202020202020202020202020202020202020
Memory Module: BANK 1/DIMM0, 16 GB, DDR3, 1867 MHz, 0x00, 0x202020202020202020202020202020202020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x14A), Broadcom BCM43xx 1.0 (7.77.61.1 AirPortDriverBrcmNIC-1305.2)
Bluetooth: Version 6.0.8f6, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE HDD ST2000DM001, 2 TB
Serial ATA Device: APPLE SSD SM0128G, 121,33 GB
USB Device: USB 3.0 Bus
USB Device: Bluetooth USB Host Controller
USB Device: FaceTime HD Camera (Built-in)
Thunderbolt Bus: iMac, Apple Inc., 28.1
Adobe Employee ,
Oct 25, 2018 Oct 25, 2018
Hi krystynaw58700073,
Sorry for the issue with Queue to Media Encoder feature.
1. Have you tried to uninstall and reinstall Media Encoder?
2. Is this happening with all projects? Please check with a new project and a simple composition.
3. Is there an anti-virus or firewall enabled in the machine? If yes, disable them and see if it works.
4. Are you logged in as an Administrator? Just for a test, log in to a different Admin account in OS and see if the issue persists.
Vidya
Dec 19, 2018 Dec 19, 2018
I'm having this issue. uninstall and reinstall hasn't helped. I've checked your 4 points, no help. Also can't import from AE to premiere. how do I fix the link issue?
Nov 28, 2018 Nov 28, 2018
Please uninstall & reinstall Adobe Media Encoder on ap lioa
Jan 10, 2019 Jan 10, 2019
SOLUCIƓN
Yo tenĆ­a el mismo problema pero logrĆ© solucionarlo. Busquen en preferencias de AE y el Encoder. Anteriormente ya dijeron quĆ© modificar en el preferencias de AE. En el Encoder, vayan a preferencias y luego a Sincronizar configuraciĆ³n. Una opciĆ³n dirĆ” "Al sincronizar", deben seleccionar "cargar siempre configuraciĆ³n". Luego, si desean pueden volver a la configuraciĆ³n anterior.
Jan 11, 2019 Jan 11, 2019
YES!!!! thank you anthony!!..it finaly works...  For me this is the sollution....preferences in Adobe Media encoder > synchronize configuration > always load configuration....and VOILA it works.
Jul 01, 2019 Jul 01, 2019
Awesome, thanks!
I think in my version it's called differently:
Media Encoder menu > Sync Settings > Manage Sync Settings > "When Syncing: Always Upload Settings"
