Hello,
When I copied pages from one InDesign document to another by drop and drag, line breaks changed. All of the settings appear to be the same: text size and leading, tracking, kerning, hyphenation, paragraph composer, text frame size, margins. It seems like there must be some underlying setting that is different in the two documents. Any suggestions for where to look would be much appreciated.
InDesign CC 2014, Mac OS 10.10.5, Mac Pro early 2009
There's also the Justification settings and maybe the Keep Options
Is the source text styled with [Basic Paragraph] or a style that's based on [Basic Paragraph]?
First check whether the difference is real: go to the document you copied from and recompose it (type any character in the story and delete it). If the text doesn't change then there is indeed a difference, though I have nothing to offer. . .
I don't quite get the suggestion, but the line breaks in a paragraph in the document I copied from do not change when I type a character and delete it.
Yes! The Justification settings were different. When I loaded the paragraph style from the source document into the target document, the line breaks fixed themselves. Thank you!
Also, there could be an Object Style conflict—the two document's [Basic Text frame] styles could be different. When there is a conflict with same named styles the destination style definition is used.
Do you still have the problem if you break the style links? Select the text and choose Break Link to Style from the Paragraph Styles panel and do the same for the selected text frame in the Object Style panel and see if that fixes the problem.
