hey I’m currently Running Illustrator CC version 17.0.0 and I’m trying to print out a design for my clothing brand however when I print it out the black comes out faded and not rich in color... I’ve attempted to change the preference by putting “output all blacks as Rich Blacks“ but still no success. I tried taking a screen shot and printing that and the Black comes out fine so I know it’s not the ink of the printer but it has to be something in the actual software/setting of illustrator...
PLS HELP
Thank You in advance.
Yes - is the OP using 100% straight black or is it a mix of CMYK, RGB etc.
If the OP wants the color to come out as "rich black" then change the swatch to a true rich black CMYK like
C 60, M 40, Y 40, K 100
I believe that that setting only affects the output to the display. It doesn't affect the document setting, and therefore has no effect on printing. If you want to print a rich black, you must define the rich black in the document.
Peter
Which document color mode ist it?
On what kind of device do you print?
Does it have its own color adjustment settings?
Rich black is only for display monitor
can you provide more details of how you are printing?
have you tried saving it as pdf and printing it from the pdf viewer? will it come out the same?
If you're printing within AI i would bet you have something changed inthe color management section which sets the printing profile settings.
Check what settings you have and see if you have multiple printer profiles first
Rich black is not only for display monitors.
The Appearance of Black settings (Printing/Exporting options) does apply to printed or PDF documents IF they are RGB.
If the OP is in a CMYK color space, that preference will do nothing for them.
What is the color breakdown for your black color?
The Black color that are you printing is a Rich Black?
