Premiere Pro not rendering/exporting right to Media Encoder
Jan 11, 2019 Jan 11, 2019
Hi everyone, I have been at this for quite a while with 45+ renders with no luck at getting it to render right.
I am trying to create a video piece that involves 3 image layers panning/zooming out to create a 3D image effect (I will post the video result down below). It looks great and preforms as need be when it comes to the Premiere Pro preview but when it's exported into Media Encoder the image color gets blown out and super pixlated.
I have exported quite a few videos this way before with no problem but this is my first time doing a project that pans and zooms like this so I am not quite sure if it's a Premiere Pro export problem or if it's a Media Encoder settings issue. Due to me doing so many renders I don't have all of the small details, I have just been messing around and following other Youtube video settings that people share. Hoping to get some help as to what may help get this looking properly. Some settings render better than others while some create a corrupted file that won't allow me to view it at all after waiting 30 min for it to render.
ORIGINAL IMAGE (flattened)
VIDEO(S) RENDERED (not all just a few)
This one is just a pan of the image with no layers but it still has the coloring problem and is really not the route I want to go with.
Any advice would be greatly appreciated!
2.3K
Community Expert , Jan 14, 2019 Jan 14, 2019
Could be a graphics card issue? Maybe you need to update your drivers? GPU could be out of spec with Premiere Pro 13.0.2? Maybe try rolling back to an earlier version of Premiere Pro (would have to remake your project)?
All the videos you linked to say "This video is unavailable"
Thanks for letting me know, I looked back and it looks like I put them all as private instead of unlisted I updated them and you should be able to see it all now
Jan 12, 2019 Jan 12, 2019
What are your Export Settings?
Yes, curious to know your project settings and your export settings as well as any effects you are using. To me, it looks like a problem with the fine gradients used in the artwork.
Jim Simon​ gerikp10383985​
I am using the Youtube 1080 HD Preset then each time I tweak it when it doesn't go right. I don't know all of the specific details unfortunately   I do see the fine gradient problems, is there any setting to fix that?
OK.
Run a test.  Choose QuickTime as the Format and Cineform YUV 10 bit as the Preset.  Upload that to YouTube, report back.
I am trying to render it now. The export time is totally ridiculous, over an estimated hour for a 7 second clip I'll tag you when I am able to upload it
Jim Simon​
Here it is, for some reason the uploading of the clip took longer than the actual rendering. It looks really good up until the end where then the coloring freaks out again. Also, I couldn't even preview it before uploading it to youtube so I didn't get a chance to look at it until recently.
Man, that is some weird stuff going on. Is it possible to share your files and project somehow to take a look?
gerikp10383985​
Sure, how do I do that? This is the first time I have been on this forum so I am not sure of the in's and out's of it.
So we can see your sequences settings. Also post a screenshot of the clip properties (right click clip in project window).
Here is the original, before any other implemented changes were taken recommended by other users, in turn goes with the first screenshot compilation I posted earlier. Ann Bens​
As for the clip properties I am not seeing any options to view, so I am unsure as to where that is/how to access it. It's not a video project, it's 3 different pictures panning/zooming out so I don't know if that would count as a clip?
Your sequence is 9000x5100, you images 4500x2550. Scaled up 400% then scale way down.......
Then exported to 1920x1080.
The way the image behave within the sequence is asking for compression artifacts.
Is there a specific place where I could make the sequence smaller? I am not seeing any portion on my side to even set the sequence size. As for the scale, yeah I had it intentionally scaled like that to create the effect. Is that not good? The image resolution is high so it should keep all the details...  I am no professional with these programs nor have I used them before like this, as mentioned before I really only used them for video processing not anything like this
It might be helpful to you to read over this help file on sequence settings
Create and change sequences in Premiere Pro
I believe I fixed the sizing issues with the sequence (finally found the panel) , however the rendering is still coming out wonky. I still have to wait for my friend to look at the specs and updates but here is the latest render and new project stuff.
Blood Maid Promo retry23.prproj - Google Drive
Try turning off Composite in linear color in the sequence settings.
It's still doing it At this point I feel it may be more of a graphics card thing like gerikp mentioned in their list of possibilities.
gerikp10383985​
Here were the last settings used I did the best I could taking screenshots and piecing them together so hopefully it all makes sense. I am not much of an experienced person in these programs I just use them for simple rendering so I don't really know what I am much doing other than it's not working the way I want it to work. All I have ever rendered previously were recorded videos.settings put together.png
In Media Encoder preferences, have you tried un-checking "import sequences natively" ?
Neil
Also, try turning off "Use maximum render quality" in your export settings. I've learned that for me it can sometimes cause problems.
R Neil Haugen​ gerikp10383985​
Here is the stuff with the import sequences natively and use maximum render quality off. I don't see much of a big difference. First video is a 2 pass and the bottom is a 1 pass.
Upload it to Google Drive or Dropbox and post a link?
