SOLVED
Can we use % (modulo) in Sightly
Avatar
Level 3
Can we use %(modulo) in Sightly
I want to use below condition in sightly, how can I use it
<ul data-sly-list="${properties.size}">
<li  data-sly-test="${itemList.count % 3 ==0}"> Test </li>
</ul>
I know above code don't work. How to achieve above condition in sightly.
1 Accepted Solution
Avatar
Correct answer by
Administrator
HTL (formerly known as Sightly ) only supports logical and comparison operators. It is intended as the view rendering scripts are not supposed to contain business logic, this should come from the model/use-objects/Js use-api.
Spec:- htl-spec/SPECIFICATION.md at master · Adobe-Marketing-Cloud/htl-spec · GitHub
Js Use-API: HTL JavaScript Use-API
Feike Visser Please correct me if I am wrong here.
~kautuk
Kautuk Sahni
Avatar
Correct answer by
Administrator
~kautuk
Kautuk Sahni
Avatar
Employee
No %-modulo can't be used. However it is a great improvement to HTL/Sightly.
Would you mind to raise a sling-ticket on this?
Avatar
Level 3
Thanks kautuksahni & Feike Visser
​Will raise sling ticket for the same.
Avatar
Employee
Let me know the ticket, so I can help to expedite it.
Avatar
Level 1
Would be great to have this functionality. If i need to render a list, and do something specific for every 5th element, ${itemList.index % 5 == 0} would be very useful.
Avatar
Employee
Raise a sling jira-ticket for it.
