This post is an act of desperation as most of my time with the latest Dreamweaver is just WAITING for the code to load.
I've been using DW for many years working with files of similar structure. CS6 worked seamlessly. CC 2015 was a bit troublesome. The CC 18 has this issue but:
This latest version CC19.0 is not actually functioning AT ALL!
Because of the nature of the website I'm working on, sometimes I'm opening several pages at the same time and use 'Find and replace' function. This worked on previous versions but now opening just two pages is proving impossible. Here is a screenshot after THREE HOURS OF WAITING!!!
Editing links in code view requires switching off code hints, otherwise it takes ages or freezes completely.
Does this happen with all files in all sites or just certain ones?
I ask because I have no latency problems in CC 2019 on Win10 64-bit. I mainly work with database driven content (PHP & MySQL). I also frequently use Bootstrap and jQuery.
Hi Nancy.
Thank you for your reply. I'm running Win 10 64-bit on Intel Core i5-7400 CPU 3,00GHz, 32 BG RAM.
I tried opening THE SAME single file few times: design view opens instantly, ready for editing every time; code view sometimes stays blank for 10-15 seconds, then appears but stays non responsive for another 20-30 seconds, sometimes is visible instantly but still non responsive for up to a minute.
Opening more than one file is virtually impossible unless I wait for each one to become fully active before opening the next one. Still: this only applies to code view, the design being fully operational straight away.
The code it very simple HTML with 4-5 CSS files attached to each page. No php, j-query etc. The site I'm working on is stored on the drive on my computer. It is pretty big, containing about 9000 html files, but my argument to that would be: it was always like that and worked seamlessly on my old CS6, opening 10-15 html files with no trouble.
This problem started when I moved from Win7 with CS6 to Win10 with CC18 and is becoming increasingly difficult. Sometimes it is actually quicker for me to open and edit the file in Notepad.
Try deleting the cache file or even the whole configuration folder as per Deleting a corrupted cache file
Disabled sync settings, closed the program, deleted the file as per instruction. Opened the program again, didn't download any of my personal settings. Tried opening four files - 5 minutes of waiting, still no code view .
In that case we need to call in the big guns. Have a look at Use the Creative Cloud Cleaner Tool to solve installation problems
Done all to the letter. Many errors in the log file:
[Sun Jan 13 12:45:15 2019] ---------------------------------------------------------
[Sun Jan 13 12:45:15 2019] *=*=*=*=*=*=*=*=* :: Start Session :: *=*=*=*=*=*=*=*=*=*
[Sun Jan 13 12:45:15 2019] Win OS Version: 6.2
[Sun Jan 13 12:45:15 2019] Cleaner Tool version : 2.0.0.0
[Sun Jan 13 12:45:15 2019] Cleanup source directory : C:\Program Files (x86)\Common Files\Adobe\AdobeCreativeCloudCleanerTool
[Sun Jan 13 12:45:15 2019] [AdobeProgramFiles] : C:\Program Files (x86)\Adobe
[Sun Jan 13 12:45:15 2019] [AdobeProgramFiles_x64] : C:\Program Files\Adobe
[Sun Jan 13 12:45:15 2019] [AdobeCommon] : C:\Program Files (x86)\Common Files\Adobe
[Sun Jan 13 12:45:15 2019] [AdobeCommon_x64] : C:\Program Files\Common Files\Adobe
[Sun Jan 13 12:45:15 2019] [UserRoamingAppData] : C:\Users\o2\AppData\Roaming
[Sun Jan 13 12:45:15 2019] [UserLocalAppData] : C:\Users\o2\AppData\Local
[Sun Jan 13 12:45:15 2019] [StartMenu] : C:\ProgramData\Microsoft\Windows\Start Menu\Programs
[Sun Jan 13 12:45:15 2019] [System32Folder] : C:\WINDOWS\system32
[Sun Jan 13 12:45:15 2019] [SharedApplicationData] : C:\ProgramData
[Sun Jan 13 12:45:15 2019] [SharedDocuments] : C:\Users\Public\Documents
[Sun Jan 13 12:45:42 2019] Language selected: English
[Sun Jan 13 12:45:42 2019] Displaying the Adobe End User License Agreement
License agreement
By using software of Adobe Systems Incorporated or its subsidiaries ("Adobe"); you agree to the following terms and conditions. If you do not agree with such terms and conditions; do not use the software. The terms of an end user license agreement accompanying a particular software file upon installation or download of the software shall supersede the terms presented below.
The export and re-export of Adobe software products are controlled by the United States Export Administration Regulations and such software may not be exported or re-exported to Cuba; Iran; Iraq; Libya; North Korea; Sudan; or Syria or any country to which the United States embargoes goods. In addition; Adobe software may not be distributed to persons on the Table of Denial Orders; the Entity List; or the List of Specially Designated Nationals.
By downloading or using an Adobe software product you are certifying that you are not a national of Cuba; Iran; Iraq; Libya; North Korea; Sudan; or Syria or any country to which the United States embargoes goods and that you are not a person on the Table of Denial Orders; the Entity List; or the List of Specially Designated Nationals.
If the software is designed for use with an application software product (the "Host Application") published by Adobe; Adobe grants you a non-exclusive license to use such software with the Host Application only; provided you possess a valid license from Adobe for the Host Application. Except as set forth below; such software is licensed to you subject to the terms and conditions of the End User License Agreement from Adobe governing your use of the Host Application.
DISCLAIMER OF WARRANTIES: YOU AGREE THAT ADOBE HAS MADE NO EXPRESS WARRANTIES TO YOU REGARDING THE SOFTWARE AND THAT THE SOFTWARE IS BEING PROVIDED TO YOU "AS IS" WITHOUT WARRANTY OF ANY KIND. ADOBE DISCLAIMS ALL WARRANTIES WITH REGARD TO THE SOFTWARE; EXPRESS OR IMPLIED; INCLUDING; WITHOUT LIMITATION; ANY IMPLIED WARRANTIES OF FITNESS FOR A PARTICULAR PURPOSE; MERCHANTABILITY; MERCHANTABLE QUALITY OR NONINFRINGEMENT OF THIRD PARTY RIGHTS. Some states or jurisdictions do not allow the exclusion of implied warranties; so the above limitations may not apply to you.
LIMIT OF LIABILITY: IN NO EVENT WILL ADOBE BE LIABLE TO YOU FOR ANY LOSS OF USE; INTERRUPTION OF BUSINESS; OR ANY DIRECT; INDIRECT; SPECIAL; INCIDENTAL; OR CONSEQUENTIAL DAMAGES OF ANY KIND (INCLUDING LOST PROFITS) REGARDLESS OF THE FORM OF ACTION WHETHER IN CONTRACT; TORT (INCLUDING NEGLIGENCE); STRICT PRODUCT LIABILITY OR OTHERWISE; EVEN IF ADOBE HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. Some states or jurisdictions do not allow the exclusion or limitation of incidental or consequential damages; so the above limitation or exclusion may not apply to you.
[Sun Jan 13 12:45:42 2019] Please enter (y) for Yes or (n) for No. ... >>
[Sun Jan 13 12:45:48 2019] Choose from one of the following options to clean up :
[Sun Jan 13 12:45:48 2019] 1. All
[Sun Jan 13 12:45:48 2019] 2. Adobe Flash Player 10.2
[Sun Jan 13 12:45:48 2019] 3. CC Apps, Creative Cloud & CS6 Products
[Sun Jan 13 12:45:48 2019] 4. CC Apps
[Sun Jan 13 12:45:48 2019] 5. CC 2014 Apps only
[Sun Jan 13 12:45:48 2019] 6. Creative Cloud only
[Sun Jan 13 12:45:48 2019] 7. CS6 only
[Sun Jan 13 12:45:48 2019] 8. CS5-CS5.5-CS6
[Sun Jan 13 12:45:48 2019] 9. CS5-CS5.5
[Sun Jan 13 12:45:48 2019] 10. CS3, CS4
[Sun Jan 13 12:45:48 2019] 11. Adobe Id credentials
[Sun Jan 13 12:45:48 2019] 12. Fix Host File
[Sun Jan 13 12:45:48 2019] 13. Quit
[Sun Jan 13 12:45:48 2019] Choice 😆
[Sun Jan 13 12:46:17 2019] User selected: CC Apps
[Sun Jan 13 12:46:17 2019] Executed the command : call copy /Y "C:\Program Files (x86)\Common Files\Adobe\caps\pdb.db" "C:\Program Files (x86)\Common Files\Adobe\backup20190113T124617\pdb.db"
[Sun Jan 13 12:46:17 2019] Executed the command : call copy /Y "C:\Program Files (x86)\Common Files\Adobe\caps\Media_db.db" "C:\Program Files (x86)\Common Files\Adobe\backup20190113T124617\Media_db.db"
[Sun Jan 13 12:46:17 2019] Executed the command : call copy /Y "C:\Program Files (x86)\Common Files\Adobe\caps\hdpim.db" "C:\Program Files (x86)\Common Files\Adobe\backup20190113T124617\hdpim.db"
[Sun Jan 13 12:46:17 2019] Calling removalofCS5CapsBackupEntries
[Sun Jan 13 12:46:17 2019] Opened DB connection with path: C:\Program Files (x86)\Common Files\Adobe\caps\pdb.db
[Sun Jan 13 12:46:17 2019] DB does not exist at: C:\Program Files (x86)\Common Files\Adobe\caps\Media_db.db
[Sun Jan 13 12:46:17 2019] HD DLL Handle valid
[Sun Jan 13 12:46:17 2019] Got a valid HD Db session get func pointer
[Sun Jan 13 12:46:17 2019] HD dll Handle is valid
[Sun Jan 13 12:46:17 2019] HD getTopLevelProducts returned code: 10
[Sun Jan 13 12:46:18 2019] List of products installed on this machine
[Sun Jan 13 12:46:18 2019] Listing products for cleanup:
[Sun Jan 13 12:46:18 2019] Please enter the option number of the product you wish to remove; enter (q) to quit ... >>
[Sun Jan 13 12:46:23 2019] response 1
[Sun Jan 13 12:46:23 2019] Are you sure you want to clean all the listed products and associated files?
[Sun Jan 13 12:46:23 2019] Type (y) to confirm and remove or (n) to quit ... >>
[Sun Jan 13 12:46:30 2019] Please wait for Adobe Creative Cloud Cleaner Tool to finish........
[Sun Jan 13 12:46:30 2019] User selected: 'Clean All'
[Sun Jan 13 12:46:30 2019] *-*-*-*-*-*-* Start removing product : ALL *-*-*-*-*-*-*
[Sun Jan 13 12:46:30 2019] *-*-*-*-*-*-* Finished removing product : ALL *-*-*-*-*-*-*
[Sun Jan 13 12:46:30 2019] Action : Deleting the C:\Program Files (x86)\Common Files\Adobe\backup20190113T124617 folder as there is no product deleted.
[Sun Jan 13 12:46:30 2019] LOG FILE SAVED TO: C:\Users\o2\AppData\Local\Temp\Adobe Creative Cloud Cleaner Tool.log
[Sun Jan 13 12:46:30 2019] Adobe Creative Cloud Cleaner Tool completed successfully
[Sun Jan 13 12:46:30 2019] Please click 'Enter' to quit Adobe Creative Cloud Cleaner Tool
[Sun Jan 13 12:46:30 2019] *-*-*-*-*-*- ::START:: - SUMMARY OF Warnings -*-*-*-*-*-*
[Sun Jan 13 12:46:30 2019] *-*-*-*-*-*- :: END :: - SUMMARY OF Warnings -*-*-*-*-*-*
[Sun Jan 13 12:46:30 2019] ---------------------------------------------------------
[Sun Jan 13 12:46:30 2019] *=*=*=*=*=*=*=*=* :: End Session :: *=*=*=*=*=*=*=*=*=*=*
[Sun Jan 13 12:48:02 2019] ---------------------------------------------------------
[Sun Jan 13 12:48:02 2019] *=*=*=*=*=*=*=*=* :: Start Session :: *=*=*=*=*=*=*=*=*=*
[Sun Jan 13 12:48:02 2019] Win OS Version: 6.2
[Sun Jan 13 12:48:02 2019] Cleaner Tool version : 2.0.0.0
[Sun Jan 13 12:48:02 2019] Cleanup source directory : C:\Program Files (x86)\Common Files\Adobe\AdobeCreativeCloudCleanerTool
[Sun Jan 13 12:48:02 2019] [AdobeProgramFiles] : C:\Program Files (x86)\Adobe
[Sun Jan 13 12:48:02 2019] [AdobeProgramFiles_x64] : C:\Program Files\Adobe
[Sun Jan 13 12:48:02 2019] [AdobeCommon] : C:\Program Files (x86)\Common Files\Adobe
[Sun Jan 13 12:48:02 2019] [AdobeCommon_x64] : C:\Program Files\Common Files\Adobe
[Sun Jan 13 12:48:02 2019] [UserRoamingAppData] : C:\Users\o2\AppData\Roaming
[Sun Jan 13 12:48:02 2019] [UserLocalAppData] : C:\Users\o2\AppData\Local
[Sun Jan 13 12:48:02 2019] [StartMenu] : C:\ProgramData\Microsoft\Windows\Start Menu\Programs
[Sun Jan 13 12:48:02 2019] [System32Folder] : C:\WINDOWS\system32
[Sun Jan 13 12:48:02 2019] [SharedApplicationData] : C:\ProgramData
[Sun Jan 13 12:48:02 2019] [SharedDocuments] : C:\Users\Public\Documents
[Sun Jan 13 12:48:06 2019] Language selected: English
[Sun Jan 13 12:48:06 2019] Displaying the Adobe End User License Agreement
License agreement
[Sun Jan 13 12:48:06 2019] Please enter (y) for Yes or (n) for No. ... >>
[Sun Jan 13 12:48:13 2019] Choose from one of the following options to clean up :
[Sun Jan 13 12:48:13 2019] 1. All
[Sun Jan 13 12:48:13 2019] 2. Adobe Flash Player 10.2
[Sun Jan 13 12:48:13 2019] 3. CC Apps, Creative Cloud & CS6 Products
[Sun Jan 13 12:48:13 2019] 4. CC Apps
[Sun Jan 13 12:48:13 2019] 5. CC 2014 Apps only
[Sun Jan 13 12:48:13 2019] 6. Creative Cloud only
[Sun Jan 13 12:48:13 2019] 7. CS6 only
[Sun Jan 13 12:48:13 2019] 8. CS5-CS5.5-CS6
[Sun Jan 13 12:48:13 2019] 9. CS5-CS5.5
[Sun Jan 13 12:48:13 2019] 10. CS3, CS4
[Sun Jan 13 12:48:13 2019] 11. Adobe Id credentials
[Sun Jan 13 12:48:13 2019] 12. Fix Host File
[Sun Jan 13 12:48:13 2019] 13. Quit
[Sun Jan 13 12:48:13 2019] Choice 😆
[Sun Jan 13 12:48:56 2019] User selected: All
[Sun Jan 13 12:48:56 2019] Opened DB connection with path: C:\Program Files (x86)\Common Files\Adobe\caps\pdb.db
[Sun Jan 13 12:48:56 2019] DB does not exist at: C:\Program Files (x86)\Common Files\Adobe\caps\Media_db.db
[Sun Jan 13 12:48:56 2019] DB does not exist at: C:\Program Files (x86)\Common Files\Adobe\caps\caps.db
[Sun Jan 13 12:48:56 2019] HD DLL Handle valid
[Sun Jan 13 12:48:56 2019] Got a valid HD Db session get func pointer
[Sun Jan 13 12:48:56 2019] HD dll Handle is valid
[Sun Jan 13 12:48:56 2019] HD getTopLevelProducts returned code: 10
[Sun Jan 13 12:48:56 2019] List of products installed on this machine
[Sun Jan 13 12:48:56 2019] Listing products for cleanup:
[Sun Jan 13 12:48:56 2019] Please enter the option number of the product you wish to remove; enter (q) to quit ... >>
[Sun Jan 13 12:49:16 2019] Are you sure you want to clean all the listed products and associated files?
[Sun Jan 13 12:49:16 2019] Type (y) to confirm and remove or (n) to quit ... >>
[Sun Jan 13 12:49:25 2019] Please wait for Adobe Creative Cloud Cleaner Tool to finish........
[Sun Jan 13 12:49:25 2019] :: Cleaning-up left over inventories ::
[Sun Jan 13 12:49:25 2019] Inventory: 'uninstallts', Type: RIBS, Action: Delete
[Sun Jan 13 12:49:25 2019] Atleast one Non-RIBS Inventory : False, Atleast one AAMRef: False
[Sun Jan 13 12:49:25 2019] ::Start:: Removing AUM contents
[Sun Jan 13 12:49:25 2019] Deleting registry root:HKLM key:Software\Microsoft\Windows\CurrentVersion\Run value:AdobeAAMUpdater-1.0
[Sun Jan 13 12:49:25 2019] Exception during deleting key : (2, 'RegDeleteValue', 'The system cannot find the file specified.')
[Sun Jan 13 12:49:25 2019] Deleting registry root:HKLM key:Software\Microsoft\Windows\CurrentVersion\Run value:ADOBE_UPDATER_STARTUP_UTILITY
[Sun Jan 13 12:49:25 2019] Deleting scheduled task : AdobeAAMUpdater-1.0-TOWER-rekrut
[Sun Jan 13 12:49:25 2019] Executing command: schtasks /delete /TN "AdobeAAMUpdater-1.0-TOWER-rekrut" /F
[Sun Jan 13 12:49:25 2019] ERROR: The system cannot find the file specified.
[Sun Jan 13 12:49:25 2019] Deleting scheduled task : AdobeUpdater Task-TOWER-rekrut
[Sun Jan 13 12:49:25 2019] Executing command: schtasks /delete /TN "AdobeUpdater Task-TOWER-rekrut" /F
[Sun Jan 13 12:49:25 2019] ::Finish:: Removing AUM contents
[Sun Jan 13 12:49:25 2019] ::Start:: Removing OOBE
[Sun Jan 13 12:49:25 2019] Executing command "taskkill /F /FI "IMAGENAME eq AAM Updates Notifier.exe""
[Sun Jan 13 12:49:25 2019] INFO: No tasks running with the specified criteria.
[Sun Jan 13 12:49:25 2019] Warning: Failed to remove file,folder trying again
[Sun Jan 13 12:49:25 2019] Warning: Failed again to remove file,folder [Error 2] The system cannot find the file specified: u'C:\\Program Files (x86)\\Common Files\\Adobe/OOBE':
[Sun Jan 13 12:49:25 2019] Warning: Failed again to remove file,folder [Error 2] The system cannot find the file specified: u'C:\\Program Files (x86)\\Common Files\\Adobe/AdobeApplicationManager':
[Sun Jan 13 12:49:25 2019] ::Finish:: Removing OOBE
[Sun Jan 13 12:49:25 2019] Removing content of Product : CS5Installer, Version : CS5
[Sun Jan 13 12:49:27 2019] Deleting file : C:\Program Files (x86)\Common Files\Adobe\caps\pdb.db
[Sun Jan 13 12:49:27 2019] File does not exist: C:\Program Files (x86)\Common Files\Adobe\caps\Media_db.db
[Sun Jan 13 12:49:27 2019] Warning: Failed to remove file,folder trying again
[Sun Jan 13 12:49:27 2019] Warning: Failed again to remove file,folder [Error 2] The system cannot find the file specified: u'C:\\ProgramData\\Adobe\\SLStore_v1':
[Sun Jan 13 12:49:27 2019] LOG FILE SAVED TO: C:\Users\o2\AppData\Local\Temp\Adobe Creative Cloud Cleaner Tool.log
[Sun Jan 13 12:49:27 2019] Adobe Creative Cloud Cleaner Tool completed successfully
[Sun Jan 13 12:49:27 2019] Please click 'Enter' to quit Adobe Creative Cloud Cleaner Tool
[Sun Jan 13 12:49:27 2019] *-*-*-*-*-*- ::START:: - SUMMARY OF Warnings -*-*-*-*-*-*
[Sun Jan 13 12:49:27 2019] *-*-*-*-*-*- :: END :: - SUMMARY OF Warnings -*-*-*-*-*-*
[Sun Jan 13 12:49:27 2019] ---------------------------------------------------------
[Sun Jan 13 12:49:27 2019] *=*=*=*=*=*=*=*=* :: End Session :: *=*=*=*=*=*=*=*=*=*=*
BenPleysier Would you take a look ar this code and tell me if it's ok to install everything back on please?
It looks perfectly alright. Just follow the instructions and hopefully it will solve your problem(s)
No difference unfortunately. Still very slow opening the code view and virtually unable to open multiple html files.
You should probably put a call into Technical Support.
Apologies in advance if I'm going over old ground:
Are you using a local testing server?
Are you using GIT? If yes whats the set up? Where's the repo? Remote, network drive, local ?
Where is your working directoy, local drive, network drive, is it located in a folder being monitered by an app like like dropbox, one drive.. etc?
Have you got any extensions installed?
Some things to try (trial and error really), disable/turn off, see if it fixes the issue and then enable one by one to pinpoint the culprit :
1) Disable anti virus, any 3rd party firewall or any other app that is monitoring your system.
2) in Dreamweaver > site defintion if you have a local testing server set up try disabling/unchecking 'maintain synchronization information' under the advanced tab for the testing server.
3) In Dreamweaver > site defintion > CSS Preprocessors > uncheck 'enable autocompilation....'
4) In site definition > advanced > local info > uncheck 'enable cache (only usually a problem if there's a lot of files), but do it anyway.
5) Dreamweaver > preferences > general > uncheck 'enable related files'
6) Dreamweaver > preferences > code hints > uncheck/disable code hints
7) Dreamweaver > preferences > in-app updates > turn off
8) Dreamweaver > preferences > linting > disable
9) Dreamweaver > preferences > real time preview > select 'default to static browser preview'
10) Dreamweaver > preferences > sync settings > uncheck 'enable automatic sync'
As Dreamweaver is using Brackets as its code editor maybe search for issues with Brackets and Windows 10:
Brackets being very very slow suddenly · Issue #14515 · adobe/brackets · GitHub
Update on this. The code is now on, fully editable on all four files!
I'm being ironic here. 10 minutes waiting is not really acceptable?
Did you get any joy on this? I can't face having to uninstall all my CC and then do this mammoth exercise just to find it has done nothing. I have exactly the same problem. I'm not even trying to preview the files as I only use DW as an IDE
Just adding to this that I have, in desperation, uninstalled every Adobe product, run the cleaner, cleared out any rogue files left behind, and reinstalled. The problem is still there.
As a CC subscriber, you have access to all major versions of the program since the subscription service started. You can have any, or all, of them installed on the same machines at the same time, they just won't run concurrently.
To do that...
1. Open the CC Desktop App
2. Click the Apps tab
3. Click the small arrow icon next to DW Install/Update button
4. Choose Manage
5. Choose Other Versions
6. Pick a version prior to the Brackets engine being added (CC2015 or earlier)
Make sure to contact Adobe Customer Care here, maybe their tech support will be able to help, but at least you'll be able to get work done in the older version while troubleshooting continues in the newer one.
Thanks. I hadn't thought to get quite so retro as 2015, but it certainly resolved that particular issue; although replaced it with a whole load more, including having to unlearn about 4 years' worth of useful new features!
Now I just have to muster up the willpower and emotional resilience to deal with the support line....
Thanks. I hadn't thought to get quite so retro as 2015, but it certainly resolved that particular issue; although replaced it with a whole load more, including having to unlearn about 4 years' worth of useful new feaures!
CC 2015 uses the good old original, reliable Dreamweaver code editor The Brackets integrated one, introduced since CC 2017 has given people glitches and perfomance issues of one form or another ... I may be wrong but I'm guessing the idea behind droppping Brackets into DW, was to reduce the development time spent on Dreamweaver going forward??? ..... if I could wish for one thing .... I'd have the old code editor back in a heartbeat, with a few updates and new features of course ...... Caught between a rock and hard place ..... I like the GIT panel and a few of the newer features in CC 2017/2018/2019 but I just keeping going back to CC 2015 when the code editor in CC 2019 starts playing up
