I want to do it by C++ ,the windows API is impossible,Is there an official interface?
Not that I could help you, but can you describe in more detail what you would like to achieve?
If language is an issue, try pasting a screen shot to this thread, and mark what you are referring to.
hi,I want to getting the menustring ,but using CMenu of windows API is fail
Hi
Adobe provide a scripting interface, although I don't know whether that will give you what you want
Adobe Photoshop Scripting
There is also a scripting sub-forum : Photoshop Scripting
Any other access is prohibited under the terms of the license which states that you must not "access or attempt to access the Services or Software by any means other than the interface we provide or authorize"
Dave
thanks,but It's not what I want
Perhaps not exactly that you want as on video I haven't notice that you see can be applied on open menus:
i attempt to used the visual studio import to "adobe photoshop CC 2019 object Library<1.0>",but there is no interface for menus
Careful guys , this is straying into the area covered by the legal terms of use which state
18. No Modifications, Reverse Engineering.
Except as expressly permitted in the Terms, you may not (a) modify, port, adapt or translate any portion of the Services or Software; or (b) reverse engineer, decompile, disassemble or otherwise attempt to discover the source code or any portion of any Service or Software. If the laws of your jurisdiction give you the right to decompile the Software to obtain information necessary to render the licensed portions of the Services or Software interoperable with other software, you must first request such information from us. We may, in our discretion, either provide such information to you or impose reasonable conditions, including a reasonable fee, on your decompilation of the Services or Software to ensure that our and our suppliers’ proprietary rights in the Services and Software are protected.
龚亮g64532194 this is a user forum. If your requirement goes beyond the provided scripting interface then you will need to contact Adobe directly, which you can do via the Contact us section using the support link at the top of the forum.
Dave
