I'm trying to add the fill of an object to my CC library. I'm grabbing the object and dragging it into the library window and it is only allowing me to add it as a graphic. When I click the Plus + sign in the bottom left corner it is only giving me the option to add as a graphic. Any idea what I'm doing wrong?
Click the + icon at the lower left in the CC library panel instead of dragging.
What we need to see is what you want to add to the library.
Thanks for reaching out to help. It looks like we got an answer.
Thank you. This is the way I used to do it. For some reason, I'm not sure if it was the way the file was saved, but it was not giving me those options. I've opened a couple other files I have inherited and I'm now seeing those options again. Here is a follow-up, if those are options are not all present, is there a way to get them back?
Never seen the options disappear, so I don't know what to do to get them back.
If it happens, can you post a screenshot?
