So I have spent multiple weeks editing a certain video, only to find that when I export it, it fails, saying that there's an unknown error. I read the forums on this issue and one of the recommendations was to export audio only or video only to check the problem. I tried it and found that when I uncheck 'export audio' and then export it, it exports just fine. Then I tried exporting audio only and then later combine them but it didn't work, meaning that there's an issue with the audio. But I need the audio, and I don't know how to fix this. Help me please!!
When you exported audio only, what specs did you use?
When you tried to combine them, what specs did you use?
When i export audio only:
Audio format : AAC
Audio Codec : AAC
Sample rate : 48000 hertz
Bitrate : 256
Precedence : Bitrate
I pretty much left them on default, because they used to work fine previously.
And no, i couldn't combine them in the first place because the audio wasn't exporting. That's the main problem.
OK.
Export to .wav files instead of AAC.
