HI!
I think the title of this conversation speaks for itself. I work a lot with the integration After Effects-Premiere and Dynamic Link, which I find extremely useful. The Problem appeared a couple of days ago when I tried modifying a composition in AE. The changes I did to this composition didn't appear in the linked composition in Premiere. I closed both applications, restarted computer, unlinked and relinked AE comp, deactivating clips in the timeline... Nothing worked.
Has that happened to anyone? Is there a solution to this problem?
The only one I found is saving again the document with a completely different name and re-importing it in Premiere. Re-importing the document without having it saved with another name didn't work as well. The problem is, when I modify this document again, then I have to save and re-name it again. And I end up with 20 different files which is not so efficient.
Thank you all!
Cheers.
What number versions of Premiere Pro and AE?
After Effects 16.0.1 (Build 48)
Premiere 13.0.3 (Build 9)
Everything up to date.
