Join us for the next Community Q&A Coffee Break on Tuesday April 23, 2024 with Eric Matisoff, Principal Evangelist, Analytics & Data Science, who will join us to discuss all the big news and announcements from Summit 2024!
SOLVED
Set percent or demical in "Intelligent Alerts"
Avatar
Level 8
Level 8
How to set percent, demical in "intelligent alerts" under: "is below or equals" criteria?
e.g.
Set a daily alerts "Bounce Rate" is above or equals "55%".
I tried to type 55%, or 0.55, but failed to input.
Thanks in advance.
1 Accepted Solution
Avatar
Correct answer by
Community Advisor
did you try with "55"? otherwise create your own metric (100*Bounce rate) and check against "55"
Avatar
Correct answer by
Community Advisor
Avatar
Level 8
Level 8
Thanks ursboller, the 100*bounce rate is a good way.
the "55" does not work ;(
Avatar
Community Advisor
remark: I almost never use the default "bounce rate" since I don't fully trust this metric, instead I use my own metrics. carefully watch the alerts if you get what you wnat
