2
A low-level exception occurred in: Adobe Scopes (Transmit::CreateInstance)
Oct 17, 2018 Oct 17, 2018
I got the Adobe Premiere Pro 2019, and after 2 days, this issue came up. I have not been able to use Premiere since then. I re-installed the program, but the issue is still there. What can I do?
137.3K
correct answers 2 Correct answers
Community Beginner , Oct 19, 2018 Oct 19, 2018
resetting preferences seems to have done the trick.
airoma​ hold down the Option (Alt on Windows) button while you click on Premiere, until the splash screen appears.
Adobe Employee , Oct 19, 2018 Oct 19, 2018
Hi darshanp2386254,
Sorry to hear that you are facing this issue. Please try to reset Premiere Pro preferences (FAQ: How to reset (trash) preferences in Premiere Pro?) and clear cache (FAQ: How to clean (delete or trash) media cache files? ) to isolate any issues caused due to the corruption of cache or preferences. Hope you find it useful, let us know if you have any questions.
Sumeet Kumar Choubey
Adobe Employee ,
Oct 18, 2018 Oct 18, 2018
Hi darshanp2386254,
Sorry for the trouble. Please elaborate when exactly you are getting this error message?
Is there any specific action that triggers it? What are the system specs?
Vidya
After this event, the program becomes unresponsive and the only way out is to Force Quit. As a result the project is either no longer readable and I have to start over, or it is reset to an earlier auto-save point (not the latest manual save as that seems to be corrupted).
From what I can tell, the last thing I did was adding footage to the timeline, either to create a new sequence or to add to an existing one.
Specs:
iMac (Retina 5K, 27-inch, Late 2015)
Processor 3.2 GHz Intel Core i5
Memory 16 GB 1867 MHz DDR3
High Sierra 10.13.6
Same issue here...I'll try resetting prefs.
Specs:
iMac Retina 5K, 27 inch, late 2015
os High Sierra 10.13.6
4 GHz Intel, core i7
32 GB memory
AMD Radeon R9 M395X graphics
Resetting the prefs worked for me!  Whew!
Jan 01, 2019 Jan 01, 2019
on MacBook Air
a low exception occurred in: ambitos de adobe (transmit::createinstance)
Same here. yesterday I was working normally, this morning the timeline won't start, by spacebar or any shortcut or even by clicking. Same thing when I try to create a new project and start an edit from scratch.
Specs
MacBook Retina (15.6 / Late 2014)
i7 2,2GHz
16gb RAM DDR3OS Mojave
Same here got an error. have to open everything in an older version. Please let me know if you find a solution.
I had the same issue. I reset my preferences and cleared the cache and that appears to have solved the problem...for now.
how did you reset my preferences
Thank you so much. This worked.
Dec 29, 2018 Dec 29, 2018
PLEASE HOW DID YOU DO THAT ON MAC
I HACE TRIED THE OPTION AND SHIFT BUT ITT JUST OPEN STIFENDER TO PREMERE
HOW DO I DELETE THE How to reset (trash) preferences in Premiere Pro?
Jan 16, 2019 Jan 16, 2019
How do you reset preference please? Thanks
Oct 23, 2018 Oct 23, 2018
Resetting the preferences worked for me. Thank you!
Oct 24, 2018 Oct 24, 2018
Thanks! Same issue here. It worked for me as well.
Feb 26, 2019 Feb 26, 2019
Thank you. it worked like a charm!
Mar 15, 2019 Mar 15, 2019
I had the same issue, and I was also able to fix it by resetting preferences. Thank you!
Jul 05, 2019 Jul 05, 2019
Thanks !
Adobe Employee ,
Hi darshanp2386254,
Nov 14, 2019 Nov 14, 2019
Resetting preferences only temporatrily fixies it. Then comes back.
What is the problem?
Is there any news on theis problem.
I have lost more than a day doing a simple edit.
Still no solution.
Try deleting your saved Workspace files (they can be found under "Documents/Adobe/Premiere Pro/13.0/[User-Profile]" in the "Layouts" and "ArchivedLayouts" folders). I had this issue for months and kept resetting my preferences only to have the problem come back, but when I deleted my Workspace files, everything returned to proper working order, and I haven't had any issues since the beginning of September.
It may be a bit of a pain, having to rebuild your workspaces, but significantly less painful than rebuilding your preferences every week to every day.
Oct 21, 2018 Oct 21, 2018
Correction: Reseting my preferences did help! I didn't do it the right way the first time.
Same thing just happened to me. This morning everything was fine; now all of the sudden there's no playback and the program just 15" freezes. Reseting preferences, deleting cache etc. didn't help.
MacBook Pro 15" 2018
2,6 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 560X
MacOS Mojave 10.14
Dec 03, 2018 Dec 03, 2018
Спасибо все сработало!
