1. Re: Convert multiple files (word docs) to multiple pdf
Bernd Alheit Oct 24, 2008 1:42 AM (in response to (Fran_Warder))In Adobe Acrobat Professional you can use a batch sequence. -
2. Re: Convert multiple files (word docs) to multiple pdf
(Fran_Warder) Oct 24, 2008 2:15 AM (in response to (Fran_Warder))I was asking how to do this - as there doesn't appear to be a batch process for this. -
3. Re: Convert multiple files (word docs) to multiple pdf
try67 Oct 24, 2008 2:18 AM (in response to (Fran_Warder))Hi Fran, I think this might be possible using a JavaScript and a Batch sequence. For more details contact me by email. -
4. Re: Convert multiple files (word docs) to multiple pdf
Bernd Alheit Oct 24, 2008 2:26 AM (in response to (Fran_Warder))Create a new batch sequence. Select 'Run commands on Selected Folder'. In the source file options enable 'Microsoft Office Word'. Then let run the sequence. -
5. Re: Convert multiple files (word docs) to multiple pdf
(Fran_Warder) Oct 24, 2008 2:29 AM (in response to (Fran_Warder))There is no batch sequence for converting files to pdf... otherwise I would have done this! -
6. Re: Convert multiple files (word docs) to multiple pdf
Bernd Alheit Oct 24, 2008 2:30 AM (in response to (Fran_Warder))try67,
why didn't you post your solution in this forum? -
7. Re: Convert multiple files (word docs) to multiple pdf
(Fran_Warder) Oct 24, 2008 2:47 AM (in response to (Fran_Warder))I still don't have a solution to this, so any ideas would be greatly appreciated. -
8. Re: Convert multiple files (word docs) to multiple pdf
Bernd Alheit Oct 24, 2008 2:54 AM (in response to (Fran_Warder))Did you try the batch sequence? -
9. Re: Convert multiple files (word docs) to multiple pdf
(Fran_Warder) Oct 24, 2008 3:15 AM (in response to (Fran_Warder))As I already posted - there is no batch sequence to convert multiple Word documents to Multiple pdfs without opening them all - that was the first place I looked. I need a JavaScript to do this with the batch sequence. -
10. Re: Convert multiple files (word docs) to multiple pdf
(Fran_Warder) Oct 24, 2008 3:32 AM (in response to (Fran_Warder))I think I need to clarify a bit here - I need to convert around 1500 documents from Word format to pdf format. I need a batch process that will do this WITHOUT opening each Word document, and WITHOUT opening each completed pdf document.
Using a new sequence in the batch processing, it is possible to convert documents, but for every document you do, you have to keep clicking on "OK" when it tells you that "whatever" can't be saved because it is open elsewhere (Acrobat is opening the thing in the first place) and I would end up with about 1500 open Word documents (which would crash my computer).
I need to run a batch process, unsupervised (so I can get on with the rest of my work on a separate computer) that won't open each document as it processes it. -
11. Re: Convert multiple files (word docs) to multiple pdf
Bernd Alheit Oct 24, 2008 3:42 AM (in response to (Fran_Warder))> Using a new sequence in the batch processing, it is possible to convert documents, but for every document you do, you have to keep clicking on "OK" when it tells you that "whatever" can't be saved because it is open elsewhere (Acrobat is opening the thing in the first place) and I would end up with about 1500 open Word documents (which would crash my computer).
Looks like a problem with your installation. I don't have any problem using such a batch sequence. -
12. Re: Convert multiple files (word docs) to multiple pdf
(A_Henderson) Nov 11, 2008 10:23 AM (in response to (Fran_Warder))I tried the instructions Bernd Alheit posted and i was successful. I'm using Acrobat 8 Pro and i converted 300 files. Thamks Bernd -
13. Re: Convert multiple files (word docs) to multiple pdf
(Fran_Warder) Nov 12, 2008 1:10 AM (in response to (Fran_Warder))Thanks - I'm using Acrobat 7 Pro at work, so I guess I'll have to take the files home and try that on Acrobat 8 instead.
Thanks for all the ideas :) -
14. Re: Convert multiple files (word docs) to multiple pdf
TomQA Jan 25, 2009 1:24 PM (in response to (Fran_Warder))Bernd,
Does the batch use the user-set preferences in Word for converting the .docx or is this a "generic" conversion?
Secondly, I almost missed your solution because it was so simple :-) I was looking for a JavaScript.
Tom -
15. Re: Convert multiple files (word docs) to multiple pdf
hellodarby Apr 6, 2009 10:31 AM (in response to Bernd Alheit)Hello,
I am trying the same function in Acrobat Pro 9, but there is no function listed in my option to enable wrod docs...
What can I do?
16. Re: Convert multiple files (word docs) to multiple pdf
meed33 Apr 17, 2009 1:18 AM (in response to Bernd Alheit)I followed your advice but I don't have "Microsoft Office Word" as an option in my source file options. Do you know what would be missing - I have Office 2004 for Mac.
17. Re: Convert multiple files (word docs) to multiple pdf
Coreopsis2 Sep 23, 2009 11:55 AM (in response to Bernd Alheit)Bernd, we are searching for a way to convert multiple Word files as well, but can you clarify with more steps how we 'create a new batch sequence'? Was not able to figure out how you do this. We have Adobe Acrobat Standard 9. Really appreciated if possible!
18. Re: Convert multiple files (word docs) to multiple pdf
Bernd Alheit Sep 23, 2009 1:22 PM (in response to Coreopsis2)Batch sequences are not available in the Standard edition.
19. Re: Convert multiple files (word docs) to multiple pdf
Aussie_leah Aug 2, 2011 5:18 PM (in response to Bernd Alheit)Thanks Bernd, your instructions worked for me. I was a little confused at first as I was trying to work out what command to use - but there is no command! You ignore point 1. and just do 2. and 3.
For those who find this forum through Google if you want to merge a number of Word Documents into a single PDF go to file - create PDF - from multiple files. This will convert seperate Word docs into one PDF.
20. Re: Convert multiple files (word docs) to multiple pdf
JBOctorara Apr 29, 2013 6:57 AM (in response to Bernd Alheit)Hello, could you tell me how to batch convert multiple word documents to pdfs in acrobat pro 9.5.3? It doesn't seem to recognize word as a supported source file. Thank you for any help you can give! Jamie
21. Re: Convert multiple files (word docs) to multiple pdf
williamrocket Jul 11, 2013 4:08 PM (in response to JBOctorara)I am having the same problem- I have Acrobat XI pro- and i haven't been able to figure out how to batch convert word files to PDF. I actually need to convert them to PDF/A, but I would be happy to at least get the first step of converting them to PDF, because I think I could figure out from there how to use the preflight option to convert the PDFs to PDF/A
22. Re: Convert multiple files (word docs) to multiple pdf
try67 Jul 12, 2013 1:21 AM (in response to williamrocket)Create an Action without any commands and run it on the folder with the Word files. They'll be automatically converted to PDF files.
23. Re: Convert multiple files (word docs) to multiple pdf
williamrocket Jul 12, 2013 10:06 AM (in response to try67)Good idea. I tried to create the action, thought, and if I don't add any tools to it it won't let me save the action-?
24. Re: Convert multiple files (word docs) to multiple pdf
try67 Jul 12, 2013 10:52 AM (in response to williamrocket)Yeah, I see... They changed how it works. Just add a Save command, then.
25. Re: Convert multiple files (word docs) to multiple pdf
CtDave Jul 12, 2013 10:53 AM (in response to try67)Just me nattering here; but --
Something is different with Acrobat XI Pro and Office 2013.
Open Acrobat XI Pro's Preferences. Select the Category "Convert to PDF". Note that you may not have any MS Office applications listed.
Without that you cannot create an Action to operate on a "supported" file (format) as Word, Excel, etc won't be present.
As a data point:
--| Windows 8 (64-bit)
--| Acrobat XI Pro (via a TCS v4 subscription)
--| Office 2013 applications (via an Office 365 Home Premium subscription)Acrobat's PDFMaker is present and functional for:
--| the Excel install
--| the Word install
--| the Outlook install
--| the PowerPoint installFor MS Access, reports can go to PDF or XPS via the MS publish to PDF routine (or exported to a Word rich text file or printed via the Acrobat installed Adobe PDF virtual printer).
For One Note Print to PDF using the Adobe PDF virtual printer.
Be well... -
26. Re: Convert multiple files (word docs) to multiple pdf
trinkalinka Dec 24, 2013 3:06 AM (in response to CtDave)Hi everyone!
I have a semi-solution for the problem, i hope you will like it!
If you use Adobe Acrobat Pro, then you have a printer named Adobe PDF.
Go to the Devices and Printers menu in the Start menu, then right click on the Adobe PDF printer.
Then click on the "print setup" or "print settings"*.
On the Adobe PDF Settings tab set the output folder and click out the "View Adobe PDF result" and OK.
Then go to that folder, where the doc files placed, Ctrl+A and right-click->Print.
I takes pretty long time, but after that the single PDFs created.
Enjoy!
Andras
*Sorry for that guys, just I use a hungarian version of win7 so I dont know the exact english form.
27. Re: Convert multiple files (word docs) to multiple pdf
gkaiseril Dec 24, 2013 7:40 AM (in response to trinkalinka)The conversion of MS Office documents to PDF goes through a number of steps and helper programs. You may need to check the PDF converter within Word for the option to prompt or not prompt for file name, Distiller for the same option,and the Adobe PDF printer for the same option. Also make sure the option to display the resulting PDF is turned off.
28. Re: Convert multiple files (word docs) to multiple pdf
iblader Oct 2, 2014 7:56 AM (in response to (Fran_Warder))You can create a portfolio of a folder of Word files. Then extract the files from the portfolio to individual PDFs.
29. Re: Convert multiple files (word docs) to multiple pdf
gkaiseril Oct 2, 2014 10:05 AM (in response to iblader)If you add Word files to a Portfolio there is an option to convert the file to PDF but this assumes you have everything setup properly for the use of PDF Maker.
30. Re: Convert multiple files (word docs) to multiple pdf
iblader Oct 2, 2014 11:20 AM (in response to gkaiseril)I don’t recall setting anything up for PDF Maker, and I’ve installed Acrobat hundreds of times. Is it sometimes a problem?
31. Re: Convert multiple files (word docs) to multiple pdf
gkaiseril Oct 2, 2014 12:01 PM (in response to iblader)For some it is.
32. Re: Convert multiple files (word docs) to multiple pdf
mike77777777 Nov 17, 2014 3:19 PM (in response to (Fran_Warder))Batch conversion from supported file formats to pdf can be done by creating an action with Action Wizard:
Click Tools button from the upper right>Click Action Wizard>Click Create New Action...>Click Save & Export from the left panen>Click Save>Click the button that it's located between the left and right pane>Click Specify Settings from the right panel.
Now, I checked the box called PDF Optimizer>Click Settings and then, on Images category, for Color Images and Greyscale Images I choosed Maximum Quality, which increase the file size, but it's OK for me.
Now, I clicked the Save button and provide a name for this profile settings, something like "Maximum quality".
Click OK, click OK, click Save, provide a name for this Action, something like "Convert all to pdf at maximum quality", then click Save.
When you want to convert, for example a bunch of .docx files to pdf, open Adobe Acrobat Professional, click Tools from the upper right, click Action Wizard, under Actions, click "Convert all to pdf at maximum quality", choose Add files or Add folder from the drop down menu located immediately under "Files to be processed:", browse and select the folder that contain .docx or other files formats, click OK, click Start.
Adobe Acrobat Professional will start conversion, without unwanted prompts.
When the job is finished, click Close, and close Adobe Acrobat Professional. If it prompt to save changes to untitled, click No.
33. Re: Convert multiple files (word docs) to multiple pdf
llamallamaduck Feb 9, 2015 1:21 PM (in response to (Fran_Warder))4 people found this helpfulI have Acrobat 9 Pro. I can batch convert Word docs to PDFs by doing this:
1. Open Acrobat Pro. Click File > Create PDF > Batch Create Multiple Files...
2. A window will open prompting you to add files. Click Add Files > Add Files... OR Add Folders... If adding a folder, navigate to it, and click OK to add it to the list. You can also select a bunch of files and drag & drop them into the Add Files window.
3. Once you have all the files listed that you want to convert, click OK. A new window called Output Options will open. In this window, select your preferred settings. For me, I want all the new PDFs to have the same filename and be in the same folder as the Word docs, so I choose these settings:
4. Click OK, and then the batch process will begin running. You will see Word opening and closing. However, you won't have to click Save or anything. You can run it unattended. The process takes a little while, so I usually set up a batch to run, then go to lunch. Once finished, you should have all your new PDFs:
Hope that helps someone!
34. Re: Convert multiple files (word docs) to multiple pdf
waldod27167014 Feb 17, 2017 4:33 AM (in response to (Fran_Warder))[ Mod: Spam removed ]
35. Re: Convert multiple files (word docs) to multiple pdf
John.Awad Feb 17, 2017 1:55 AM (in response to llamallamaduck)@llamallamaduck, that's exactly what the OP was looking for, and what I was looking for too. Thank you so much!
36. Re: Convert multiple files (word docs) to multiple pdf
Liquid Blue Jul 10, 2017 1:49 PM (in response to llamallamaduck)However with the latest Acrobat Pro DC I cannot get any of this to work.
Batch processing multiple word documents is a PITA currently.
Newest Version and newest Word.Any help?
37. Re: Convert multiple files (word docs) to multiple pdf
shanedelorme Oct 24, 2017 7:40 AM (in response to Liquid Blue) -
38. Re: Convert multiple files (word docs) to multiple pdf
denverp1441270 Nov 7, 2017 8:51 AM (in response to llamallamaduck)Thank you!
