5
Using Google maps in Adobe XD
Mar 18, 2016 Mar 18, 2016
Can you embed a Google Map into XD?
<The Title was renamed by moderator>
How to , Plug-ins
94.0K
correct answers 2 Correct answers
Adobe Employee , Oct 03, 2019 Oct 03, 2019
Hi all,
Thank you for trying the steps mentioned by Preran. We would request you to please raise your request here: https://github.com/boopeshmahendran/AdobeXD-maps/issues/6 and upvote the request to the plugin support page. Hope it helps.
Harshika
Adobe Employee , Dec 12, 2019 Dec 12, 2019
I found a plugin that you could use to include Google Maps in your XD artboard. Check out the Umap plugin. See https://helpx.adobe.com/ca/xd/help/plugins.html#view for info on installing plug-ins in XD.
Adobe XD now supports scrolling in all directions. You can use Scroll Groups in Adobe XD to do that. For more info, see https://helpx.adobe.com/ca/xd/help/create-scroll-groups.html
Preran
Adobe Employee ,
Not at the moment, but please feel free to enter a suggestion in UserVoice, our tool for tracking feature requests and bug reports: Adobe XD: Feature Requests: Top (59 ideas) – Adobe XD Feedback : Feature Requests & Bugs
Thank you,
Joe
Adobe Employee ,
Apr 02, 2019 Apr 02, 2019
In the time that the feature makes it to the product, I suggest trying the Maps Generator plugin in Adobe XD.
To install the plugin, select Plugins > Discover Plugins in Adobe XD. Search for Maps Generator
*Because I have already installed the plug-in, you see the Update button displayed. If you are installing it for the first time, you will see the Install button.
After you install the plugin, the name is displayed under Plugins. Now, do the following:
  1. Create a shape on your artboard in which you want to insert the map.
  2. Select Plugins > Maps Generator
  3. Enter the Address under Location, select the Zoom level, and the type of view for the map (Roadmap, Satellite, Terrain, Hybrid.)
  4. Click Generate Map.
when i do these same process you appear this error: REQUEST HAD AN ERROR: ${REQ.STATUS
Same here. REQUEST HAD AN ERROR: ${REQ.STATUS
Adobe Employee ,
Hi all,
Harshika
Oct 20, 2019 Oct 20, 2019
Have you figured this out? I am getting the same Error.
Oct 22, 2019 Oct 22, 2019
I'm waiting to fix the bug (REQUEST HAD AN ERROR: ${REQ.STATUS). It's 2 weeks now with the same error.
Same issue here
Oct 23, 2019 Oct 23, 2019
Same issue here
Adobe Employee ,
Oct 24, 2019 Oct 24, 2019
Hi All,
We are sorry to hear you're experiencing issues while using the plugin. However, we would like to confirm if you've all submiited your feedback request on the link i've mentioned above as this needs to be taken care by plugin support.
Once you'll go through the link, you'll see multiple solutions to troubleshoot the issue. We would request you to please go through the steps shared and share your results with the plugin support team.
Hope it helps.
Harshika
Nov 27, 2019 Nov 27, 2019
Looking in the source, I think I found what the problem is.
const apiKeys = require("./apiKeys.json").apiKeys;
Looks like we may have to make our own API keys file, which I dont see in the source and shoudl not see.
I will make some adjustments possibly and give some instructions after testing my fix.
In the utils  you grab a random API key for maps look like
function getApiKey() {
const length = apiKeys.length;
return apiKeys[Math.floor(Math.random()*length)];
which this is a pluglin that requires the users to depend on your api keys which looks like may have been removed from source, which the API billing will be on the developers dime. I am assuming the file is jsut an array of API keys. You may can go into the plugins folder add the JSON file thats missing , I am testing that as we speak or have to add the file and recompile.
This may require a credit card from users if they would like to use it.
Nov 28, 2019 Nov 28, 2019
Sara I can help you fix this
A temp fix would be to go into the plugin directory and find the plugin and change the API.
You would have to make a google api account  and activate it and set for static google maps api.
Replace the default key with the new key, also take into consideration it may cost. Its about $2.00 every 1000 request, so I recommend to copy and paste and reuse when possible.
Also as mentioned I saw a merge request to give the ability to put your own API key, which means you would have to repeat the steps above.  I actually added the changes to the copy of the plugin that I downloaded.
Apr 24, 2021 Apr 24, 2021
Hi, I can't seem to find the Map Generator plugin. Is it still available now?
Mar 09, 2022 Mar 09, 2022
This plugin no longer exsists
Adobe Employee ,
It looks like this plugin has been removed from the list. I am checking wiht the team to see if there is anything else you could use in the meantime. Will update this post as soon as I hear from them.
Adobe Employee ,
Preran
I can give you the copy that I fixed.
Jan 07, 2020 Jan 07, 2020
I could try it
Jan 09, 2020 Jan 09, 2020
Hi!
Would be so happy if you could share that map plug in with me (and probably also others 🙂 ..) Is it possible? Also I still look for a plug in which makes it possible for me to use external links. Do you know where to find that?
Thanks in forward!
Mark
Jun 02, 2020 Jun 02, 2020
Hi, can you maby send me the copy?
Dec 17, 2019 Dec 17, 2019
I tried using the plugin from GitHub but it doesn't really work. Also, it just a screenshot of the map and not the map that you can interact with. I am working on an application that requires map simulation and interactivity.
Would be cool to have an integration of dynamic map like Framer X does with Mapbox studio https://www.youtube.com/watch?v=hY4W0MGHNog
Mar 30, 2020 Mar 30, 2020
Hello Everyone,
Here I've found an alternative to Google Maps
U Map
you can download with the below link
https://adobe.com/go/xd_plugins_discover_plugin?pluginId=593fc326
