500 error viewing http://localhost/flex2gateway
Avatar
Level 1
I’m trying to setup Flex 3 to work with CF using Flash
Remoting and I’m stuck getting the flex2gateway to work. I
have CF 8 installed as a standalone server integrated with IIS. I'm
getting a 500 error when I view
in a browser. Here’s the error and various things I’ve
tried. I’ve been all over the web and found a number of
suggested resolutions but none of them work. Sites I’ve
looked at include:
http://www.drisgill.com/index.cfm/2006/3/22/Flex-2-Beta-2--flex2gateway-Problem
http://www.forta.com/blog/index.cfm?mode=search
Here's the error when I try to hit the gateway from my mxml
page:
ERROR: [RPC Fault faultString="Send failed"
faultCode="Client.Error.MessageSend"
faultDetail="Channel.Connect.Failed error
NetConnection.Call.Failed: HTTP: Failed: url: '
http://localhost/flex2gateway/cfamfpolling'"
I’m still totally stuck here (it’s been a solid
10+ hours). I’ve visited at least 20 sites that all have
solutions that worked for them including:
- running
C:\ColdFusion8\bin\connectors\Remove_ALL_connectors.bat followed by
C:\ColdFusion8\bin\connectors\IIS_connector.bat
- Editing services-config.xml and changing the value of the
uri argument in the endpoint node for the channel-definition of
‘cf-polling-amf’. I’ve tried all sorts of things
like removing {context.root} from the path, hard coding the path,
etc. What’s strange to me is that no matter what I change the
value too, even something fake like “FOOBAR”, the error
always shows the same failed url (and I restart CF in between too)
- Ensuring
- Ensuring the "/" is at the end of my path (i.e.
http://localhost/flex2gateway/")
Any help would be so greatly apprieciated.
Thanks in advance!
