Adobe Illustrator crashes opening a file.
Aug 04, 2018 Aug 04, 2018
Just installed CC 2018 (4 times) and every time it crashes when I open a file. Anyone else experiencing this, have a solution (I've removed it, removed preferences, restarted, logged out and in again. Then proceed to get a crash report message every time. Please help.
21.9K
correct answers 2 Correct answers
New Here , Aug 28, 2018 Aug 28, 2018
Deactivating the GPU Performance did the trick.
Adobe Employee , Sep 15, 2020 Sep 15, 2020
Hi all,
We understand how frustrating crashes can be. We have consolidated the most popular solutions that help in fixing these issues and also, how you can recover unsaved documents after a crash. Please check this help article for more details.
If you still need help, feel free to reach out, we'd be happy to help.
Srishti
Adobe
Is a printer connected and turned on?
Does it happen with every file?
Adobe Employee ,
Aug 24, 2018 Aug 24, 2018
Hi Robert,
We have been waiting for your response to this query. Kindly update the discussion if the issue is resolved. If not, please share a few more details like:
Operating System(Exact Version of Windows or MAC)
Is it happening with a particular file? If yes, would you mind sharing your file?
Srishti
I'm having the same issue.
Doesn't matter what file I try to open.
I can't even create a new file.
I am using Windows 10.
Oct 25, 2018 Oct 25, 2018
Worked for me! Thanks!!!
Jul 23, 2019 Jul 23, 2019
Deactivating the GPU Performance fixed it for me! Thanks!!
Oct 01, 2020 Oct 01, 2020
Deactivating the GPU Performance fixed it for me aswell. I think its becuase its trying to use the GPU as a Visual feed instead of another processor on your system. If your having any troubles on any other programs check the GPU first. Also I downloaded Adobe Acrobat PDF printer aswell before I tried this. I know its a known fix so I hope this extra info helps someone.
Oct 05, 2018 Oct 05, 2018
i am having the same problem and its any file i try
Is a printer connected?
If not, connect one.
Mar 06, 2024 Mar 06, 2024
This trick saved me. Thx!
Apr 17, 2019 Apr 17, 2019
I discovered the source of the problem.
@michalf63166855 said turning off GPU rendering did the trick for him. This is a workaround, not a diagnosis. The real problem is settings within the GPU settings app released by the manufacturer of the GPU architecture. For an nVidia card, modify the 3D settings for Illustrator in the nVidia Control Panel. I had enabled some 3D enhancements for all of my programs and games in the Global Settings. This caused a problem with Illustrator, so I had to specifically disable these for the Illustrator executable.
Manage 3D settings > Program Settings > Select a program to customize > Adobe Illustrator (illustrator.exe)
-> Change all settings to the default settings for the card. If you changed the "Global Settings", the "Program Settings" must be reverted to what they were prior to your modifications of the Global Settings. Every Program Setting that can be set to "Application Controlled" needs to be set to "Application Controlled".
These two changes fixed the problem for me:
~Anti-aliasing mode: Application controlled
~Vertical sync: Use the 3D application setting
The "default printer" problem makes zero sense. No programmer would ever check for a printer during a file read. A does not imply B.
@Adobe you need to fix your GPU code to handle the error and give a helpful message, instead of crashing the program.
Apr 18, 2019 Apr 18, 2019
That might be the case.
But in the recent 10 years or so we have discovered on the forums in countless threads that an unavailable printer can ineed cause issuess and connecting a printer or setting up a PDF printer can solve them. It's not the only cause of crashes on opening a file, but it's definitely one of them.
Oct 02, 2019 Oct 02, 2019
This doesn't fix it at all for me...
Oct 03, 2019 Oct 03, 2019
This is a long thread. Please tell us your exact issue, your setup (system and Illustrator version) and what you already did to address the problem. Please create a new thread.
Jun 26, 2020 Jun 26, 2020
Never fix ita at all.  But I don't understand why this will be our user problem to fix the issues every time.  I am just so frustrated.  Can't Adobe Illustrator team actually do somework about it?  They get pay to do so, no?
They can only fix what they can locate. So will you please tell us what your actual issue is? And which system, version this is about?
Oct 07, 2019 Oct 07, 2019
I'm having the same issue. Turning off 3D acceleration either in app or in Nvidia settings as described does not work. Trying to open any .ai file within Illustrator causes a crash.
So.... About that printer thing. I eventually climbed down from my presupposed-knowledge-tree and switched the default printer. And it worked!
But why would that be a problem for Illustrator? It seems to me that this is something that Adobe should look into and "fix" in a future update. It doesn't make sense that Illustrator should check for printer already at open project.
Oct 08, 2019 Oct 08, 2019
Illustrator stores information about the printer in the file (and yes, new documents are also based on existing files), that's what the "Done" button in the "Print" dialog is all about. When Illustrator opens a file, it checks if the printer is still there. And yes, Illustrator shouldn't crash. But it does.
Oct 10, 2019 Oct 10, 2019
Same issues here, I can approve that changing the standard printer in windows 10 works. Adobe should definitely find a solution for this workaround tho.
Mar 31, 2020 Mar 31, 2020
There are solutions where changing the printer works, however when I go to edit the printer preferences Illustrator crashes just like when trying to open a file...any thoughts?
Check the printer setup in your system.
Which system is it?
What kind of printer do you use?
Jun 12, 2020 Jun 12, 2020
I had this exact issue. Happenned following a couple of Windows 10 system updates. Re-installed Illustrator and CC completely with no fix. Tried the GPU work around. The error kept saying it was 'exceptional access error'.
Turns out changing my default printer to Windows Print to PDF solved it!
First solution - change your default printer ! If I had known this instead of trying everything else, I would have saved 2 days. Hope this helps.
Feb 27, 2021 Feb 27, 2021
Thanks, this worked for me after trying everything else,, Adobe really need to fix this problem
