Exit Code: 183
-------------------------------------- Summary --------------------------------------
- 2 fatal error(s), 0 error(s), 1 warnings(s)
FATAL: Error (Code = 183) executing in command 'RunProgramCommand' for package: 'UWPAssets', version:20.1.12.4
FATAL: Error occurred in install of package (Name: UWPAssets Version: 20.1.12.4). Error code: '183'
WARN: Program "C:\Program Files\Common Files\Adobe/Adobe XD/PluginCleanup.exe" failed with exit code: -1073740791
Every time I try to download Adobe XD this pops up. When I go to the website on the error code and solution it just says to click retry and downloads again. I click retry but the same error code keeps coming up.
HI There.
Please try this simple step to fix this issue
Go to CONTROL PANEL>Programs and features> Add or remove programs
Look for the programs whose name starts with Microsoft visual C++
There must be 7 or more such programs
Uninstall all of them one by one
Then try to Install XD
once XD is successfully downloaded you can Restart your machine and all the microsoft visual c++ programs will reappear again
YOU ARE ALL SET
HAPPY PROTOTYPING
Hi, have you tried running Adobe Creative Cloud Cleaner Tool? It could help you remove all the files related to a certain software and find some corrupt files that could give you some problems. Adobe Creative Cloud Cleaner
Don't know about the OP, but this worked for me. Thanks @italosan , really appreciate it!
Edit: It worked, but on reboot, I'm getting the same error again. Uninstalling it doesn't seem to fix anything now either.
I understand, at this point I suggest you contact Adobe XD support. Surely they will be able to help you more.
Check to ensure your system meets minimum requirements to support XD
Error code `183 is a permissions problem. See solutions below.
Error code 183 when installing XD on Windows
Moving to the Creative Cloud Download & Install​
HI There.
YOU ARE ALL SET
HAPPY PROTOTYPING
Good Job Mudabir,That worked.
it works.Thanks
I am really sorry to hear about the encountered problem and I am really happy that our community managed to come with a workaround (great job Mudabir). In the meantime we identified the issue as being related to some older versions of MS Visual C++ 2017 Redistributable which might be present on some machines. We implemented a fix around it and it is already publicly available starting today with the latest version of XD, namely version 21.1. The update is available through the Creative Cloud application.
As a note, the fix addresses the specific case of error 183 during installation caused by the failure to run "PluginCleanup.exe" (which is the exact one mentioned in this thread).
