Hi blackshirt,
Could you check the project properties in Flex Builder by
right click on the “Test” project and select
“Properties”? The project properties should look
something like that:
After install Flex with integrated JRun (in default
location):
Flex root folder: C:\fds2 \jrun4\servers\default\flex
Flex server URL:
http://localhost:8700/flex/(where 8700 is the default port number for the Flex/JRun server)
FDS project root: C:\ fds2 \jrun4\servers\default\flex\Test
After install Flex under JRun4 (both in default locations):
Flex root folder: C:\JRun4\servers\default\flex
Flex server URL:
http://localhost:8100/flex/(where 8100 is the default port number for the JRun default server)
FDS project root: C:\JRun4\servers\default\flex\Test
Sharon
Flex Builder QA
