Dynamic Page Changing
Aug 09, 2007 Aug 09, 2007
We have some digital TV's that we are streaming info to across the organization and the TV scheduler is really bad for what we are trying to do so Im looking for some help. Basically we are pushing one webpage out for a one minute block of time then we need it to refresh to the next predefined webpage. We have pages set up for each area that we call spots. We have a list created like this.
hr/spot1.html
Marketing/spot1.html
IS/spot1.html
hr/spot2.html
What we would like to do is handle the scheduling in CFML vs. the lame schedulere they gave us and loop through these pages at 1 min intervals. The trick is we need to put one URL reference in the TV scheduler then have the 1 min looping handled by CFML.
Does anyone know or have ideas on how to accoplish this?
Advanced techniques
968
google "coldfusion sleep".
I have about 30 URL to loop through with each one needing to show for 60 secs. Would this tag work for that?
quote:
yes
My first thought is that you would have one file called by a scheduled
task every 60 seconds. This file would then be responsible for pushing
out the appropriate next content or however your system works.
I could set a scheduled task to run every 60 seconds but how would it know which URL was presented last and which one is in order to go next? We would need them to run in order.
That would be the logic of the page that is run every minute. A simple
method would be an array that is stored in the application scope so it
is available from one request to the next. Then a simple pointer on
what file was called, and change the pointer after each file is
displayed. When you reach the end start over at the beginning.
This sounds like it could work. Would you beable to provide some sample code to get me started? This sounds like what Im looking for.
Aug 10, 2007 Aug 10, 2007
<cfset application.pointer = application.pointer + 1>
<cfif application.pointer > arrayLen(application.urlAry)>
<cfset application.pointer = 1>
</cfif>
<cfset currentFile = application.urlAry[application.pointer]>
<!--- Do Something with currentFile --->
You will need to have something to defines the application.urlAry. A
simple form would do this easily. You then call this file once a minute
with a scheduled task.
Update to insure that variable exist.
<cfparam name="application.pointer" value="1">
<cfparam name="application.urlAry" value="#arrayNew(1)#">
</cfif>
<cfif arrayLen(application.urlAry) EQ 0>
ERROR: No File Array Defined
<cfelse>
</cfif>
I like it let me see if I can get it to work. Be back shortly
I havn't found enough documentation on how to use the CFX_Sleep function.
You don't need cfx_sleep.
http://www.petefreitag.com/item/85.cfm
Like I said not much documentation on that artical. If you could provide some sample code on how that would work using that artical I would be greatful. If not I would like to explore Ian Skinner's idea.
<cfset thread = CreateObject("java", "java.lang.Thread")>
set other variables you need, such as a list of urls.
determine 1st url
start a loop
load url
<cfset thread.sleep(60000)>
change url
end loop.
> determine 1st url
> start a loop
> load url
> change url
> end loop.
A potential problem with this concept is that the request will have to
run for the duration of displaying the files. The default timeout for a
request processing thread is 60 seconds. I'm not sure I would want to
configure my server to run a thread for minutes, hours and potentially days.
Documentation
