1 Reply Latest reply: Nov 26, 2007 1:07 PM by Newsgroup_User RSS
    Image Gallery Paging
    jmottle Community Member
      I am putting together an image gallery but am not quite sure how to approach this using Dreamweaver. The main gallery page will simply connect to all of the images in the gallery and allow you to page through them. When you click on an image and go to the detail page I want the detail page to a larger version of the clicked image. So far easy. HOWEVER, I want that detail page to allow the user to page through all of the other images beloning to that same user. So when you arrive on the detail page, you are really viewing a recordset of all images by a particular artist and you are pushed directly to the image on the first master page. I hope that makes sense. How would I go about doing this?
      Cheers,
      Jeff
        • 1. Re: Image Gallery Paging
          Newsgroup_User Community Member
          "jmottle" <webforumsuser@macromedia.com> wrote in message
          news:fi6u36$r0b$1@forums.macromedia.com...
          > approach
          > of
          > click on
          > version
          > allow
          > user. So
          > all
          > the
          > this?
          > Cheers,
          > Jeff
          You don't say what server model you are using so I won't provide code
          samples.
          You could create a second recordset ton the detail page that holds all image
          records and use that with the recordset navigation serverbehaviors and a
          repeat region for 1 record. You'd have to pass the current page id which
          would be the same as the record-index of the image clicked on the masterpage
          via a querystring parameter to get the repeat-region on the detail page to
          be at the same record.
          In the ASP servemodel dreamweaver has a move to detail record
          serverbehavior, but I'm not sure if that comes with the PHP_MySQL
          servermodel too.
