ROBOHELP: Set Tabs in WYSIWYG
Apr 27, 2006 Apr 27, 2006
Hi
How do I set Tabulators in the Robohelp WYSIWYG?
I often Import from Word-Files. The Tabulators are never imported with it.
Thanx in advance for your kind help.
791
Welcome to the forum.
Am I right in thinking you are referring to RH HTML? If so there is no concept of tags in HTML,
Contributor ,
Peter -
You meant 'tabs', right? Actually, tabs will show up in html if you wrap it with the <pre> or the <xmp> tag. And, you can format the style of those tags, so they don't show up as courier all the time.
Hi Roger
As far as I can see if you go into true code and use the <pre> tag and enter your text there such as
<pre>mmmm...... mmmm...... mmmm</pre>
using the tabs which do work in the true code editor, then RH will not override that in the editor and the spacing will show as entered in the true code view. However, the question was how is this done in Robohelp WYSIWYG.
If you enter the above html in true code and then switch to WYSIWYG, the tab key no longer works.
If I have read about the pre tag correctly, it just leaves the spacing if finds alone. In this instance I suspect that spacing gets lost on import so even if you put pre tags around the text, it would be too late.
Dreamweaver appears to work the same way so it's not a RH thing.
UPDATE: In the example above I put in loads of spaces to emulate tab spacing but quess what happened! Please interpret the full stops as a tab space.
Contributor ,
ah, good point about the wysiwyg, Peter - darn. the truth can be so limiting.
but, switching to TrueCode should be a practical option for all good soldiers. It's so easy to do, and so much fun.
anyway, copying and pasting the tabbed text inside those tags is the only way I know of to use Tabs in Html.
It looks cool, too:
Mar 03, 2007 Mar 03, 2007
Tried the <XMP> example above and everthing worked perfectly. However when I tried to do a link to the appropriate paragraph the source code was displayed on the WYSIWIG.
My original line was:
<p style="text-transform: lowercase;">1.3 SCOPE</p>
I then changed it to:
<XMP>
<p style="text-transform: lowercase;">1.3SCOPE</p>
</XMP>
And there the problem occured.
My list of contents has about 30 items all linked to bookmarks on that page
Could you tell me what I've messed up?
Al
Contributor ,
Mar 04, 2007 Mar 04, 2007
Al -
That's how the <pre> and <xmp> tags are supposed to work: they reflect exactly what you put between them. You can format it, however, by defining the style of those tags: insert the "style="text-transform: lowercase;"" into the <pre> and <xmp> tags themselves.
Mar 07, 2007 Mar 07, 2007
Ahh that would explain it!
That's solved the problem. All I've got to sort out now is why the "lowercase" still leaves the text as upper cast - then we're home and dry!
Al
RoboHelp Documentation
Download Adobe RoboHelp
